Reply 1440 of 1733, by robertmo3
does that link work for you?
you can attach it to your post on vogons 😀
5 000 000 bytes limit to a file, 5 files limit to a post
you are safe with first limit 😉
https://www.youtube.com/@sharangadayananda
i guess cause you are logged in, try from being logged out, anyway you are different location which may be a reason too.
still doesn't work for me
OK. I attached it.
ok, works in a different browser
https://1drv.ms/u/c/5277ef8d4f2a9dcf/EfF6GTmY … bjUQ9g?e=iMLlOe
Try this. Might be a onedrive outage.
had to clear browser's history and it worked
OK, does the mouse work in Rm and RMR?
mouse is ok now in rmc too 😉
robertmo3 wrote on 2024-05-11, 15:32:mouse is ok now in rmc too 😉
Great! Rmc or RMR?
rmcgl(rmc), rmverite(rmv) and rmrising(rmr) 😀
robertmo3 wrote on 2024-05-11, 16:01:rmcgl, rmverite and rmrising 😀
That's a hattrick!
I'm still trying to fix the stability problem.
I take it you've had and continue to have many unexplained crashes?
@robertmo3
Can see if this lowers your CPU load down to 2 cores?
https://1drv.ms/u/c/5277ef8d4f2a9dcf/Ef2bqgIt … SH5MzQ?e=gowdd6
MD5: 7c665d208a99fda540241d3e6a4cc7bc
If you could check ICR2 for 30 fps and Whiplash (both in DMA mode) for 60 fps or higher.
The central mirror in ICR2/Cart2 can be turned on by setting mirror=1 in rendition.cfg (not dosbox-rendition.cfg).
nothing has changed on 4 cores
robertmo3 wrote on 2024-05-11, 20:37:nothing has changed on 4 cores
Aaaargh!
all games work on 2 cores
figured out how to make whiplash game work
How?
i already know but want to reproduce it in many situations to figure out for sure
what else may be exactly affecting that
robertmo3 wrote on 2024-05-12, 05:07:i already know but want to reproduce it in many situations to figure out for sure
I'm profiling the code right now. The profile claims there're lots of sleep(0) (spin time), but they only occur when the threads are idle.
