Adding 3.3v to pci adapter(Released)
Reply 100 of 192, by Sphere478
Can you tell me what capacitor package type you are thinking, and check me for errors please. 😀
perhaps a thru hole capacitor but attached smd? maybe a ceramic laid flat? won't get a very high value to fit without modifying the pads significantly
I was able to adjust the vsb gap btw, this will probably work.
Sphere's PCB projects.
Reply 101 of 192, by mr-spain
scheiss_freak wrote on 2022-03-08, 08:35:
Seems like I'm not eligible to send PMs yet. But I've set up a simple website to allow for easy ordering: https://recnas.org/
Please let me know if this is inappropriate and I'll remove the link asap.
I'm not sure, but I placed an order this morning if you want to verify it. I've got a project on my bench this would help immensely.
Reply 102 of 192, by mr-spain
Sphere478 wrote on 2022-08-30, 06:36:
Will you have some samples for purchase?
Reply 103 of 192, by Sphere478
The latest revision is waiting on feedback. RussD never replied.
You will just order them yourself from a pcb maker. It’s pretty easy.
Reply 104 of 192, by mr-spain
Sphere478 wrote on 2022-10-04, 02:14:
Gotcha, last one you posted?
Reply 105 of 192, by Sphere478
mr-spain wrote on 2022-10-04, 02:30:
Re: Adding 3.3v to pci (Beta)
Reply 106 of 192, by Sphere478
Edit: out of date, read farther
Here is the latest version.
3.3v PCI Converter Beta 3.14159.zip
-added gnd,
-dropped 3.3/5v pins
-removed solder jumpers
-improved labeling
-figure electrolytic can caps can be used on the existing terminals should user wish for it.
Reply 107 of 192, by mr-spain
Sphere478 wrote on 2022-10-04, 03:07:
Here is the latest version.3.3v PCI Converter Beta 3.14159.zip […]
-added gnd,
-improved labeling
That is awesome, thanks! Any particular places you reccomend for PCB work? Quick turnaround is a plus.
Reply 110 of 192, by mr-spain
Ordered. I'll update next week. (or when it gets here)
Reply 112 of 192, by mr-spain
Sphere478 wrote on 2022-10-09, 00:20:
Kapton tape would be a good idea under the contacts. If you don’t have any, order some now. 😀
I'll have some coming - this is for under the end connectors or underneath the whole pcb?
Reply 114 of 192, by mr-spain
Sphere478 wrote on 2022-10-09, 02:43:
End connection points
Perfect. I'll check it and test it on one of my boards, and I'll have some surplus if anyone here needs one. Think I have ten coming.
Reply 115 of 192, by mr-spain
yYg9rPYl.png?1
igmd1Xpl.png?1
Got the first batch back, fitment is excellent, color? Questionable! oh well it should work for what I want to do. Waiting on an Amazon package RN and will finish it up in a few hours.
Reply 116 of 192, by mr-spain
OK all wired up, checked OK, 5v tested good in the slot and went to test with my 3.3v mx420 - it gave me a post beep which it never has done before, but no output to the monitor. I'm not sure if this is a function of signaling voltage or failure to get one of the connections soldered, although they all checked ok with my meter. That's the only universal video card I have so I ordered the ubiquitous rage from amazon to test tomorrow.
Reply 117 of 192, by Sphere478
Is the mx420 that you have a card that needs 3.3v I take it? It didn’t work before in this mobo I take it?
Yeah, that rage xl cool card, That is a card in need of 3.3v for sure! Should be a good test.
Be sure you are checking for shorts thoroughly.
Reply 118 of 192, by mr-spain
Sphere478 wrote on 2022-10-12, 01:18:
Is the mx440 that you have a card that needs 3.3v I take it? It didn’t work before in this mobo I take it?
From what I can tell, it went OK as far as shorts. I checked 3.3v to ground on all of the solder connections and no connectivity, and ground were all good. I will also check for any shorts to data/io/whatever pins later.
Yep the card I have on hand (actual part number MX42064) needs 3.3v and it gave me a post beep, can see numlock activity, just no monitor output. I'll test with the Rage and then if I have no output there either start drilling down.
Reply 119 of 192, by Sphere478
What voltage are you getting on the pins that I had on the last version?
Last version had no ground taps
Had 3.3v taps and 3.3/5v taps.
We removed the 3.3/5v taps because it was assumed that those would probably be 5v anyway. And it would just be a pointless feature.
Did you bridge the 3.3vsb tap?
