So... funny story, I bought this random Siemens Nixdorf Xpert case off ebay recently, just because it was a pretty compact full ATX case while still retaining several drive bays in a somewhat weird setup... but it wasn't expensive and thought it would make for a fun build, I don't have a picture of the case at hand right now, but it is this one:
https://gshaw0.files.wordpress.com/2018/12/IM … 25_160838-1.jpg
why funny?
a little while later while browsing around ebay I stumbled upon this board with onboard Matrox GPU and memory upgrade... that alone was reason for me to scoop it up... turns out that's the exact Siemens Nixdorf board that belongs in this case type, see the missing bottom ISA? That's because the case only has 6 card slot openings ^^
seems like an interesting board overall regardless of this coincidence.
it also seems to have a socket for an extra wavetable chip in addition to the CS4238b onboard sound chip, google tells me that a CS9236 should fit.
also picked up another scrap lot that mostly consisted of trashed AV equipment PCBs but had a few nice boards in between, I kindly asked the seller to only send me those so all the big AV boards and power transformers wouldn't damage these in transit ^^
ASRock 939 Dual-sata2, one of these strange ASRock Upgrade boards with AGP/PCIe that I'll probably never find the upgrade card for ^^
unfortunately the heatsink came off (was apparent in the sellers pictures already) and the socket seems to have broken, the white plastic piece detached a bit and the lever fell out, but I could put it back together, will have to see if this one still works.
Shuttle HOT-307, some corrosion on the 32bit slot for some reason, but seems to be fine otherwise, battery had already been removed.
and the main reason why I wanted this lot... this rather nice ASUS PVI-486SP3, PCI/VL board :3
