First post, by Bondi
I've finally received my DSS. it's working, but sounds weird. The playback is kind of slow. As if the samples are played at a lower rate. Or can this a problem on the analogue side? There are no obvoius visible problems on the PCBs. I've also tried to poke the adjustable resistor on the dongle, no effect. It's same thing in all games and different computers.
I'd be very grateful for any help on this.
Here a sample recording from DOOM.
The attachment DSS.mp3 is no longer available
PCMCIA Sound Cards chart
archive.org: PCMCIA software, manuals, drivers
68pins.com custom PCMCIA drivers
Reply 1 of 15, by matze79
maybe variable resistor is dirty or capacitor on ne555 is aged.
Replacing them should fix it
if you have a scope check output frequency of NE555 it should be around 7Khz
Reply 2 of 15, by Bondi
matze79 wrote on 2021-12-18, 20:22:
Thanks for the respond! Here are the internals Re: Disney Sound Source Pinout
Which capacitor is the suspect?
Don't have a scope, unfortunately.
Reply 3 of 15, by matze79
Ah sorry i was thinking about clone.
Normal dss has no ne555.
Well I would first start with cleaning the VR. Spill it with isopropyl alcohol and turn it bit forward and back.
Can you see the small foil capacitor (green) maybe it is the issue here ?
Please try a different game which has native dss Support.
Does it also happen in niteraid or hocus pocus?
Reply 4 of 15, by Benedikt
matze79 wrote on 2021-12-19, 11:10:
One could also try to connect a resistor in parallel using test leads. If that makes a difference, the variable resistor needs to be cleaned or replaced.
Reply 5 of 15, by Bondi
Ah sorry i was thinking about clone. Normal dss has no ne555. […]
I've tried also Wolf3D that has DSS native support - same thinng. Will try Hocus Pocus too.
I'll start with cleaning the resistor. Hope the solution is that simple.
DSS has the ICS1493 clock synthesizer that generates 22.5792 MHz clock. I assume it's divided somehow by 3 to get the 7,something clock that DSS is working on. I'm not really into electronics, but can this "division" be issue? How is it done (if at all)?
And can the problem be on the amplifier side?
Benedikt wrote on 2021-12-19, 14:09:
Thank you for the suggestion. Will try that as well.
Reply 6 of 15, by matze79
The Datasheet you read is for different IC they simply have same Name.
Its no way a ICS1493, this is SMD Chip and much more modern.
It did not even exist back then 😀
Its a Custom ASIC.
No the Amplifer Box ist just LM386 Amp, it can`t change speed.
It must be the VR or a Capacitor.
It could be the foil capacitor is aging for example.
Not sure what its purpose is, so i only can guess.
Reply 7 of 15, by Tiido
The thing uses a simple RC oscillator for its timebase and that film capacitor + potentiometer are for controlling the oscillation speed. If the pot doesn't make a difference it is surely misbehaving, but if it does change the pitch but not enough it might be the capacitor gone significantly out of spec.
Reply 8 of 15, by Bondi
So, yes, it was the potentiometer. Just cleaning did not help as It was way out of the specified 200k. After long fiddling i managed to lower the resistence to about 85k and the sound is almost correct now. Will replace it it at some point.
Thanks to everyone for your help!
Reply 9 of 15, by dionb
Not exactly on-topic, but my cat also had big issues with the sound sample in OP, where she normally snoozes happily through Doom. Perhaps I should use her more for diagnostics of sound issues.
Reply 10 of 15, by Bondi
dionb wrote on 2021-12-21, 22:08:
Haha, I have my son in the role of your cat. He called the DSS distorted samples, pardon, "rectal sounds"
Reply 11 of 15, by matze79
haha 😀 nice it works.
Reply 12 of 15, by Scandy
Hello,
may I ask how it's possible to play DOOM sounds on a DSS? Thank you!
THE NIGHTLAND is my board + video game for Commodore 64.
Reply 13 of 15, by Bondi
Scandy wrote on 2022-05-06, 18:14:
Hello,
FastDoom mod has DSS support FastDoom. A new Doom port for DOS, optimized to be as fast as possible for 386/486 personal computers!
Reply 14 of 15, by Scandy
So the sample recording in your first post is from FastDoom? Thank you so much for your kind feedback.
