Reply 40 of 223, by BEEN_Nath_58
New entry:
Driver
Reply 41 of 223, by BEEN_Nath_58
New entry:
Civilization 2
Fury3
Reply 42 of 223, by BEEN_Nath_58
New update:
Remove FEAR series because I dont know why I added it
Added info for Hitman Codename 47
Reply 43 of 223, by Jorpho
Discrete_BOB_058 wrote on 2020-05-01, 19:50:
Zuma Deluxe
Not sure what led you to this conclusion. Pretty much every Popcap game (except Bejeweled 3) uses the same framework with the same bug: the scaling in fullscreen is completely messed up unless you switch to a 4:3 desktop resolution before launching. It might just be a bug in nvidia's drivers rather than something in Windows, technically.
Either way, you could totally pad out the list with all of Popcap's games if you wanted to, but I'm not sure what the point of that would be.
Reply 44 of 223, by BEEN_Nath_58
Jorpho wrote on 2020-08-25, 20:18:
Zuma Deluxe
Well I could never run the game on a 16:9 res. This may not be a bug but not a feature implemented then. Hitman Codename 47 also has scaling problems in Glide on 16:9.
Zuma Deluxe
Well I have used nVidia, Intel, ATi cards and never faced this.
Reply 45 of 223, by Jorpho
Discrete_BOB_058 wrote on 2020-08-26, 03:38:
The games always run at 4:3, but the scaling gets messed up unless the desktop resolution is 4:3 before launching. I should also add that the problem can also be fixed by disabling hardware acceleration in the Options menu for each game, but then you lose whatever fancy zooming and particle effects the game might employ. It is easy to dismiss the issue by saying "oh, these games are old and low-res and pixelated, they're supposed to look like that", but it makes a huge difference.
Reply 46 of 223, by BEEN_Nath_58
Jorpho wrote on 2020-08-26, 05:59:
Well as you say I will check.it out again,but I didn't find this problem even when my monitor was at 16:9
Reply 47 of 223, by BEEN_Nath_58
New entry:
Test Drive Off-Road 3
Reply 48 of 223, by BEEN_Nath_58
New update:
Added more data to Colin McRae Rally
Reply 49 of 223, by BEEN_Nath_58
New entry:
Revolt
Reply 50 of 223, by BEEN_Nath_58
New entry:
Re-Volt
Reply 51 of 223, by BEEN_Nath_58
New entries:
Mafia
Grand Theft Auto Vice City
Reply 52 of 223, by BEEN_Nath_58
New entry:
Tomb Raider II
Reply 53 of 223, by BEEN_Nath_58
New entry:
Final Fantasy VII
Reply 54 of 223, by BEEN_Nath_58
New update:
Added information regarding running Red Alert
Reply 55 of 223, by BEEN_Nath_58
New update:
Added information for FIFA 2000 and NFS2SE
Reply 56 of 223, by BEEN_Nath_58
New entry:
Time Gate Knight's Chase
Reply 57 of 223, by BEEN_Nath_58
New update:
A lot of useless data are removed
Reply 58 of 223, by BEEN_Nath_58
New entries:
Half-Life Opposing Force
Half-Life Blue Shift
Half-Life Decay
Reply 59 of 223, by BEEN_Nath_58
New update:
Added information for MK4
