First post, by Berzerkula
- Newbie
Greetings,
ALTERA LP6 and 386 with NT 3.51 and MAX+PLUS II 9.32
I've found an Altera LP6 ISA device, some MAX5000 and MAX7000 series programming modules. I installed some software and the main point is the hardware. If anyone needs help in programming some old Altera devices, I may have what is required. Letting the community know, and there is still someone around who can perform the task. The pictures limit what I have acquired. I've installed NT 3.51 with a 386 machine and all is working well.
Sincerely,
William
You feel a whole lot more like you do now than you did when you used to.
