HWiNFO support of vintage hardware
Reply 520 of 717, by Mumak
appiah4 wrote on 2021-05-19, 22:23:
Mumak wrote on 2021-05-11, 07:32:
appiah4 wrote on 2021-05-11, 07:20:
How do I generate one from the MS-DOS version? I think I have version 6.1.3 by the way.
Either manually pressing F2 will save content of current screen into a LOG file, or automatically using the -r switch. Adding -d will also produce DBG file that contains some more details for me.
Here you go, I hope it helps. 😀
Thanks! It's useful for my reference and future improvements.
What DELL monitor is that, P2414H? This model isn't in my database yet.
Reply 523 of 717, by ultra_code
Tested out an ATI Rage LT PRO AGP PCI card under 98SE on my Asus TUSL2-C test-bench, and noticed questionable clocks being reported. Frankly, not sure what the actual clocks for this card are supposed to be, but looking on Wikipedia, these don't look quite right. Was wondering if you could take a look at it Mumak. Thanks!
https://en.wikipedia.org/wiki/List_of_AMD_gra … Mobility_series
Builds
Reply 524 of 717, by Mumak
Frankly, I'm not sure here either. Clock detection here is implemented per documentation but I can't rule out cases where some additional/special clocking logic is involved.
Is there some other tool being able to report clocks that we can trust?
Reply 525 of 717, by ultra_code
Mumak wrote on 2021-07-05, 10:35:
Not that I know of, no. Everest did not report clocks, Rivatuner224C provided nothing, and the drivers I used didn't provide any information. Maybe newer drivers would say something, but I'm doubtful.
Builds
Reply 526 of 717, by appiah4
Please find attached a report and debug file for my new toy, a Fujitsu Lifebook S6110 laptop running Windows 98SE. All seems to be in order but hopefully it helps with something anyway.
Reply 527 of 717, by Mumak
appiah4 wrote on 2021-07-16, 11:29:
Thanks, looks good 😀
Reply 528 of 717, by zapbuzz
the_ultra_code wrote on 2021-07-05, 10:28:
Tested out an ATI Rage LT PRO AGP PCI card under 98SE on my Asus TUSL2-C test-bench, and noticed questionable clocks being repor […]
That little metal can on your GPU card is the clock crystal be wise to test it they vibrate silently to death. Also happens to old motherboards.
They are cheap to get though just that tedious surface mount job is all.
Reply 530 of 717, by ultra_code
zapbuzz wrote on 2021-07-19, 15:38:
Not sure how you would test it. With a multimeter perhaps? Also, I've already recycled the card - it was causing a short somewhere, don't have the knowledge to diagnose it, and frankly don't care enough for such a strange card. 😒
Builds
Reply 531 of 717, by zapbuzz
the_ultra_code wrote on 2021-07-19, 23:18:
theres a youtube channel with technicians of a computer museun they called CuriousMarc that demonstrates how to test clock crystals https://www.youtube.com/c/CuriousMarc/featured
SiS6326 had an AGP chip on PCI came in 4 to 8mb vram I recommend them as the pci solution of such a contraption if one was to look for them the SiS bios came out with bios upodate TSR programs that bios could be programmed into many system BIOS eliminating the onboard video bios (i took it off the card ran much faster)
Reply 532 of 717, by Cyrix200+
Tried HWiNFO32 on my Dual Pentium Pro build (not done yet).
- Some DIMMs are recognized as FPM (should be EDO)
- Temperatures and other sensors have strange values
- Audio is not fully recognized (listed as Unknown or none, but devices are present)
- In SMBIOS DMI the L1 and L2 cache are listed but have no title (this might be just the way it is)
- Serial ports are disabled in BIOS, but still found by HWiNFO32. But Windows 2000 also assumes they are there in Device Manager with the yellow exclamation marks
Thanks for keeping retro-HWiNFO alive!
    48.37 KiB
    DPPRO.LOG
    79.61 KiB
    95 downloads
1982 to 2001
Reply 533 of 717, by Mumak
Cyrix200+ wrote on 2021-10-20, 12:39:
Tried HWiNFO32 on my Dual Pentium Pro build (not done yet). […]
Thanks for the feedback. Please also attach the HWiNFO Debug File, I need to check more details.
From a quick look - the BIOS also reports 2 modules as FPM in SMBIOS DMI. The L1/L2 info in DMI is populated by BIOS.
Reply 534 of 717, by Cyrix200+
Mumak wrote on 2021-10-20, 13:23:
I have reset the BIOS settings between my previous post and this post. I've attached the debug file and a new log file.
    HWiNFO32.DBG.txt
    119.66 KiB
    106 downloads
    DPPRO.LOG
    81.46 KiB
    94 downloads
1982 to 2001
Reply 535 of 717, by Mumak
Cyrix200+ wrote on 2021-10-20, 14:49:
Looking at the raw data, the memory controller is indeed configured so that the last rows are in FPM mode. Could be a BIOS issue.
Reply 536 of 717, by Cyrix200+
Mumak wrote on 2021-10-20, 17:17:
Ha, the memory controller was actually right. The DIMMs are FPM: https://www.servers4less.com/memory/server/mi … shi-mh4v72czj-6
FPM is not (officially) supported by the board (http://www.win3x.org/uh19/motherboards/3172), so I had assumed it was EDO memory.
1.4.1 Main Memory The motherboard has four DIMM sockets. Minimum memory size is 16 MB and maximum memory size is 512 MB. The m […]
1.4.1 Main Memory
memory size is 512 MB. The motherboard supports the following memory types, speeds, and
module sizes:
• 168-pin 3.3 V DIMMs with gold-plated contacts
• 50 ns and 60 ns buffered asynchronous EDO memory
• Parity and ECC memory
• 2 MB x 72 (16 MB), 4 MB x 72 (32 MB), 8 MB x 72 (64 MB) and 16 MB x 72 (128 MB)
modules
1982 to 2001
Reply 537 of 717, by leonardo
Here are the report files for my older systems:
I would also like to note that HWiNFO 7.12 does not start on Windows 95. There is no error, it just fails to load. Dependency Walker doesn't find any issues with 7.12, either. Version 6.24 runs, so that's what I used to generate the debug files and reports.
[Install Win95 like you were born in 1985!] on systems like this or this.
Reply 538 of 717, by Mumak
leonardo wrote on 2021-10-24, 21:04:
Here are the report files for my older systems: […]
Thanks for the reports, the output looks good to me. Would you be able to try some versions between 6.34 and 7.12 to find out which is the latest one working on Win95?
Reply 539 of 717, by leonardo
Mumak wrote on 2021-10-24, 21:25:
I seem to recall I did test and found 6.24 to be the last version, but I may have skipped some versions in-between. I'll test all the versions again soon!
The reports are fairly throrough, although I noticed some odd discrepancies between what's shown in the System Summary-window and what is put in the report. For example, on my AMD-system, the memory timings nor the FSB clock are displayed. I think on the P3 the first timing data is shown, and then no more. Nevermind, here's the P3 screen:
On the AMD system, the FSB multiplier is shown as 1.0x and the other fields are just blank, even though in the report it has correctly determined a 75 MHz bus.
