Reply 520 of 2973, by RaVeN-05
Pre-entry (Int 15h)(Call 1) AX 0000, BX BFDE, CX 0008, DX 035F, ES 15E6, DI 0006, DS 1620 SI 0000, SP 0FD4, FLAGS 7246
On exit (2) AX 8600, BX BFDE, CX 0008, DX 035F, ES 15E6, DI 0006, DS 1620, SI 0000, SP 0FD4, FLAGS 7A83
Pre-entry (Int 15h)(Call 2) AX 0000, BX BF01, CX 11C0, DX 0011, ES 15E6, DI 0006, DS 1620 SI 0000, SP 0FD4, FLAGS 7246
On exit (2) AX 8600, BX BF01, CX 11C0, DX 0011, ES 15E6, DI 0006, DS 1620, SI 0000, SP 0FD4, FLAGS 7A83
Pre-entry (Int 10h)(1) AX 158D, BX 0000, CX 0000, DX 0000, ES 15E6, DI 0006, DS 1620 SI 0000, SP 0FD4, FLAGS 7246
On exit (2) AX 0015, BX 0000, CX 0A2C, DX C000, ES 15E6, DI 0006, DS 1620, SI 0000, SP 0FD4, FLAGS 7246
Rendition Segment 0000C000, Rendition Base 00000A2C
Pre-entry (Int 1ah)(1) AX B101, BX 0000, CX C000, DX 0A2C, ES 15E6, DI 0006, DS 1620 SI 0000, SP 0FD4, FLAGS 7246
Int 1ah on exit (2) AX 0011, BX 0210, CX C001, DX 4350, ES 15E6, DI 0006, DS 1620, SI 0000, SP 0FD4, flags 7246
Searching for Rendition Verite V1000
Pre-entry (Int 1ah/vQuake) (1) AX B102, BX 0000, CX 0001, DX 1163, ES 15E6, DI 0006, DS 1620 SI 0000, SP 0FD4, FLAGS 7246
Int 1ah on exit (2) AX 8602, BX 0201, CX 0001, DX 1163, ES 15E6, DI 0006, DS 1620, SI 0000, SP 0FD4, flags 7247
Not found
Searching for Rendition Verite V2000
Pre-entry (Int 1ah/vQuake) (1) AX B102, BX 0000, CX 2000, DX 1163, ES 15E6, DI 0006, DS 1620 SI 0000, SP 0FD4, FLAGS 7246
Int 1ah on exit (2) AX 0002, BX 0100, CX 2000, DX 1163, ES 15E6, DI 0006, DS 1620, SI 0000, SP 0FD4, flags 7246
Found V2000 bus # 1, dev num 0
Pre-entry (Register read) (1) AX B108, BX 0100, CX 0000, DX 0000, ES 15E6, DI 000B, DS 1620 SI 0000, SP 0FD4, FLAGS 7216
Int 1ah on exit (2) AX 0008, BX 0100, CX 0003, DX 0000, ES 15E6, DI 000B, DS 1620, SI 0000, SP 0FD4, flags 7216
Read register[000B] = 03*****************************************************************************
Pre-entry (Register read) (1) AX B108, BX 0100, CX 1620, DX 0000, ES 15E6, DI 0013, DS 1620 SI 0000, SP 0FD4, FLAGS 7246
Int 1ah on exit (2) AX 0008, BX 0100, CX 16DE, DX 0000, ES 15E6, DI 0013, DS 1620, SI 0000, SP 0FD4, flags 7246
Read register[0013] = DE*****************************************************************************
Pre-entry (Register read) (1) AX B108, BX 0100, CX 1620, DX 0000, ES 15E6, DI 0015, DS 1620 SI 0000, SP 0FD4, FLAGS 7246
Int 1ah on exit (2) AX 0008, BX 0100, CX 16D0, DX 0000, ES 15E6, DI 0015, DS 1620, SI 0000, SP 0FD4, flags 7246
Read register[0015] = D0*****************************************************************************
Pre-entry (Register read) (1) AX B108, BX 0100, CX 1620, DX 0000, ES 15E6, DI 003C, DS 1620 SI 0000, SP 0FD4, FLAGS 7246
Int 1ah on exit (2) AX 0008, BX 0100, CX 160B, DX 0000, ES 15E6, DI 003C, DS 1620, SI 0000, SP 0FD4, flags 7246
Read register[003C] = 0B*****************************************************************************
Pre-entry (Register read) (1) AX B108, BX 0100, CX 1620, DX 0000, ES 15E6, DI 0004, DS 1620 SI 0000, SP 0FD4, FLAGS 7246
Int 1ah on exit (2) AX 0008, BX 0100, CX 1607, DX 0000, ES 15E6, DI 0004, DS 1620, SI 0000, SP 0FD4, flags 7246
Read register[0004] = 07*****************************************************************************
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 521 of 2973, by sharangad
Thanks Agent. Hopefully the reg values should be the same as a V2000. Even if they're not the V1000 values are the ones that're going to be used, since Speedy3d works best on V1000.
I'll be plugging these into my dosbox test harness soon.
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready?utm_medium=unknown … ontent=copyLink
Reply 522 of 2973, by sharangad
I think values 2 and 3 are the io port numbers (16 bit when combined) . I have the RTEST values from before so I'll check in a bit.
Thanks Raven.
Reply 523 of 2973, by sharangad
Raven from your RTEST resukts:
Board # 1
Verite ID 0x2000
IoBase 0xd000
MemBase 0xde000000
MemMappedIoBase 0xdd000000
memSize 4194304
IOBase 0xd000
BusMaster 0x1
VGA Device 0x1
0xde and oxd0 are the upper bytes of mem base and io base.
Reply 524 of 2973, by sharangad
Agent could you run RTEST. Exe from Windows on your V1000 and post the results? I can't find it in this thread.
RTEST is available here:
https://1drv.ms/u/s!As-dKk-N73dSlmafg4OhhQ3_osXs?e=N7TkT8
Your membase should be E8000000 and iobase should be e100 (maybe swapped)
Reply 525 of 2973, by sharangad
No need, I think this is your result:
Board # 1
Verite ID 0x1
IoBase 0xe800
MemBase 0xe1000000
MemMappedIoBase 0x0
memSize 4194304
IOBase 0xe800
BusMaster 0x1
VGA Device 0x1
Press [ENTER] to close
Reply 526 of 2973, by sharangad
See if this runs or locks up. I also needs the VESABlock.txt file, if it exits
https://1drv.ms/f/s!As-dKk-N73dSlkAMo-Zu9Ad0nTvO
MD5: f76b9bfffb6770ff3291fd66adba1ecc
Reply 527 of 2973, by Agent of the BSoD
That link doesn't go to a file.
Pentium MMX 233 | 64MB | FIC PA-2013 | Matrox Mystique 220 | SB Pro 2 | Music Quest MPU Clone | Windows 95B
MT-32 | SC-55mkII, 88Pro, 8820 | SB16 CT2230
3DFX Voodoo 1&2 | S3 ViRGE GX2 | PowerVR PCX1&2 | Rendition Vérité V1000 | ATI 3D Rage Pro
Reply 529 of 2973, by Agent of the BSoD
Complete lockup. No text is ever saved to a text file.
Reply 531 of 2973, by sharangad
https://1drv.ms/u/s!As-dKk-N73dSmBoMo-Zu9Ad0nTvO
MD5: 4fd08746b7e156ba9b652bc3f1e8bee4
That should do it. It takes a bit of adjusting to get used to FP_SEG and FP_OFF and MAKE_FP. I haven't used those in decades.
[EDIT] Needs the VESABLOC.txt file as well as setmode output.
Reply 534 of 2973, by RaVeN-05
what do you think? about Whiplash in configuration menu has switch between 4meg and probably 8meg as chat told me on stream, but 8mb is not even show, i think this can be confusion since Speedy3D first introduced in v1000 and v1000 probably newer has 8mb?
Reply 536 of 2973, by sharangad
RaVeN-05 wrote on 2024-03-04, 10:45:
I think they planned to support cards with more RAM as a forward thinking feature., but that option's probably hidden unless the card actually has 8 MB of RAM.
Reply 538 of 2973, by sharangad
Last one for today:
https://1drv.ms/u/s!As-dKk-N73dSmBwMo-Zu9Ad0nTvO
MD5: 76458c5015981fc931b33dae940efd2c
This doesn't do anything new, just fixes bugs. It would be nice to get results from a V1000 as well as a V2000.
I've ported some of the VESA info into DOSbox. At some point I'll have to create the project on sourceforge. But not just yet.
