First post, by AntcuFaalb
Does the VIA EXT-PCIG work with the VIA EPIA-800 / EPIA-5000?
I have a Wyse J400/WT941GXL (EPIA LP-10000A) which, AFAIK, is an EPIA-800 with a 1GHz Nehemiah and no TV output jacks.
At the moment I can only find the EXT-PCIG. I'd like to connect a Voodoo3 2000 as well as a USB 2.0 PCI card.
Thanks!
EDIT: I forgot to mention that I'll be putting my EPIA board in a new case.
Reply 1 of 3, by wiretap
I use one of these in my SLI Voodoo 2 ITX rig: Electronic Product Solutions PCI-32BIT-DUAL
55.64 KiB
The motherboard I'm using is a VIA EPIA CN10000EG (VIA C7 1GHz). Might be worth trying it.
My Github
Circuit Board Repair Manuals
Reply 2 of 3, by AntcuFaalb
wiretap wrote on 2022-07-26, 19:46:
Nice, thank you!
I think I may have found the manufacturer page and documentation: http://www.morex.com.tw/products/product_view_en/123
At first it doesn't look like a match, but when you dig into the documentation it's pretty damn close.
Reply 3 of 3, by Sphere478
idk about your application but I have that riser shown in post above and it works when I have tried to use it for stuff 😀
Sphere's PCB projects.
