First post, by kixs
- l33t
After many years of delaying... now is the time for the second round of 286 to the Max 😁
Link to the first 286 to the Max thread Kixs's 286 to the Max
System info/config:
Motherboard: Octek Fox II Rev 3.4 with Harris 80286-20; HT12/a chipset
FPU: Cyrix 287XL+
Memory: 2x 1MB 60ns SIMM runs with 0-wait states
VGA: Tseng ET4000AX ISA
Oscillator clock: 58MHz == CPU@29Mhz
At this speed some active cooling is required. I used 12cm case fan to cool the motherboard in area of memory and CPU. Without it there were instabilities - warm room temperature doesn't help (26 degC).
I actually run out of incremental oscillators. After 58MHz I only have 66Mhz. My guess is the 60Mhz should still work fine.
Anyways... to the benchmarks... Text version first in case of photos disappearing...
Norton System Information: 22.8
Landmark System Speed Test 6.00: CPU: 45.90 | FPU: 37.68
Checkit 3.0: Dhrystones: 7533 | Whetstones: 999.9K
NSSI: Dhrystones: 7315 | Whetstones: 1112K
Comptest 2.60: Max MEM: 14068 KB/s | Drys. 7862.9 | Whetstones: 721.4K
PMIPS: 4.7
Celem Cache Test: 763 (lower is better)
Dr. Hardware 3.7: Hardstones: 6813 | Softstones: 1004 | RAM: 14.09MB/s | Bus: 5.15MB/s
3DBENCH 1.0: 12.0
WOLF3D Bench: 19.8
To do:
run other benchmarks
try other FPUs
try other VGA cards
get faster oscillators 😉
try to mod other motherboards with socket for easy replacing oscillator
Visit my AmiBay items for sale (updated: 2025-10-29). I also take requests 😉
