Reply 53500 of 59730, by myne
zuldan wrote on 2024-07-07, 20:50:
AGP4LIfe? wrote on 2024-07-07, 01:53:
Found this magnificently ugly beautiful beast at thrift center for 15$, CPU's included!! You think it will post?? 😁
The attachment PXL_20240707_014812951~3.jpg is no longer available
Did it post?
I'd be running that through the dishwasher without soap before attacking it with a toothbrush.
Ideally, ultrasonic bath. Most half decent electronic repair shops will have one and will probably let you use it free/cheap
I built:
Reply 53501 of 59730, by Ensign Nemo
myne wrote on 2024-07-08, 01:47:
Did it post?
Are you not concerned over the toxins from the motherboard leaching off into your dishwasher? Circuit boards have some nasty stuff in them. I wouldn't want to have those come into contact with stuff I eat from.
Reply 53502 of 59730, by luckybob
Ensign Nemo wrote on 2024-07-08, 01:50:
no. your dishwasher should fully drain, every time its used.
Worst case scenario - run the machine empty with a machine cleaner.
Reply 53503 of 59730, by Ensign Nemo
luckybob wrote on 2024-07-08, 01:55:
I understand that the dishwasher would drain fully and that the water would dilute the pollutants. However, draining alone won't necessarily mean that any toxin is no longer present. Having hard water will show that some stuff can get left behind and that's just stuff you can see afterwards. Still, it's probably a good idea to run the dishwasher without any utensils or dishes if you are going to put electronics in there.
Reply 53504 of 59730, by myne
Uh, I thought that last bit went without saying.
I did say no soap.
I built:
Reply 53505 of 59730, by AGP4LIfe?
myne wrote on 2024-07-08, 02:15:
I did say no soap.
I am 100% not familiar with the dishwasher method, but that scares the heck outta me. Your saying dish-washing the motherboard is not only, not bad for it, but is actually a good way to clean it??!
Who decides what truth is, and what is their objective? Today’s falseness can reappear as tomorrow’s truth.
Reply 53506 of 59730, by myne
Done it many times. Gpus and motherboards
Never made anything worse. Revived several.
It's just hot water.
Sure, hard water can potentially be an issue, and it's not as ideal as the factory distilled water, but that can be mitigated by rinsing in isopropyl if you're paranoid.
I built:
Reply 53507 of 59730, by rasz_pl
No soap as in bar soap, but detergents are normal stuff in industrial applications (cleaning pcbs).
Reply 53508 of 59730, by pan069
myne wrote on 2024-07-08, 03:05:
Done it many times. Gpus and motherboards Never made anything worse. Revived several. It's just hot water. Sure, hard water can […]
I think the problem with (some) dishwashers is that they reuse water from a previous cycle as a way to conserve water. I.e. if your dishwasher does and you wash electronics in the dishwasher, then a) first your electronics will be washed in water from a previous cycle (not sure of that matters) and b) your next cycle, maybe the plates and cutlery you eat from/with, may be washed with water that might contain pollutants.
Reply 53509 of 59730, by Ensign Nemo
pan069 wrote on 2024-07-08, 04:34:
Another one would be if any residues or contaminants are left over, even if the dishwasher doesn't reuse water. I've never used a dishwasher that was 100% effective at cleaning everything that I've had on a plate. While the levels wouldn't likely be that high, I'd still be concerned over any long-term health impacts from repeated exposure. If enough people did this sort of thing, it probably wouldn't be great for the local wastewater treatment system either. I don't want to start a flame war or anything, but I thought my original comment was a reasonable health concern. Judging by the size of the average backlog, I think most people here would benefit from a few extra healthy years in their life. (-:
Reply 53510 of 59730, by Kahenraz
I prefer the hand wash method with a mild detergent. That way I can inspect the board as I clean it.
Re: What retro activity did you get up to today?
The attachment 20231025_050643.jpg is no longer available
The attachment 20231025_070056.jpg is no longer available
The attachment 20231025_070352.jpg is no longer available
Reply 53511 of 59730, by chrismeyer6
AGP4LIfe? wrote on 2024-07-08, 00:17:
Did it post?
Unfortunately no 😂, no beeps or anything. It does power on? And yes that pic is real LoL! To be fair I don't think I have the right/correct psu for the job. Nor did I test the CPU's individually, but even if they were bad I would get a beep I suppose. 🧐 🤔
Did you test the board without a bios battery? I've had a lot of boards act dead until I installed a bios battery. I've also had boards behave in very strange ways with dead/missing/low batteries. I'd install one before declaring the board dead.
Reply 53512 of 59730, by Aui
I also think there is always the option to do it by hand...
https://m.youtube.com/watch?v=kRkgwVMW3_0
Reply 53513 of 59730, by appiah4
Back when I started this hobby about ten years ago not washing electronics was a hill I was willing to die on. Over the years I've encountered things that had everything on them from rat piss to dog shit. As is, I don't give a damn what anybody says, into detergent they go.
Reply 53514 of 59730, by Munx
appiah4 wrote on 2024-07-08, 11:50:
I've had hardware that I presumed to be dead only to be revived by a last-ditch "whatever, its dead anyway" dunk into dishwasher detergent.
My builds!
The Underdog - The budget K6
Reply 53515 of 59730, by Nexxen
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 53516 of 59730, by PcBytes
Did it post?
I'd try sanding the BIOS pins with a piece of sandpaper to remove some of the corrosion. The BIOS chip' pins look pretty awful.
Reply 53517 of 59730, by AGP4LIfe?
chrismeyer6 wrote on 2024-07-08, 10:06:
Did it post?
Yea I popped in a battery later still no go 🙁
Reply 53518 of 59730, by AGP4LIfe?
oh great, I ate a sandwich after touching this thing..... you just put so many images in my head..
Reply 53519 of 59730, by AGP4LIfe?
PcBytes wrote on 2024-07-08, 12:13:
Did it post?
I could try, would have to get the chip out without destroying it though, whats the best way to pop it out? Flat head screw driver?
