Reply 40 of 217, by BEEN_Nath_58
New entry:
Driver
New entry:
Driver
New entry:
Civilization 2
Fury3
New update:
Remove FEAR series because I dont know why I added it
Added info for Hitman Codename 47
Discrete_BOB_058 wrote on 2020-05-01, 19:50:Zuma Deluxe
Not sure what led you to this conclusion. Pretty much every Popcap game (except Bejeweled 3) uses the same framework with the same bug: the scaling in fullscreen is completely messed up unless you switch to a 4:3 desktop resolution before launching. It might just be a bug in nvidia's drivers rather than something in Windows, technically.
Either way, you could totally pad out the list with all of Popcap's games if you wanted to, but I'm not sure what the point of that would be.
Jorpho wrote on 2020-08-25, 20:18:Discrete_BOB_058 wrote on 2020-05-01, 19:50:Zuma Deluxe
Well I could never run the game on a 16:9 res. This may not be a bug but not a feature implemented then. Hitman Codename 47 also has scaling problems in Glide on 16:9.
Well I have used nVidia, Intel, ATi cards and never faced this.
Discrete_BOB_058 wrote on 2020-08-26, 03:38:Well I could never run the game on a 16:9 res. This may not be a bug but not a feature implemented then. Hitman Codename 47 also has scaling problems in Glide on 16:9.
The games always run at 4:3, but the scaling gets messed up unless the desktop resolution is 4:3 before launching. I should also add that the problem can also be fixed by disabling hardware acceleration in the Options menu for each game, but then you lose whatever fancy zooming and particle effects the game might employ. It is easy to dismiss the issue by saying "oh, these games are old and low-res and pixelated, they're supposed to look like that", but it makes a huge difference.
Jorpho wrote on 2020-08-26, 05:59:Discrete_BOB_058 wrote on 2020-08-26, 03:38:Well I could never run the game on a 16:9 res. This may not be a bug but not a feature implemented then. Hitman Codename 47 also has scaling problems in Glide on 16:9.
Well I have used nVidia, Intel, ATi cards and never faced this.The games always run at 4:3, but the scaling gets messed up unless the desktop resolution is 4:3 before launching. I should also add that the problem can also be fixed by disabling hardware acceleration in the Options menu for each game, but then you lose whatever fancy zooming and particle effects the game might employ. It is easy to dismiss the issue by saying "oh, these games are old and low-res and pixelated, they're supposed to look like that", but it makes a huge difference.
Well as you say I will check.it out again,but I didn't find this problem even when my monitor was at 16:9
New entry:
Test Drive Off-Road 3
New update:
Added more data to Colin McRae Rally
New entry:
Revolt
New entry:
Re-Volt
New entries:
Mafia
Grand Theft Auto Vice City
New entry:
Tomb Raider II
New entry:
Final Fantasy VII
New update:
Added information regarding running Red Alert
New update:
Added information for FIFA 2000 and NFS2SE
New entry:
Time Gate Knight's Chase
New update:
A lot of useless data are removed
New entries:
Half-Life Opposing Force
Half-Life Blue Shift
Half-Life Decay
New update:
Added information for MK4
