First post, by AntcuFaalb
- Newbie
Does the VIA EXT-PCIG work with the VIA EPIA-800 / EPIA-5000?
I have a Wyse J400/WT941GXL (EPIA LP-10000A) which, AFAIK, is an EPIA-800 with a 1GHz Nehemiah and no TV output jacks.
At the moment I can only find the EXT-PCIG. I'd like to connect a Voodoo3 2000 as well as a USB 2.0 PCI card.
Thanks!
EDIT: I forgot to mention that I'll be putting my EPIA board in a new case.
