Reply 661 of 683, by Linoleum
Player H wrote on 2024-08-15, 01:32:
Is this project still being maintained? Is there a website for it?
Of course! There was an update in March of this year... Like some retro projects, vogons seem to be the home base.
Athlon64 3200+, 1Gb, HD3650 AGP, SB Audigy 2ZS
P4 1.8Ghz, 512Mb, Voodoo3, SBLive
P3 866Mhz, 384Mb, Riva TNT2, Audigy
P2 266Mhz, 256Mb, RageIIc, V2, SBLive
P233 MMX, 64Mb, Mystique 220, SB 32
P100, 32Mb , S3 Virge GX, AWE64, WavetablePi & PicoGus v2
Reply 662 of 683, by theelf
Hi guys, im building a P2 machine, zida bx98-3d, awe64 gold
Unisound crash in ram detection in first isa slot, and in second just detect 0kb
Official creative driver, ctcm, detect fine and card works good. Aweutil is able to emulate gm, mt32, and no problem to upload 4mb sound bank
any ideas?thanks
EDIT> Happen same with gold and value awe64
Reply 663 of 683, by Retromachines
I found a bug in Unisound v0.81b, I have an SB 16 sound card.
Version Unisound v0.81b show error msg "Unknown PnP card TCM5098 found."
file.php?mode=view&id=199974
Version Unisound v0.80a.. ok everything works.
file.php?mode=view&id=199975
    125.49 KiB
    92.33 KiB
Reply 664 of 683, by 8bitbubsy
Retromachines wrote on 2024-08-25, 08:29:
I found a bug in Unisound v0.81b, I have an SB 16 sound card. […]
Try to run unisound with the /CS (or /NOPNP) parameter. What is happening is that you have another non-soundcard PnP card in your system, and this is confusing unisound.
I've had the same issue, and this solved it for me.
386:
- CPU: 386DX-40 (128kB external L1 cache)
- RAM: 8MB (0 waitstates at 40MHz)
- VGA: Diamond SpeedSTAR VGA (ET4000AX 1MB ISA)
- Audio: SB Pro 2.0 + GUS 1MB
- ISA PS/2 mouse card + ISA USB card
- MS-DOS 6.22 + Win 3.1
- MR BIOS
Reply 666 of 683, by AirIntake
My IBM Aptiva E2N 2153 has an onboard Crystal CS4235-KQ. It works fine in Windows 98 and DOS using the drivers pv2860.zip from Philscomputerlab.com. It doesn't get detected by Unisound though, giving me the error "Unknown PnP card [CSC8025] found. Aborting...". Any ideas?
Casio BE-300 Advancement Society alumni
Reply 667 of 683, by megatog615
AirIntake wrote on 2024-09-19, 21:52:
try /nopnp
Reply 668 of 683, by AirIntake
megatog615 wrote on 2024-09-19, 22:23:
try /nopnp
I tried that and it just says no devices detected.
Reply 670 of 683, by AirIntake
megatog615 wrote on 2024-09-21, 11:28:
Try with /CL to list all pnp cards then /C followed by the card number to initialize the right card.
/CL lists Card #1 [CSC8025] Onboard PnP Audio, and Card #2 [GVC5C19] LT Win Modem. /C1 gives me the same error "Unknown PnP card [CSC8025] found.". It's detecting the CS4235 as a CSC8025 (which I can't find anything about on Google), perhaps because my CS4235 is onboard the motherboard and not on an ISA card.
Reply 671 of 683, by megatog615
AirIntake wrote on 2024-09-24, 22:18:
Ah that sounds like a bug then.
Reply 674 of 683, by Grzyb
scroeffie wrote on 2024-10-13, 16:56:
does unisound have mixer settings i can acces ?
   /Vnn   Set Master Volume level to 'nn' % (00-99)
/VWnn Set Wave Volume level to 'nn' % (00-99)
/VFnn Set FM/Synth/WT Volume level to 'nn' % (00-99)
/VLnn Set Line-in Volume level to 'nn' % (00-99)
/VCnn Set CD Volume level to 'nn' (00-99)
/VMnn Set Mic Volume level to 'nn' (00-99)
/VPnn Set PC Speaker-in Volume level to 'nn' (00-99) (Creative)
/VTnn Set Treble level to 'nn' (00-99) (Compatible cards)
/VBnn Set Bass level to 'nn' (00-99) (Compatible cards)
/VRnn Set FM Reverb amount (00-99) (SB AWE only)
/VUnn Set FM Chorus amount (00-99) (SB AWE only)
Reply 675 of 683, by scroeffie
what do i type in if i want louder music ? not clear to me
Reply 676 of 683, by Grzyb
scroeffie wrote on 2024-10-13, 17:14:
What do you mean?
If you want louder FM synth music, but no volume change for PCM effects:
unisound /VF99
Reply 678 of 683, by Grzyb
scroeffie wrote on 2024-10-13, 17:28:
vol wav and fm on 99% because iam testing a vu led meter mod i hooked up to my soundblaster 16 card its working but the settings are to low
If you want all output as loud as possible:
unisound /V99 /VW99 /VF99
but be careful - with some cards, max settings = overdriving = distorted sound
