Copy code to clipboard 1 ***************************************************************************** 2 Pre-entry (Int 15h)(Call 1) AX 0000, BX BFDE, CX 0008, DX 035F, ES 15E6, DI 0006, DS 1620 SI 0000, SP 0FD4, FLAGS 7246 3 On exit (2) AX 8600, BX BFDE, CX 0008, DX 035F, ES 15E6, DI 0006, DS 1620, SI 0000, SP 0FD4, FLAGS 7A83 4 ***************************************************************************** 5 ***************************************************************************** 6 Pre-entry (Int 15h)(Call 2) AX 0000, BX BF01, CX 11C0, DX 0011, ES 15E6, DI 0006, DS 1620 SI 0000, SP 0FD4, FLAGS 7246 7 On exit (2) AX 8600, BX BF01, CX 11C0, DX 0011, ES 15E6, DI 0006, DS 1620, SI 0000, SP 0FD4, FLAGS 7A83 8 ***************************************************************************** 9 ***************************************************************************** 10 Pre-entry (Int 10h)(1) AX 158D, BX 0000, CX 0000, DX 0000, ES 15E6, DI 0006, DS 1620 SI 0000, SP 0FD4, FLAGS 7246 11 On exit (2) AX 0015, BX 0000, CX 0A2C, DX C000, ES 15E6, DI 0006, DS 1620, SI 0000, SP 0FD4, FLAGS 7246 12 ***************************************************************************** 13 Rendition Segment 0000C000, Rendition Base 00000A2C 14 Pre-entry (Int 1ah)(1) AX B101, BX 0000, CX C000, DX 0A2C, ES 15E6, DI 0006, DS 1620 SI 0000, SP 0FD4, FLAGS 7246 15 Int 1ah on exit (2) AX 0011, BX 0210, CX C001, DX 4350, ES 15E6, DI 0006, DS 1620, SI 0000, SP 0FD4, flags 7246 16 ***************************************************************************** 17 Searching for Rendition Verite V1000 18 Pre-entry (Int 1ah/vQuake) (1) AX B102, BX 0000, CX 0001, DX 1163, ES 15E6, DI 0006, DS 1620 SI 0000, SP 0FD4, FLAGS 7246 19 Int 1ah on exit (2) AX 8602, BX 0201, CX 0001, DX 1163, ES 15E6, DI 0006, DS 1620, SI 0000, SP 0FD4, flags 7247 20 ***************************************************************************** 21 Not found 22 Searching for Rendition Verite V2000 23 Pre-entry (Int 1ah/vQuake) (1) AX B102, BX 0000, CX 2000, DX 1163, ES 15E6, DI 0006, DS 1620 SI 0000, SP 0FD4, FLAGS 7246 24 Int 1ah on exit (2) AX 0002, BX 0100, CX 2000, DX 1163, ES 15E6, DI 0006, DS 1620, SI 0000, SP 0FD4, flags 7246 25 ***************************************************************************** 26 Found V2000 bus # 1, dev num 0 27 Pre-entry (Register read) (1) AX B108, BX 0100, CX 0000, DX 0000, ES 15E6, DI 000B, DS 1620 SI 0000, SP 0FD4, FLAGS 7216 28 Int 1ah on exit (2) AX 0008, BX 0100, CX 0003, DX 0000, ES 15E6, DI 000B, DS 1620, SI 0000, SP 0FD4, flags 7216 29 Read register[000B] = 03***************************************************************************** 30 Pre-entry (Register read) (1) AX B108, BX 0100, CX 1620, DX 0000, ES 15E6, DI 0013, DS 1620 SI 0000, SP 0FD4, FLAGS 7246 31 Int 1ah on exit (2) AX 0008, BX 0100, CX 16DE, DX 0000, ES 15E6, DI 0013, DS 1620, SI 0000, SP 0FD4, flags 7246 32 Read register[0013] = DE***************************************************************************** 33 Pre-entry (Register read) (1) AX B108, BX 0100, CX 1620, DX 0000, ES 15E6, DI 0015, DS 1620 SI 0000, SP 0FD4, FLAGS 7246 34 Int 1ah on exit (2) AX 0008, BX 0100, CX 16D0, DX 0000, ES 15E6, DI 0015, DS 1620, SI 0000, SP 0FD4, flags 7246 35 Read register[0015] = D0***************************************************************************** 36 Pre-entry (Register read) (1) AX B108, BX 0100, CX 1620, DX 0000, ES 15E6, DI 003C, DS 1620 SI 0000, SP 0FD4, FLAGS 7246 37 Int 1ah on exit (2) AX 0008, BX 0100, CX 160B, DX 0000, ES 15E6, DI 003C, DS 1620, SI 0000, SP 0FD4, flags 7246 38 Read register[003C] = 0B***************************************************************************** 39 Pre-entry (Register read) (1) AX B108, BX 0100, CX 1620, DX 0000, ES 15E6, DI 0004, DS 1620 SI 0000, SP 0FD4, FLAGS 7246 40 Int 1ah on exit (2) AX 0008, BX 0100, CX 1607, DX 0000, ES 15E6, DI 0004, DS 1620, SI 0000, SP 0FD4, flags 7246 41 Read register[0004] = 07*****************************************************************************
