GeForce 2 Coolers
First post, by bytesaber
Is there any modern advise for how to replace coolers for old cards, such as Geforce2? I have a Geforce2 TI AGP, that is very flat with it's cooler, and does not touch the PCI slot directly next below it.
Two "problems". The fan is a bit unusual, sunken into the flat heatsink, and is rattling. The other problem, is that it's even noisier blowing against the neighboring PCI card, directly almost against it. ASUS CUBX-E.
I am not certain if it's good to have a neighboring PCI card right up against it, but I would like to for having more cards in the system. I can get over that if I must and remove a card. Either way, it's very noisy but cooling does work. I am wondering if I could look into an alternative, if such an idea exists.
I do have some replacement coolers on hand, from around 15 years ago. But they would make the card thicker and encroach on the PCI slot below the AGP slot. I could decide to do this, but wanted to ask for any ideas.
Thank you
-=kreg
Reply 1 of 4, by Pino
You can find vga cooler of pretty much any size you can image on ebay, just measure the distance between pins and do a quick search.
A Geforce 2 shouldn't need anything fancy, anything modern and a fresh thermal paste will be good as new.
Reply 2 of 4, by The Serpent Rider
ZALMAN VF700 "flower" cooler knock-offs should suffice, if you're willing to sacrifice the second slot beside AGP.
Reply 3 of 4, by bytesaber
Thank you for the Zalman suggestion. I will check that too.
Here is my card, and what appears to be the same coolers found on ebay. I'll start here.
The attachment PXL_20240511_182333371.jpg is no longer available
The attachment PXL_20240511_182340055.jpg is no longer available
Ebay listing
The attachment Screenshot_20240511-121115.png is no longer available
https://www.ebay.com/itm/402590410780
Reply 4 of 4, by The Serpent Rider
Keep in mind that they aren't really good for cooling and most likely in bad state anyway.
