Reply 20 of 31, by maxtherabbit
- l33t
empty ram slot? wtf is that?
paradigital wrote on 2022-05-31, 06:12:What I fail to understand is why they bothered with the DIMM pins? Power and data are provided by the SATA connectors in the corner, so why bother with the edge-connector at all?
I’d contemplated a similar idea previously, but vertical mounting for two 2.5” SSDs that you simply slot home onto connectors like the one on the corner of this device. Place a single SATA power in connector on one edge and two SATA data on the other.
the copper substrate is on the PCB anyways, it's a subtractive manufacturing process, so keeping the pins there doesn't cost anything, and the additional plating is probably negligeble too, also it's probably better for the pins if they sit against a suitable mating surface than just a bare pcb.
imi wrote on 2022-05-31, 13:42:additional plating is probably negligeble too
its very expensive
dionb wrote on 2022-05-31, 12:03:Vote for the utility of these things. Maybe it's because of my penchant for vintage cases, but I've frequently had trouble getting a 2.5" SSD properly mounted in a case, let alone any nVME thing like this. I generally have more RAM slots left than good places to stick a stick.
That said, the opposite may also be true. In that case, just don't use it 😉
The last month or so I've been working with 2 systems (one of which has sadly passed but will see if I can revive it) and several SSDs. Unfortunately the system in question was mounted in a Centurion 5 which didn't come with mounting spots for 2.5in drives and my 3.5in to 2.5in adapters I found too cumbersome as I was basically just moving some data around quickly for backup purposes and I ended up just...letting them basically hang in there xD
I still prefer older cases though. The other system is now mounted in an older Antec case (Antec NSK 4480 II) which also doesn't come with 2.5in drive bays.
For the Antec case the SSD mounted in a 2.5in to 3.5in adapter works well but I can imagine some people preferring a more secure option.
And if I were to pick an older memory type that this mounting system could be made for, I'd say the mechanically best option could be to mount it on a CRIMM since those must be used anyway if not all RIMM slots are used up.
@Sphere478, weren't there also some dual s370 boards that came with a s370 dummy in the second PGA370 socket? Get it? 😉 😉 😉 😜
imi wrote on 2022-05-31, 13:42:paradigital wrote on 2022-05-31, 06:12:What I fail to understand is why they bothered with the DIMM pins? Power and data are provided by the SATA connectors in the corner, so why bother with the edge-connector at all?
My main concern would be reliability and the preservation of the memory slot. I wouldn't want to damage or otherwise reduce-due-to-wear-and-tear the quality of the memory slot as I wouldn't want to get problems with this sometime down the line.
Though I'm wondering...wouldn't it perhaps make more sense to make M2 to 3.5in adapters so these could be mounted in traditional 3.5in drive bays? or perhaps an adapter for a 2.5in drive bay?
I've always found M2 a bit of an odd one as it doesn't seem too compelling to prefer it over 'traditional' SSD 2.5in format but it does take up more space on the PCB than a single SATA connector does.
But still I find it an interesting, though somewhat gimmicky, solution.
while you're at it, make an ISA card with a sata connector & m.2 slot. 😁
Do not ask Why !
Tetrium wrote on 2022-05-31, 16:08:Though I'm wondering...wouldn't it perhaps make more sense to make M2 to 3.5in adapters so these could be mounted in traditional 3.5in drive bays? or perhaps an adapter for a 2.5in drive bay?
those also already readily exist ^^ often for multiple M.2 at once
I like the M.2 form factor, great for a system drive to place directly on the board, and I recently replaced my external SSD with one that now has a neat "gumstick" format that is a really nice size to carry around.
TrashPanda wrote on 2022-05-31, 11:31:hmm ..I have a cup holder in my XP rig . .the lighter I dont have but I could use one !
wait ... its a cup holder right
Don’t reset 🤣
Tetrium wrote on 2022-05-31, 16:00:The last month or so I've been working with 2 systems (one of which has sadly passed but will see if I can revive it) and severa […]
For the Antec case the SSD mounted in a 2.5in to 3.5in adapter works well but I can imagine some people preferring a more secure option.And if I were to pick an older memory type that this mounting system could be made for, I'd say the mechanically best option could be to mount it on a CRIMM since those must be used anyway if not all RIMM slots are used up.
Yeah, dual socket terminators
For real? Why the gold plated edge connector if the pins are not connected to anything? I get why the adapter may be useful, just not the added expense of gold plating 😀
EDIT:
Come to think of it, why is the M2 connector perpendicular to the board? Wouldn't it be better if the drive were in the same direction of the board? Less risk of it getting knocked
debs3759 wrote on 2022-05-31, 21:37:For real? Why the gold plated edge connector if the pins are not connected to anything? I get why the adapter may be useful, just not the added expense of gold plating 😀
Already been said it is to spare the actual pins of the socket.
Do not ask Why !
Adhesive velcro pads or maybe some tie wraps would be my "solutions" for keeping an otherwise unfastened adapter PCB in place inside a case.
Is that too MacGyver-y or Red Green-ish for the fancy folks around these parts ? 😉
Get a 3D printer and print 2.5" -> 3.5" adapter 😁, for example this one printers quick and fits really well 😁.
Also helfull when printing gotek shell/case with OLED window and rotary encoder hole, among other things 👀
