A brief comparison of 386 FPUs
Reply 120 of 148, by rasz_pl
JohnBourno wrote on 2022-03-22, 12:58:
What is interesting, is that without a FPU Duke Nukem 3d sometimes gets slowed down significantly. It drops from 20 frames per second to 7 fps in some scenes. Turns out that Duke3D uses floating point operations for rendering slopes. So without an FPU every time you have some slopes in your viewports the CPU has to do all the extra work and the game gets almost unplayable. Just by adding a IIS FPU the fps only drop to 15 instead of 7. So quite playable.
90MHz NexGen Nx586 drops down to 10fps on first screen with sloped roof for that very reason:
https://youtu.be/41O2bNG2qKA?t=234
Im sure today someone could come up with a faster integer/lookup table method of calculating those slopes.
Reply 121 of 148, by BitWrangler
Next time I find/boot my U5S CPU, I should try it out on DN3D with one of the 387 emulators see if there's a speed boost.
Reply 122 of 148, by galanopu
So... here is an update.
My 387DX FPU collection has increased by a lot.
All overclocked to the max (up to 55MHz). Enjoy:
https://www.youtube.com/watch?v=Zvisa_-uEqI
Let's mod everything! Check my youtube channel:
https://www.youtube.com/channel/UCZ6ULBqIKhxuNslAbqFNJUg
Interested in my devices? Check my store:
https://migronelectronics.bigcartel.com
Reply 123 of 148, by Ailicec
On the 4x4 instruction.. you load the 4x4 transformation matrix into alternate register sets, then leave them resident while you load the fairly small 4x1 vector. Typically the transformation matrix is reused many times, so this saves a huge amount of communication overhead. For the time, a very big win. You also presumably (I haven't tried it) get a pretty good chunk of time that the FPU is busy and you might be able to do something useful with the integer unit. Easier than trying to work in a couple int instructions in between normal FPU instructions.
Often you can get away with a 3x3 matrix for 3d graphics, which would be a bit faster, but they didn't support that.
A downside.. Operating systems don't know about it, so they don't save the extra register sets. It didn't matter much at the time.
Deunan wrote on 2021-04-27, 08:44:
Personally I see one big problem with the 4x4 operation - it needs all the data to be fed to FPU and then the results be read back. AFAIR you need to start with empty stack, use IIT-specific stack extension instructions, and some of the input arguments are over-written to store the result. This, coupled with the rather slow CPU-NPU comm channel, limits the usefulness of such instructions. Weitek worked around that by having their NPU register space memory-mapped, at the cost of even lower compatibility with typical x87 code.
Long story short: It took MMX to finaly have some direct access to FPU register space, and even that was flawed due to cost of switching between MMX and x87 modes. SSE finally made FPU on x86 family somewhat saner by today's standards.
Reply 124 of 148, by Sphere478
I’m going to be building a 386 er ‘486’ system soon. And using the texas instruments sxl2 66 on the new interposer.
And was wondering what the best fpu to pair with it would be.
This will be the slowest system that I have ever built. So it will be kinda fun new territory for me.
I’ll have to post the exact mobo model later as I can’t seem to remember it, but I think it is a shuttle hot with 16 isa and 8 bit isa. I seem to recall it having a AMD-40 soldered on and a witek socket as well as a cpu upgrade socket
Sphere's PCB projects.
Reply 125 of 148, by pshipkov
For up to 40-45MHz base frequency that will be a combination of Weitek Abacus 3167 + Cyrix FasMath (gray top) or ULSI DLC.
Where ULSI is faster in Quake 1 only and Fasmath at everything else.
At 50mhz base you will most likely be going with Cyrix Fasmath (black top) or ULSI DLC. No idea is 3167 can manage that speed.
retro bits and bytes | DOS media library
Reply 128 of 148, by kixs
Sphere478 wrote on 2022-12-15, 04:08:
I’m going to be building a 386 er ‘486’ system soon. And using the texas instruments sxl2 66 on the new interposer. […]
For x2 CPU I'd use the x2 FPU - like ULSI 66 or IIT 50.
Visit my AmiBay items for sale (updated: 2025-10-29). I also take requests 😉
Reply 129 of 148, by pshipkov
Dont know if the (very rare) 2x models can tick reliably at 80, 90 or 100 mhz.
Also, IIT 387 FPUs are actually very slow.
Reply 130 of 148, by feipoa
sphere, a run of the mill black-top Cyrix FasMath at 40 Mhz is your best bet for an SXL2 at 80 Mhz. There is only benefit in the ULSI DX2-66 if you are running your SXL2 at 66 MHz. I doubt the ULSI DX2 can do 80 MHz.
Reply 133 of 148, by Sphere478
So the ulsi dx2 is faster but can’t do 80mhz
So a 40mhz black top is the fastest option for a overclocked sxl2
but a stock speed sxl2 the fastest would be ulsi dx2?
What would be the fastest overall combo?
Ulsi and sxl2 at 75 mhz?
I’m going for maximum upgrade here.
Reply 134 of 148, by feipoa
I think it best to forget about the ULSI DX2-66. This FPU takes rare to a new level. Even if the ULSI DX2-66 ran at 75 MHz, which is doubtful, an SXL2 system at 80 MHz coupled with a Cyrix FasMath at 40 Mhz will be faster.
Reply 137 of 148, by feipoa
It can use a Weitek or a regular 387 FPU, but the Weitek only works for very select applications.
Reply 138 of 148, by galanopu
Sphere478 wrote on 2022-12-17, 18:03:
Got one of these correct one?
Check again my last video.
Assuming testing at the same clock, the fastest FPU is the Cyrix -KN.
No question about that. This one is a bit rare though.
Now benches are nice but in practice a 387 FPU are a bit pointless these days.
Games that need one, just run to slowly with a system of this class.
CAD programs are just too old and pointless.
So in the end a 5% difference in FPU performance, you will not really notice.
And the Cyrix you got is also a good one.
Reply 139 of 148, by Anonymous Coward
The "KN" is the older design with the grey top, right? Don't those have compatibility issues with Cyrix's own SLC/DLC CPUs?
How about a CX83D87-40HP? Those are also very rare. I assume the only difference over the standard black top is just the packaging...but has anyone every benched one?
