Display options for a PC-XT
Reply 20 of 30, by BitWrangler
I think if he already had the RCA composite in the back of his PC he wouldn't be asking. Many cards and systems omitted it. I've got a couple.
Another source of the composite signal might be a header on the CGA board. They can be 2 pin or 4 pin, usually half the 4 pin is a on off jumper for mono/color.
Reply 21 of 30, by rmay635703
BitWrangler wrote on 2026-11-19, 15:31:
Yeah if I had the like option I would hit
You would think Spain would have better equip't TVs than the trash we got here (SCART, multi region, TTL VTR, etc)
My android is blocking me from copying a direct link for some reason but this is what I was thinking if a vintage solution was desired.
https://www.google.com/url?sa=i&source=web&rc … 795189161899000
Even here in the US I have one small sony with a 8 color VTR connector that should sort of work with cga but again pal might throw a wrench in that.
Locally to me I can buy a $5 RF adapter for composite to channel 3 but PAL probably throws a wrench in that.
Ah well, vga it is.
Reply 22 of 30, by Ozzuneoj
Anaxagoras wrote on 2026-11-19, 09:43:
Yes, I’ve understood. The original CGA card has an RCA video output. But I think that model – the CGA installed in the original […]
Ozzuneoj wrote on 2026-11-19, 07:07:
Sorry if I'm misunderstanding what you're saying, but he was just saying to use the IBM CGA card (Color Graphics Adapter) that m […]
Anaxagoras wrote on 2026-11-19, 06:46:
Thanks rmay635703, good to know. But It sounds very expensive, at least to me.
Sorry if I'm misunderstanding what you're saying, but he was just saying to use the IBM CGA card (Color Graphics Adapter) that many IBM PCs and XTs would have originally come with. Specifically, the card shown here (they will have either a green or brown PCB). The RCA jack on it is a basic composite video output, so you can connect it directly to any TV with a composite video (yellow) input.
An XT would normally have come with one of four IBM video cards... Either a CGA card, a Monochrome Display Adapter card, or less commonly an Enhanced Graphics Adapter card... or if someone was made out of money, a rare and stupidly expensive Professional Graphics Controller card.
If your system didn't come with a video card or didn't come with an IBM CGA card, then you're probably best off just getting an OAK or Trident card will connect to a VGA monitor unless you can find an IBM CGA card cheap. There are some interesting things you can do with the composite video out on a CGA card (video demos that do crazy things to output more colors), but that's a pretty specific use case.
Yes, I’ve understood. The original CGA card has an RCA video output. But I think that model – the CGA installed in the original IBM PC-XT – is more expensive than the Trident 9000 VGA and probably hard to find too.
Of course, I know that there are different things.
The problem, or my scenario, is the following:
- PC-XT clone with CGA adapter.
- Monochrome monitor (12'') that’s about to stop working (used in my current setup).
- TV (14").
- TFT (17'').
To be honest, I don’t know what the best setup is for using my PC-XT without spending too much money.
I think the Trident 9000 graphics card plus a TFT monitor is a cheap option, but it means sacrificing the original look and feel.
Of course, the best thing would be to replace the current monitor with a ‘new’ one, but it’s very difficult to find one in good condition, it’s too heavy to post, and I don’t know how long I’ll be able to use it for.
For the other hand the original CGA card with video output to use in TV is the best option in terms of look and feel.
At the moment I created two searches on eBay, one for Trident card and other for CGA with video output.
Ah, I see. Unless I missed it, you hadn't stated previously that you were using a clone or what video card it came with. In general, if someone has an IBM PC XT (5160), there's a good chance they have an IBM CGA card which can connect to an NTSC TV easily. If it's a clone, then that all changes of course. Being in a PAL region means that CGA output to a TV may be problematic for you anyway, as others have mentioned (I hadn't thought of this).
If there's any chance of finding a VGA CRT that someone is getting rid of, that would probably be the best compromise. At that point you'd be able to use any VGA card that can operate in an 8bit ISA slot.
I found a pretty detailed discussion with lists here:
https://forum.vcfed.org/index.php?threads/8bi … ga-cards.26866/
I have only used an OAK OTI-037 for this (with jumpers I believe), but it seems there are lots of options and some VGA chips are autosensing. Those, presumably, can work in an 8bit slot even if there is no obvious jumper to switch modes.
Reply 24 of 30, by Grem Five
I used this list when I got VGA cards for my 5160s. https://minuszerodegrees.net/5160/vga/5160_vga.htm#cards
I can confirm AST VGA Plus, ATI VGA WonderXL and Orchid ProDesigner IIs work in 5160, still looking for a reasonable priced Video Seven model.
Still havent tested EGA,CGA and MDA modes on all but all should do them according to manuals. (still havent tested the mouse on the WonderXL)
Reply 25 of 30, by pavunoDev
If you're not looking to continue using an OG CGA monitor, I'd go for a RGBtoHDMI adapter and use a modern monitor. You're looking at 60-70 euro in Spain and you'd be set permanently, pretty much.
Something like this:
| IBM PC / XT |
| CGA card (DE-9 RGBI out) |
| DE-9 straight-through cable
| (male-to-female, pin 1:1)
v
| RGBtoHDMI (PC edition) |
| CGA input board |
| Raspberry Pi Zero |
| 5V micro-USB power |
| Mini-HDMI to HDMI cable
v
| HDMI-to-VGA converter | <-- Only if monitor lacks HDMI
| (active adapter) |
| VGA cable
v
| VGA TFT monitor |
Can't seem to get this diagram pretty, but should be understandable. Apologies.
Reply 26 of 30, by Anaxagoras
Thank you all for all this information.
Serdashop’s products are brilliant, although at the moment I’m looking for something a bit cheaper.
So I’ve decided to buy a Trident 9000C 16-bit ISA card, but one with a jumper so I can select 8-bit mode.
That way, I can use the same monitor for both the 486 and the PC-XT and save space in the room.
I’m always struggling with space, time and money 😀
My computers
Reply 27 of 30, by theelf
pavunoDev wrote on 2026-11-20, 00:12:
If you're not looking to continue using an OG CGA monitor, I'd go for a RGBtoHDMI adapter and use a modern monitor. You're looki […]
| IBM PC / XT |
v
| CGA input board |
| Raspberry Pi Zero |
v
| (active adapter) |
| VGA cable
v
| VGA TFT monitor |
The attachment image_59b4a0b9.jpeg is no longer available
Anaxagoras wrote on 2026-11-20, 12:54:
Thank you all for all this information. […]
Wallapop el otro dia compre una a 12 euros, aunque lo normal es 20-25
Reply 28 of 30, by Babasha
Sometimes it reqs soldering too
My 9000C have jumper 8/16 bit but when I use it in my XT it gives me no image so I make some knife/solder modification (1-2 minutes with soldering)
Need help? Begin with photo and model of your hardware 😉
Reply 29 of 30, by pavunoDev
theelf wrote on 2026-11-20, 13:39:
Wallapop el otro dia compre una a 12 euros, aunque lo normal es 20-25 […]
| IBM PC / XT |
v
| CGA input board |
| Raspberry Pi Zero |
v
| (active adapter) |
| VGA cable
v
| VGA TFT monitor |
not sure why i specified VGA TFT, in reality any VGA would do, and it should look pretty good with a VGA CRT
Reply 30 of 30, by rmay635703
wierd_w wrote on 2026-11-19, 16:37:
Again, they could also *try* an 8bit serdavision.
https://serdashop.com/products/serdavision-hdmi
That, plus some TSRs for better support of CGA composite, ( https://github.com/RetroErik/CGA-Composite-to-VGA ,et al ), might give the most mileage with what's available?
They could also try to get the monitors issues well described for troubleshooting, IBMs 5153 CGA Monitor is well understood for troubleshooting, I've occasionally been surprised that some rather major component failures are moderately inexpensive to get repaired (depending on luck of what's available for replacement parts locally)
A broken 5153 is still worth money in inop condition which could help fund its replacement sold asis inop.
