First post, by bytesaber
Is there any modern advise for how to replace coolers for old cards, such as Geforce2? I have a Geforce2 TI AGP, that is very flat with it's cooler, and does not touch the PCI slot directly next below it.
Two "problems". The fan is a bit unusual, sunken into the flat heatsink, and is rattling. The other problem, is that it's even noisier blowing against the neighboring PCI card, directly almost against it. ASUS CUBX-E.
I am not certain if it's good to have a neighboring PCI card right up against it, but I would like to for having more cards in the system. I can get over that if I must and remove a card. Either way, it's very noisy but cooling does work. I am wondering if I could look into an alternative, if such an idea exists.
I do have some replacement coolers on hand, from around 15 years ago. But they would make the card thicker and encroach on the PCI slot below the AGP slot. I could decide to do this, but wanted to ask for any ideas.
Thank you
-=kreg
Reply 1 of 4, by Pino
You can find vga cooler of pretty much any size you can image on ebay, just measure the distance between pins and do a quick search.
A Geforce 2 shouldn't need anything fancy, anything modern and a fresh thermal paste will be good as new.
Reply 2 of 4, by The Serpent Rider
ZALMAN VF700 "flower" cooler knock-offs should suffice, if you're willing to sacrifice the second slot beside AGP.
Reply 3 of 4, by bytesaber
Thank you for the Zalman suggestion. I will check that too.
Here is my card, and what appears to be the same coolers found on ebay. I'll start here.
1.81 MiB
1.43 MiB
Ebay listing
922.63 KiB
https://www.ebay.com/itm/402590410780
Reply 4 of 4, by The Serpent Rider
Keep in mind that they aren't really good for cooling and most likely in bad state anyway.
