Reply 33640 of 58804, by Horun
darry wrote on 2020-04-27, 17:28:
Dell 2007FPB arrived . It's the S-IPS variant, made in 2009, and has 50000 odd hours on the clock .
For a total of 105 Canadian dollars including shipping, I would call it a good deal .
Nice ! I have the little sister a 1908fpt. Works very well though limited to 1280x1024 max but my eyes are bad so not a big deal 😀
The adjustable height and pivot on some of the UltraSharp models is a good feature !
Reply 33641 of 58804, by darry
Horun wrote on 2020-04-29, 00:44:
The adjustable height and angle are great . I have a Samsung 204B for which I had to purchase a stand because the original one was really unsatisfactory to me .
Reply 33642 of 58804, by bofh.fromhell
Managed to snag an Elsa Geforce 2 Ultra card for about $50.
Can't find any on ebay right now so I'm not sure if I overpayed or not, but I reccon it was a bargain.
Looks nice next to my Gainward GF2U (With DVI!) that I bought new many moons ago:
Reply 33643 of 58804, by pan069
Daniël Oosterhuis wrote on 2020-04-28, 17:13:
https://i.imgur.com/wApPKfq.jpg?1 […]
wApPKfq.jpg?1
Nice case. I have seen this model before. I had a similar case back in the early 90's, which I think was produced by the same company but I have never seen the model I had. My model was more "round", like it had a belly. Also, the power button was black instead in gray. Did you find this case in the Netherlands? Maybe the type and model was unique to Western Europe...
Reply 33644 of 58804, by Caluser2000
Put an ACORN sticker on my test bench.
Reply 33645 of 58804, by devius
2Mourty wrote on 2020-04-28, 21:15:
Did the t41p every have an ips display option or did that start with the t42?
I'm not sure, but this one is definitely not IPS, although it is high res at 1400x1050, which is pretty good for 2004.
Reply 33646 of 58804, by imi
So... funny story, I bought this random Siemens Nixdorf Xpert case off ebay recently, just because it was a pretty compact full ATX case while still retaining several drive bays in a somewhat weird setup... but it wasn't expensive and thought it would make for a fun build, I don't have a picture of the case at hand right now, but it is this one:
https://gshaw0.files.wordpress.com/2018/12/IM … 25_160838-1.jpg
why funny?
a little while later while browsing around ebay I stumbled upon this board with onboard Matrox GPU and memory upgrade... that alone was reason for me to scoop it up... turns out that's the exact Siemens Nixdorf board that belongs in this case type, see the missing bottom ISA? That's because the case only has 6 card slot openings ^^
seems like an interesting board overall regardless of this coincidence.
The attachment hardware38_22.jpg is no longer available
it also seems to have a socket for an extra wavetable chip in addition to the CS4238b onboard sound chip, google tells me that a CS9236 should fit.
The attachment hardware38_22b.jpg is no longer available
also picked up another scrap lot that mostly consisted of trashed AV equipment PCBs but had a few nice boards in between, I kindly asked the seller to only send me those so all the big AV boards and power transformers wouldn't damage these in transit ^^
ASRock 939 Dual-sata2, one of these strange ASRock Upgrade boards with AGP/PCIe that I'll probably never find the upgrade card for ^^
unfortunately the heatsink came off (was apparent in the sellers pictures already) and the socket seems to have broken, the white plastic piece detached a bit and the lever fell out, but I could put it back together, will have to see if this one still works.
The attachment hardware38_23.jpg is no longer available
Shuttle HOT-307, some corrosion on the 32bit slot for some reason, but seems to be fine otherwise, battery had already been removed.
The attachment hardware38_24.jpg is no longer available
and the main reason why I wanted this lot... this rather nice ASUS PVI-486SP3, PCI/VL board :3
The attachment hardware38_25.jpg is no longer available
Reply 33647 of 58804, by imi
oh... also the asus board had this CPU on it which the seller seems to have removed ungracefully unfortunately, had to straighten a few pins again...
didn't have one of these yet, so that was another reason why I got it ^^
The attachment hardware38_26.jpg is no longer available
luckily I had also marked the two upside down CPUs in the very last picture for the seller to send me, because that as it turns out were actually the CPUs that were in the boards on the other pictures.
Reply 33648 of 58804, by varrol
bofh.fromhell wrote on 2020-04-29, 03:17:
I had exactly this Elsa model like 20 years ago - with Thermaltake Crystal Orb - overclocked nicely 😀
But this was the only graphic card I had replaced under warranty 😉
I had it with 3d Glasses that worked only with CRT screens and high refresh rate (~120Hz) - nice gadget - I wonder how much the whole set with original box would be worth now (I sold it for nothing back then - like we all did I assume).
AOpen AX6B+ | P3 1G | 1GB ECC REG | FX5200 | CT4500
AOpen AX59pro | K6-2 450M | 256MB | Rage 128
Asus CUBX-E | P3 1G | 512MB | GF4 TI4200 | YMF719E-S
Asus P3B-F | P3 933M | 384MB | Radeon 9200 | CT4520
Asus P5A | P55C 200M | 256MB | Riva TNT | CT3600
Reply 33649 of 58804, by Daniël Oosterhuis
Cyrix200+ wrote on 2020-04-28, 18:42:
Don't get rid of the case badge, I've been wanting one of those myself also. I think the seller also is a retro computer fan!
I'm not a huge Terminator-head myself, but I'll be sure to carefully remove it if I ever want to swap it out for something else, and see if I can pass it on to someone else. I've been thinking about doing a custom purple badge with a white AMD logo, underscored by "Am486DX4-100" in an appropriate font, but I think it's a bit expensive to do, given you have to get several. I was thinking of maybe gauging intererest in such a label on Vogons, and seeing if a group buy would be possible to set up, but I don't know if that goes against any rules regarding the ban on selling on this site, and it'd still be a lot of effort and responsibility for a small sticker 😜
And yeah, the seller is definitely into this stuff, he preloaded the system with some good games, and Windows 3.1 from original floppies.
imi wrote on 2020-04-28, 17:21:
watch out, don't let skynet into your network!
Haha, its CD-ROM Device Name is set to SKYNET, better not put a NIC in this machine, hook it up to dial up, or feed it any writeable media!
pan069 wrote on 2020-04-29, 06:06:
Yes, it was sold on a Dutch site, so I figure it's from around here. It's always tricky to find these specific AT cases, given they were generic and mostly model number-less.
Reply 33650 of 58804, by pan069
imi wrote on 2020-04-29, 16:43:
Nice. I've got the REV 1.8 of this board. I'm using this board in my DX4-100 build.
Reply 33651 of 58804, by wirerogue
i needed a pci video card so picked up this stb velocity 3d with 4+4mb ram.
i really like video cards with add on memory modules.
The attachment stb.velocity.3d.jpg is no longer available
Reply 33653 of 58804, by flupke11
Real life is hampering my Tualatin tests, but luckily bidding and buying does not eat away a lot of time.
After finding my first AMD Slot A, I got another one!
For 30 euro I got the following: MSI 6191, with the proper, yet not-so-stable Irongate chipset, a Slot A Athlon 800, a nice Taisol Socket A cooler (which will be used for the Tualatins), 3 sleeved ATA133 and a Sparkle FX5900XT AGP. Hopefully all works.
Upgraded my daily from a 3770K to a 4790K as the former was acting up. If I can get the 3770K stable again, that will replace my Xeon 5460 as the main Linux/forensic station. The xeon will then be demoted (promoted) to a late WinXP/early Win7 gaming rig.
Looking forward to rainy weather and overtime leave 😉
Reply 33654 of 58804, by Bancho
Picked up this little sound card for a cheap price. Saw the Dream Chip on it and decided to grab it. I'm not sure what chip is underneath the sticker. Will try and find out later when i test it.
Reply 33655 of 58804, by badmojo
Bancho wrote on 2020-04-30, 08:53:
That looks like a winner! The chip under the sticker looks to be the wrong shape for Crystal but I'll make that my guess anyway - please let us know what you find.
Reply 33656 of 58804, by appiah4
Looks like an ES1688/1868 IC.. Awesome card.
Reply 33657 of 58804, by dave343
Cache for 486, just grabbed it from Digikey
Reply 33659 of 58804, by dionb
Two parcels today - one very small, the other a bit bigger:
The attachment 15882536518630.jpg is no longer available
The Roland SC-55ST at last gives me full GS. A slight shame not to get the full display, but it would have cost me three times the price for an SC-55mk2, so more than happy with this.
And the MOS6581 aka SID. Anyone want to guess which sound card replica I intend to build soon? 😉
