Reply 660 of 860, by Player H
Is this project still being maintained? Is there a website for it?
Reply 661 of 860, by Linoleum
Player H wrote on 2024-08-15, 01:32:
Of course! There was an update in March of this year... Like some retro projects, vogons seem to be the home base.
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge, SB32, PicoGus
486DX4 100, CLGD5424, SB32
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA, Forte16
PS2 30/286, SBP
Reply 662 of 860, by theelf
Hi guys, im building a P2 machine, zida bx98-3d, awe64 gold
Unisound crash in ram detection in first isa slot, and in second just detect 0kb
Official creative driver, ctcm, detect fine and card works good. Aweutil is able to emulate gm, mt32, and no problem to upload 4mb sound bank
any ideas?thanks
EDIT> Happen same with gold and value awe64
Reply 663 of 860, by Retromachines
I found a bug in Unisound v0.81b, I have an SB 16 sound card.
Version Unisound v0.81b show error msg "Unknown PnP card TCM5098 found."
file.php?mode=view&id=199974
Version Unisound v0.80a.. ok everything works.
file.php?mode=view&id=199975
Reply 664 of 860, by 8bitbubsy
Retromachines wrote on 2024-08-25, 08:29:
I found a bug in Unisound v0.81b, I have an SB 16 sound card. […]
Try to run unisound with the /CS (or /NOPNP) parameter. What is happening is that you have another non-soundcard PnP card in your system, and this is confusing unisound.
I've had the same issue, and this solved it for me.
386:
- CPU: 386DX-40 + 40MHz FPU + 128kB L1 cache
- RAM: 8MB (0 waitstates, 40MHz)
- VGA: Diamond SpeedSTAR VGA (ET4000AX 1MB ISA)
- Audio: Sound Blaster Pro 2.0
- ISA PS/2 mouse card + ISA USB-stick card
- MR BIOS v1.65
Reply 665 of 860, by dukeofurl
This program is fantastic and I use it with everything I run dos on.
Reply 666 of 860, by AirIntake
My IBM Aptiva E2N 2153 has an onboard Crystal CS4235-KQ. It works fine in Windows 98 and DOS using the drivers pv2860.zip from Philscomputerlab.com. It doesn't get detected by Unisound though, giving me the error "Unknown PnP card [CSC8025] found. Aborting...". Any ideas?
Casio BE-300 Advancement Society (be300.org) alumni
Reply 667 of 860, by megatog615
AirIntake wrote on 2024-09-19, 21:52:
try /nopnp
You AI slop bores me.
Hoping to get my PicoIDE soon.
Reply 668 of 860, by AirIntake
megatog615 wrote on 2024-09-19, 22:23:
try /nopnp
I tried that and it just says no devices detected.
Reply 669 of 860, by megatog615
Try with /CL to list all pnp cards then /C followed by the card number to initialize the right card.
Reply 670 of 860, by AirIntake
megatog615 wrote on 2024-09-21, 11:28:
/CL lists Card #1 [CSC8025] Onboard PnP Audio, and Card #2 [GVC5C19] LT Win Modem. /C1 gives me the same error "Unknown PnP card [CSC8025] found.". It's detecting the CS4235 as a CSC8025 (which I can't find anything about on Google), perhaps because my CS4235 is onboard the motherboard and not on an ISA card.
Reply 671 of 860, by megatog615
AirIntake wrote on 2024-09-24, 22:18:
Ah that sounds like a bug then.
Reply 672 of 860, by vico
Bug report with sound card: ESS1688 / NO PNP / Sound Blaster Pro Clone
When initializing with unisound /nopnp the card is detected by many games as Adlib. Also the sound is very loud and distorted.
Reply 673 of 860, by scroeffie
does unisound have mixer settings i can acces ?
Reply 674 of 860, by Grzyb
scroeffie wrote on 2024-10-13, 16:56:
   /Vnn   Set Master Volume level to 'nn' % (00-99)
/VWnn Set Wave Volume level to 'nn' % (00-99)
/VFnn Set FM/Synth/WT Volume level to 'nn' % (00-99)
/VLnn Set Line-in Volume level to 'nn' % (00-99)
/VCnn Set CD Volume level to 'nn' (00-99)
/VMnn Set Mic Volume level to 'nn' (00-99)
/VPnn Set PC Speaker-in Volume level to 'nn' (00-99) (Creative)
/VTnn Set Treble level to 'nn' (00-99) (Compatible cards)
/VBnn Set Bass level to 'nn' (00-99) (Compatible cards)
/VRnn Set FM Reverb amount (00-99) (SB AWE only)
/VUnn Set FM Chorus amount (00-99) (SB AWE only)
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 675 of 860, by scroeffie
what do i type in if i want louder music ? not clear to me
Reply 676 of 860, by Grzyb
scroeffie wrote on 2024-10-13, 17:14:
What do you mean?
If you want louder FM synth music, but no volume change for PCM effects:
unisound /VF99
Reply 678 of 860, by Grzyb
scroeffie wrote on 2024-10-13, 17:28:
vol wav and fm on 99% because iam testing a vu led meter mod i hooked up to my soundblaster 16 card its working but the settings are to low
If you want all output as loud as possible:
unisound /V99 /VW99 /VF99
but be careful - with some cards, max settings = overdriving = distorted sound
Reply 679 of 860, by scroeffie
doesnt work what am i doing wrong ?
