First post, by MaverickUK
The HDD Clicker sounds like a fantastic idea.
However it got it thinking, would it be possible to simulate more of the experience? Such as the sound of a mechanical hard drive spinning up and more realistic access sounds?
After wrangling some CircuitPython code with a spare Raspberry Pi Pico & Pico Audio I had my answer:
YouTube video of the device in action
How it works
There are three WAV files on the Raspberry Pi Pico
  • Spin up
  • Idling
  • Disk access
When the Raspberry Pi Pico retrieve power it starts by playing the spin up WAV file. Once this is complete it will continuously loop the idling WAV file. When
HDD activity is detected it then switches to looping the disk access WAV file.
HDD activity is detected by using the analogue inputs on the Pico, so that when a PCs HDD LED lights up it detects the voltage and will then play the disk access sound.
I have also programmed it to output 3.3V on another set of Pico pins when HDD access is detected, which can be used to connect up to the PCs HDD LED should the original connection be disconnected
Next steps
I won't be able to progress this until the weekends (due to work/family life), but the next step is to fit this into an actual PC to prove that it works. Once that's complete I'll make any refinements required then I'll release the full source code and parts list.
If you'd be interested in a prebuilt device let me know so I can determine if it's worthwhile me assembling a set for sale.
Cheers
Peter
http://www.strifestreams.com
Reply 1 of 58, by myretropast
That’s very cool, I was wondering if a Pi Pico could be used for something like this. My initial thoughts were to use a Pico to run an OLED panel showing HDD activity and Turbo status, a bit overkill, but if it can also do the audio then that would be a nice little add on.
Reply 2 of 58, by keropi
make spinning sounds loud again! 🤣
nice project! not sure about using the spinning sound looping in the background but the head sounds are very nice!
Reply 3 of 58, by MaverickUK
I'm planning to make it very configurable so that anyone using this can easily change the HDD samples it uses or change other aspects. As from the comments on the video so far it's clear that everyone has their own preferences in this arena 😀
I've successfully tested it in my 386 and it was able to detect HDD LED activity to act as a trigger and then relay a signal to the PCs case HDD LED
Pico%20HDD%20Synth%20testing.jpeg?raw=1
I'm waiting for some additional parts to arrive from Pimoroni (small speaker, mount, jumper cables) along with a few eBay purchases (Molox to USB power & 3.5mm audio jacks). Once these arrive I'll clean up the prototype so it's more "production" ready.
Reply 4 of 58, by MaverickUK
I've decided to address both the mounting and power problems with a single solution, that being making use of a ISA board as shown in the image below
HDD%20Synth%20ISA.jpeg?raw=1
Thanks to Martin Niec at https://www.ebay.co.uk/itm/284508460587 for these superb prototyping ISA PCBs
These provide 5v and ground connections through the ISA bus.
I've also purchased a new CompactFlash to IDE adapter and replaced the HDD LED with a connector so that I can link it to the PCB, rather than take it from the motherboard. This means that a passthrough approach isn't required and the PC can continue to drive the case indicator LEDs as normal. However I've also programmed the Pico to provide a replacement HDD LED output for those who wish to wire up their PC this way.
Once I've wired up the ISA board I'll post a new video of it in operation.
Finally a thanks to Ian Scott of PicoGUS fame https://github.com/polpo/picogus who has kindly shared his knowledge about interfacing with a Pi Pico over the ISA bus. For a future revision of this device it may be possible to detect HDD activity purely from the ISA bus within some systems.
I also like the idea of writing a utility that can talk with the Pico over the ISA bus to allow for configuration to be performed directly on the PC itself. Although that's really for a version 2 of this device, but it's nice to have idea for the future.
Reply 5 of 58, by dlxmax
Great project--what's the status?
Reply 6 of 58, by MaverickUK
This project has on ice for a few years, due to events in my life. I'm happy to say that I've now resumed work
After some advice from Ian Scott of PicoGUS fame I've been investigating detecting HDD activity directly from the ISA bus, so that this becomes a plug and play device.
I purchased several TXS0108E level shifters to translate the ISA bus 5v to a safe 3.3v for the Pi Pico and wired up a breadboard to the A0 - A9 address lines along with IOR and IOW
img_8250.jpg?width=1000&v=1dc09cc8f245962
After several wiring checks I felt brave enough to actually try it in my computer.
The following video demonstrates what happened on that first attempt!
https://youtu.be/V8H3NL-J_68?si=Dbhm6iBzVk_Q1NyU
Reply 7 of 58, by MaverickUK
After posting the previous video I found that one of the level shifters was faultly along with the next replacement I then used!
What followed was an exercise manually testing each of the ISA lines on the bench to validate the chips and lines were all working
img_8271.jpg?rmode=max&width=800&v=1dc09faca929e7d
img_8272.jpg?rmode=max&width=800&v=1dc09faca896fc7
Thankfully after all this I was able to return to my 386 PC and after adding in some additional code to ensure HDD activity only triggers after activity reaches a certain threshold. Although some finessing is still required, I'm proud to say that this is a successful proof of concept. HDD activity is being successfully captured by the Pico.
A video of this working is available from https://youtu.be/Tan_0qBtJHs
Reply 8 of 58, by MaverickUK
I've been continuing to prototype aspects of the project such as loading audio samples from an SD card so that it'll be easier for users to change the samples
I'm waiting for an Adafruit I2S MAX98357A to arrive to determine if that's an acceptable and cheaper audio out than the Pico Audio Pack i've used so far
Today I've been starting to create the prototype PCB so that I can create some units to send out to people who would like to help me test and refine the device
img_8619.jpg?rxy=0.6340852130325815,0.5958429715599888&width=1000&v=1dc11f273f5f2de
There are still some components to be placed on the PCB, so this is a work in progress.
I did however start to price up 20 x PCBs with the SMD components pre-assembled which came to about $60.
Before I go ahead and place the order with PCBWay would someone be able to validate my designs to ensure I've not made any fatal mistakes. This is my first time with KiCad and PCBWay
Reply 9 of 58, by MaverickUK
PCB design for the initial prototype is complete and sent off to PCBWay for manufacture.
To keep things are simple as possible for the initial I've changed all the components to be through hole. I'll move to surface mount and a more compact design to the final design.
screenshot-2025-08-24-at-140517.png?width=1000&v=1dc14f7d0f453e9
screenshot-2025-08-24-at-140452.png?width=1000&v=1dc14f7d121c8bb
Reply 10 of 58, by MaverickUK
img_8689.jpg?width=1000&v=1dc18c6957b6e72
The first batch of prototype PCBs arrived this morning
img_8695.jpg?width=1000&v=1dc18c6959817ec
A sanity check of the components shows that they all fit their through hole mounts, which is a good start
Next up I'll perform a continouity check on the traces before soldering in the sockets and then testing the PCB using my bench power supply before I get anywhere near putting it into my PC
Reply 11 of 58, by ott
Сool idea!
How about spin down after shutdown?
I think a medium capacitor/small battery would be enough to play this sound.
Reply 12 of 58, by MaverickUK
Good thinking ott 😀
I've ordered a few 5.5V 1.5F super capacitors to test exactly this idea out
In theory if I connect them in parrallel to the 5v ISA rail which goes to the Pi Pico VSYS input with a 22 ohm resistor to prevent a sudden load, once charged up it should provide enough power to power all the components after the PC is turned off. The Schottky rectifier diode that is already part of the design will stop the voltage going back into the PC, so it'll only get used on the HDD Synth.
img_8701.jpg?rmode=max&width=500&v=1dc18f5fd506d48
I've bought a quality Eaton brand for this proof of concept work which is quite expensive at around £7
Reply 13 of 58, by dreamblaster
wohoooo
New X2GS TE & X16GS sound card : https://www.serdashop.com/X2GS-TE ,
Thanks for your support !
Reply 14 of 58, by ott
MaverickUK wrote on 2025-08-29, 15:09:
Sorry, I didn't think about powering the capacitor. It's not a trivial task in terms of all kinds of protection.
Please be careful, I've seen bad consequences from a faulty diode/capacitor.
It might be worth considering external power supply from USB-C.
Reply 15 of 58, by MaverickUK
img_8702.jpg?width=1000&v=1dc3a97c90bda32
Behold, the fully assembled HDD Synth
Unfortunately some bodge wiring was required...
img_8759.jpg?width=1000&v=1dc3a97c8f249ac
Long story short, I've decided to take a slightly different route for the MK2 prototype. The full reasons are explained at https://www.strifestreams.com/articles/2025/a … -mk1-prototype/
The next prototype board won't detect HDD activity through the ISA bus and instead will use a direct detection from the HDD LED. It'll still use the ISA card form so that it can draw power and for ease for installation, but I'm planning to make it only use the 8bit ISA slot connector to small it smaller.
I'll likely revisit ISA bus HDD detection again in the future, as I really like the idea of a true plug and play device. However, for the moment this allow me to focus on getting a true MVP developed and released. Ideally in time for Christmas! At least, that's the deadline I'm setting for myself as motivation.
Reply 16 of 58, by MaverickUK
The HDD Synth MKII PCBs has arrived this morning
With some easter eggs on the back 😀
Next steps, get the components attached and then testing can begin
Reply 17 of 58, by sydres
One question? Can it recreate the sound of a Quantum Bigfoot seeking over bad sectors? Or crashing heads? Just kidding!
Reply 18 of 58, by crusher
Very cool product! 😀
I like the idea having this solution as an ISA card.
Reply 19 of 58, by MaverickUK
sydres wrote on 2026-01-13, 22:42:
I really like this idea 😁
I've made a note on my feature list to add a health setting that will allow a user to determine how likely such an event would be
I'd really like to replicate the full physical HDD experience, so why not!
