Reply 820 of 1544, by sharangad
- Oldbie
This should correct RRide3 render to texture issues. It should also correct vHexen2 AA when the screen size is shrunk(default)., i.e. coming out of the water with high underwater resolutions shouldn't leave AA remnants behind. Same with Raven-05 RR2/RR3 demos:
https://1drv.ms/u/s!As-dKk-N73dSmFtO3jlrk5msCogo?e=rczUPf
MD5: eea6f5404c1ca215eb44bf2783c473bc
It does not contain any Speedy3D code.
[EDIT]R3 does not work.
Yet.[/EDIT]
[EDIT 2] This is an untested release.
https://www.youtube.com/@sharangadayananda
