Reply 43541 of 59011, by imi
hey, thanks!
for some reason it didn't occur to me to go to the internet archive 😁
Reply 43542 of 59011, by Kahenraz
imi wrote on 2022-03-28, 00:43:
hey, thanks!
I'm curious if your board supports DMA on the ISA slot. My board is very similar but has a PC87200VUL PCI-ISA bridge chip. Yours has a Winbond W83628, which is supposed to be compatible, but I've heard that it can have problems with some ISA sound cards. I don't have any boards with this Windbond chip, so I can't confirm.
Reply 43543 of 59011, by Tetrium
imi wrote on 2022-03-28, 00:06:
i845
from what I could find it is AGP 4x
It's probably not compatible with AGP 2x cards however. Not with this particular chipset (and i865)
My retro rigs (old topic)
Report spammers here!
Reply 43544 of 59011, by ChrisK
Seems to be AGP UNIVERSAL 2X/4X SLOT according to this...
RetroPC: K6-III+/400ATZ @6x83@1.7V / CT-5SIM / 2x 64M SDR / 40G HDD / RIVA TNT / V2 SLI / CT4520
ModernPC: Phenom II 910e @ 3GHz / ALiveDual-eSATA2 / 4x 2GB DDR-II / 512G SSD / 750G HDD / RX470
Reply 43545 of 59011, by imi
yeah that datasheet was the only thing I found outside of the internet archive ^^ but no it most certainly is not universal, it's keyed only for 1,5V and a 3,3V card that is keyed correctly will not fit and a 3,3V that is keyed universal will destroy the board as like Tetrium said the 845 chipset is incompatible with 3,3V signaling (you can find a few warnings against certain cards online)
Kahenraz wrote on 2022-03-28, 03:25:
in theory it should, it is actually the smaller W83629 chip below that is needed for DMA functionality iirc from the last time I read up about it, and ICH2 should support DMA no problem afaik, so if it's implemented correctly it should work.
Reply 43546 of 59011, by ChrisK
You are right. May be the statement from the schematic is meant from a VGA card's perspective as AGP 4x/1.5V cards with universal keying are said to be AGP 2x/3.3V compatible.
Yet somewhat confusing.
Besides that, I've never seen a PCI-to-ISA bridge function implemented with an additional IC.
Reply 43547 of 59011, by brostenen
Well.... It finally arrived in the weekend. The bad part, is that it does not seem to support power from ZorroBus (with a hardware mod that is) and it came without any PSU (I knew that in advance). So I have no way of testing before I can find an original PSU or find a way to build one. But I kind of found the product name funny. Made me think of this (youtube-link) song....
The attachment RocHard-RH800C.jpg is no longer available
Reply 43548 of 59011, by HanJammer
These 30-pin simm modules.
Reply 43549 of 59011, by BitWrangler
It's amazing how they got a whole 16MB in under 250W power consumption really.
Reply 43550 of 59011, by ilmazzo
Hirsch wrote on 2022-02-17, 22:47:
I haven't installed the PlexTools Professional right now. I'll check this and write an update, later. Regarding the RPC-1 Firmwa […]
ilmazzo wrote on 2022-01-18, 13:52:
Question regarding plextors.... […]
Hirsch wrote on 2022-01-05, 00:14:
Spoiler
I got these four Plextor PX-760A PATA drives today. One needed a lens cleaning. All work fine and are flashed to the latest RPC1 firmware now. This and the SATA version PX-760SA are the last drives made by Plextor. (The successors were made by various OEMs like Pioneer.)
I have a 760A too and I was looking for the firmware upgrade (if any) and plextor software to go with it, can you point me in the right direction for them? I installed plextor tools on my windows xp machine but they refused to work, can't remember the version though.
thanks!
I haven't installed the PlexTools Professional right now. I'll check this and write an update, later. Regarding the RPC-1 Firmware I can provide some information:
First of all you'll need the original firmware since it contains an executable for flashing:
https://www.firmwarehq.com/download_229-file_ … 60A107.exe.html
Download the file 760A107.exe and extract it to a folder using 7-Zip. The folder will contain 3 files:
eme_107.bin
PlexFirm.ini
PXFirm3.exe
Download 1_08Xrpc1.bin and copy it to the same folder:
http://www.oocities.org/de/linux_piewie/download/
Edit PlexFirm.ini and change entry FirmwareFileName to 1_08Xrpc1.bin.
Run PXFirm3.exe and flash the drive.
The Firmware 1_08Xrpc1.bin works on the IDE (Plextor PX-760A) and SATA (Plextor PX-760SA) version. I've done this myself and can confirm that it works. (The file name is a little bit misleading, it contains the RPC-1 patched latest firmware 1.07 for Plextor PX-760A and Plextor PX-760SA.)[/details]
Much appreciated
Reply 43551 of 59011, by imi
HanJammer wrote on 2022-03-28, 20:59:
I can already hear the plastic clips screaming 😁
Reply 43552 of 59011, by weedeewee
Wonder what computer they originally belonged to.
Could you post a better picture of the 5 chips on the back, can't quite make out all the numbers on the chips.
and...
Booo. No parity ! 😁
Do not ask Why !
Reply 43553 of 59011, by Cuttoon
dude, is that even legal?
Do those fit in many systems or were they only used for some high end special purpose like industrial machinery or some printer systems that cost as much as a small house?
I like jumpers.
Reply 43554 of 59011, by TrashPanda
Cuttoon wrote on 2022-03-28, 21:26:
They are for sure some kind of proprietary setup, never heard of the Dove Computer Corporation either.
Pretty cool looking modules, I wonder if they could be made to work in a normal board.
Reply 43556 of 59011, by HanJammer
TrashPanda wrote on 2022-03-28, 21:49:
They made alot of stuff for Apple machines. I bet these modules also were designed for some of the Apple Macintosh computers. Thanks to guys at Vintage Computer group of Facebook we figured out what's the purpose of the PAL (address decoding because chips are 1-bit) and probable use for the jumpers (selection of the chip size - because chips are actually socketed and module can be repopulated with different size of chips - I guess in the current configuration they are maxed-out at 4MB each). As for the chips on the back - they are just buffers and terminating resistors...
And yeah, they are heavy and will put strain on the sockets so it's best to use them on sockets with metal clips or the heavy duty-slot style sockets...
Reply 43558 of 59011, by Tetrium
I have seen similar SIMMs in the past, but not like this with a double row xD
Very impressive.
cyclone3d wrote on 2022-03-29, 00:32:
So you are the one that won the eBay auction.
I was kinda wanting them for the lulz.
I can imagine this for sure 🙂
Reply 43559 of 59011, by HanJammer
I will use them in some outrageous 386/486 build on my channel.
