Reply 1640 of 2402, by CoffeeOne
pshipkov wrote on 2023-01-21, 18:56:Decided to consolidate the captured performance metrics for all tested motherboards. Goal is to improve consistency and readabil […]
Goal is to improve consistency and readability.
Data will be split in few separate posts based on hardware class - 286, 386, 486 (160/180/200MHz).
The original posts will be edited accordingly.
Starting with 486 class motherboards at 160MHz.
(charts will be updated if new items get examined later)486 class motherboards with AMD Am5x86 processor running at 160MHz (4x40)
Hi again,
I must say I am really surprised a little bit by your values.
I always have lower values, also when I seem to use identical hardware
for example
Asus SVGOX4 Rev.1.2 160MHz 1MB L2, all timinings best except DRAM burst disabled.
VLB Ark 1000VL 1MB
some dos bench marks:
Wolf 3D: 142.4
Doom max: 65.1
PCP 640x480: 10.9
Quake 640x480: 18.1 (Here you have 18.8 just as an example).
So not even in DOS I come close 😁. Does the DOS version play a role??? I used the one from Windows 98SE.
I keep trying, will upgrade the ARK to 2MB (but I don't think that makes a difference for DOS)
Then I will compare the valued with the ones of a SV2GX4 Rev.2.0 (where this "DRAM write burst" can be also enabled, but again, I also doubt that makes a difference)
Then I will try different CPUs. Can this make a difference? I also doubt it.
