Reply 1440 of 3175, by robertmo3
does that link work for you?
Reply 1441 of 3175, by robertmo3
you can attach it to your post on vogons 😀
5 000 000 bytes limit to a file, 5 files limit to a post
you are safe with first limit 😉
Reply 1443 of 3175, by robertmo3
i guess cause you are logged in, try from being logged out, anyway you are different location which may be a reason too.
still doesn't work for me
Reply 1445 of 3175, by robertmo3
ok, works in a different browser
Reply 1447 of 3175, by robertmo3
had to clear browser's history and it worked
Reply 1449 of 3175, by robertmo3
mouse is ok now in rmc too 😉
Reply 1451 of 3175, by robertmo3
rmcgl(rmc), rmverite(rmv) and rmrising(rmr) 😀
Reply 1452 of 3175, by sharangad
robertmo3 wrote on 2024-05-11, 16:01:
rmcgl, rmverite and rmrising 😀
That's a hattrick!
I'm still trying to fix the stability problem.
I take it you've had and continue to have many unexplained crashes?
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 1453 of 3175, by sharangad
@robertmo3
Can see if this lowers your CPU load down to 2 cores?
https://1drv.ms/u/c/5277ef8d4f2a9dcf/Ef2bqgIt … SH5MzQ?e=gowdd6
MD5: 7c665d208a99fda540241d3e6a4cc7bc
If you could check ICR2 for 30 fps and Whiplash (both in DMA mode) for 60 fps or higher.
The central mirror in ICR2/Cart2 can be turned on by setting mirror=1 in rendition.cfg (not dosbox-rendition.cfg).
Reply 1454 of 3175, by robertmo3
nothing has changed on 4 cores
Reply 1456 of 3175, by robertmo3
all games work on 2 cores
figured out how to make whiplash game work
Reply 1458 of 3175, by robertmo3
i already know but want to reproduce it in many situations to figure out for sure
what else may be exactly affecting that
Reply 1459 of 3175, by sharangad
robertmo3 wrote on 2024-05-12, 05:07:
I'm profiling the code right now. The profile claims there're lots of sleep(0) (spin time), but they only occur when the threads are idle.
