Hi. I tried it on my setup and it worked properly. I had to force uninstall a couple of already installed drivers and software by the official driver and after that it was a success!
On step 3.3 it hung a couple of times. After that, it prompted me to point to the driver, which I did point to the VXD subfolder and then it was able to continue.
Setup: Athlon XP 3200+, 1GB RAM (with RLOEW patch), GF6800LE, SB Audigy 2ZS, ASUS A7V600 (VIA KT600).
Thank you for that, much appreciated work!
HP Elitebook 14 G1a | Snapdragon 12core | 32GB LPDDR5X RAM | Adreno GPU | 32" AOC 75Hz 2K IPS + 17" DEC CRT 1024x768 @ 85Hz
Windows 11 on ARM --> pcem ARM | Eden & Dolphin ARM editions
