First post, by Studiostriver
Hi to all.
As perhaps someone saw my old posts here on forum its been little bit more then 2 months that i got myself into retro Pentium 3 computer and so far i having lot of fun playing old games.
Currently i using ATI 9600 Pro 128mb as my GPU, and for some games like Wizardry 8 i sometimes get 100% CPU hit (big maps and lots of enemies to render) on my Tualatin 1.4ghz S model.
I want to try to overclock it , and i asking how much would be safe zone so to speak? 1.5/6? Or i can dare to try 1.7 for example?
Kind regards,
Dado.
Reply 1 of 16, by smtkr
If you really want to overclock it, just send it until you start to crash. If you want to increase voltage to achieve stability at higher clocks, that's where you'll start to risk your hardware. Be conservative with your fun.
Just keep in mind two main things:
1. They don't make them any more, so if you kill it, there's one fewer left in the world
2. If you need more speed, building a faster retro system is better than overclocking
Reply 2 of 16, by BitWrangler
It is typical to be "running out of" FSB headroom on your motherboard before these processors cry uncle*, so not entirely clear what the top limits on them are. However, as usually in overclocking they make a lot more heat, so bigass cooler needed. VoodooMan has a number of posts concerning Tualatin performance, the memory modules to use etc.
Edit: * beg for mercy.... not sure how clear that expression is to non-Brits/merkins.
Reply 3 of 16, by pete8475
Studiostriver wrote on 2024-12-05, 23:47:
Hi to all. […]
Hi to all.
Kind regards,
Dado.
I've had one at 1648mhz for years now so I'd say push it as far as possible.
Reply 4 of 16, by Studiostriver
BitWrangler wrote on 2024-12-06, 02:08:
I have bought very big AMD heatsink and CPU never went to be nothing but lukewarm while i using it, well judging by my touch of the heatsink. It barely has any heat at all.
Reply 5 of 16, by Studiostriver
pete8475 wrote on 2024-12-06, 02:38:
Hi to all. […]
Hi to all.
Kind regards,
Dado.
Around 5 years of more? 😀 Just checking the lifespan. 😉
Reply 6 of 16, by pete8475
Studiostriver wrote on 2024-12-06, 02:56:
Hi to all. […]
Hi to all.
Kind regards,
Dado.
Easily more than 5.
Reply 7 of 16, by Studiostriver
pete8475 wrote on 2024-12-06, 20:54:
Easily more than 5.
Oh great, thanks for let me know. Then i may overclock my Tualatin for sheer enjoyment. I dont know how much this retro enthusiasm gonna hold up in future, so if it gonna last at least 5 years then i`m fine with it.
Reply 8 of 16, by pshipkov
These CPUs handle 1.7++ GHz just fine, often without the need to overvolt.
Given a decent motherboard and video card, the limiting factor is by far the DRAM memory.
If you plan to go 140MHz FSB with tight timings - you will need to find magical mem modules.
This is especially true if you want more RAM (multiple modules).
retro bits and bytes
Reply 9 of 16, by VooDooMan
The safe voltage for a Tualatin CPU is 1.75 volts according to Intel: https://theretroweb.com/misc/documentation/24 … de769755306.pdf
The truth is, overclocking is NOT about voltage. It's more about thermals, but that is also NOT the most important thing. What really matters here is the quality of the silicon wafer used in your CPU. So if you wanna get REALLY GOOD OC results, you don't need high voltage. What you need is a perfect batch. To get one you have to start binning. 😀 There is no other way... What you should look for is the latest revision of a given CPU. The later the production date, the higher the chances of finding what you need 😉 How many CPUs do you need to find a perfect one? At least 10.... From my experience: 1 out of 10 CPUs is very good, 2 are good, and the rest is trash. Just look for different production dates, don't take the ones made at the same time.
So now you probably wonder: How high can you can I go?
With a regular socket 370 cooling and poor quality thermal-paste your CPU will probably run over 50 Celsius at the default Vcore. You need to lower the temps as much as you can. Using a high quality paste and a copper-based cooler (from socket A boards) can make a real difference, and you will be able to go down to 34-38 Celcius.
Now you can expect:
- at 1,45Vcore : up to 1800 MHz ( with max temperatures under full load being 39 Celsius) but usually that is around 1750 MHz
- at 1,65Vcore : up to 1900 MHz ( with max temperatures under full load being 44 Celsius) but usually that is around 1850 MHz
- at 1,75Vcore: up to 2000 MHz ( with max temperatures under full load being 44 Celsius) but usually that is around 1950 MHz (here you need to delid and use liquid metal)
Of course if have only one sample of a given CPU it won't overclock that good (unless you are very lucky). For example most SL6BY CPUS overclock easily above 160 MHz but only 1 in 5 will reach 166 MHz. at 1,65v...) So if your CPU just doesn't want to overclock don't feed him with too much 😉 It doesn't make any sense to use higher voltage unless you are planning some extreme cooling solutions like dry ice or liquid nitrogen. I have tried that kind of cooling only ONCE and it wasn't worth it. https://www.youtube.com/watch?v=pR2FxPIo3es
Naturally, to be able to achieve such high speeds, you also have to have a decent mobo 😉 Only the ones base on i815 will give you the chance to reach FSB higher than 200 MHz, forget about Intel BX440. VIA chipsets will be good to around 170 MHz maximum in sometimes up to 180 MHz. Memory is not a problem at all here. Boards like ABIT ST6 or ASUS TUSL2-C give you the chance to overclock in asynchronous mode, so basically any SDR133 CL2 will be fine for overclocking up to 200 MHz. BUT if you want to have tight timings, then you also have to know what to look for 😉 You have to bear in mind that overclocking on a regular board will affect all other components on your mobo especially when you go higher than 166 MHz (unless you are using a mobo with 1/5 PCI divider, but there aren't many of those...). Do not use Radeon 9X00 cards, especially 9700PRO and 9800 PRO - they don't like AGP frequencies higher than 78 MHz. Stick to some GeForce 4 MX 440m MX4000, 6200 cards (they are cheap and tolerant of around 115 MHz AGP frequncies)
In case:
You need a CPU that overclocks beyond 220 MHz - HIT ME!
You need an SDR memory that is able to go 200 MHZ CL 2-2-2-7 - HIT ME!
You want to find a way how to easily select a fast CPU - HIT ME!
BTW! Don't listen to skeptics, be careful what you are doing, monitor the temps and voltages; and always have fun!!! 😀
Best Tualatin Motherboard
ECS P6S5AT at 166 MHz
Overclocking Pentium III
Reply 10 of 16, by mockingbird
@VooDooMan - why didn't you use direct die cooling? The TIM on those has to be pretty crusty by now.
(Decommissioned:)
Reply 12 of 16, by cloverskull
Man, these 1.4ghz Tualatin CPUs are gonna be worth quite a bit on the vintage market at some point. I'm hoarding a couple myself 😜 @VooDooMan do you have any in your stash you'd want to part with that you've already proven overclockability?
Right now I have two in use. Both running at factory clock. One in a PC and one in my original XBox. Fun times.
Reply 13 of 16, by H3nrik V!
You'll probably still hit 100% CPU load on an overclocked CPU, but with higher frame rate 😀
What I'm trying to say is that the 100% CPU load is not an indicator per se, if you're running 120+ FPS with 100% CPU load, then no problem 😉
Reply 14 of 16, by Studiostriver
H3nrik V! wrote on 2024-12-19, 07:51:
Hm, ok then. 😀
Reply 15 of 16, by Studiostriver
VooDooMan wrote on 2024-12-18, 18:35:
The safe voltage for a Tualatin CPU is 1.75 volts according to Intel: https://theretroweb.com/misc/documentation/24 … de7697553 […]
In case:
I`m not too much experimenting since i`m not personally too much enthusiast into retro gaming. I just made one Pentium 3 configuration which i occasionaly enjoy playing when i find free time. 😀
My motherboard is DFI CA64-TC
https://theretroweb.com/motherboards/s/dfi-ca64-tc
SDRAM is 768MB, i had struggle finding 500MB that works with my motherboard, wanted to upgrage to 1GB, but so far had no luck.
All is working on 133mhz, CPU and RAM. 😉 Thats all i know.
Reply 16 of 16, by Studiostriver
Update
I`ve managed only to make it work on 1.5ghz, all above that simply dont work. Well it will stay there. 😀
