stamasd wrote on 2024-10-02, 09:55:
No, actually to my ears it was the other way around. FM emulation was passable, but MIDI (at least in the games I've tried) frankly sucked. Very tinny, like all of the music was played on cymbals and bells only. 😀 But it worked, so that's a plus. 😜
If only there was a way to generate better quality .ecw sets and replace the default ones...
From what I gather, some attempts to reverse engineer the ECW format were made in the past, but there have been no major breakthroughs as of yet.
Personally, if I'm playing DOS games which support General MIDI on a SBLive/Audigy card, I do it from within Win9x if possible. That way, I can choose whichever soundfont I like best for a particular game. Of course, some DOS games can't run from Win9x, so that's not always an option. But usually, it works fine for later titles like Doom, Duke3D, Descent and such.
(edit) try it; there is a download of Frontier Elite 2 shareware at https://www.frontierastro.co.uk/Files/files.html - sound options at the beginning are: Roland/LAPCI (essentially MIDI through MPU401), Soundblaster/AdLib (FM sound), none, and PC speaker 😀 Needs at least 768k of expanded memory or else it won't start.
I'm sure you know that LAPC is not compatible with General MIDI. As for the MT-32 emulation on SBLive/Audigy cards, that's limited to the few games which don't use custom instruments.
