Reply 20 of 33, by Joseph_Joestar
- l33t++
shamino wrote on 2025-01-30, 07:00:On some systems the PCI bus gets saturated. Also, the frontside bus and RAM can get hit 4x: reading a file from disk to RAM, reading that file data back from RAM, converting it to network packets as it's written back to another location in RAM, and then reading those packets back out of RAM to send them out to the network.
I just replaced the 3Com network card in my Celeron 600 rig with an Intel PRO/1000 GT. Using that card, and with "Interrupt Moderation Rate" disabled in the driver, I'm getting the following results from LAN Speed Test under Win2K:
However, in real-world scenarios such as copying an ultra compressed 7-Zip archive from the network, I'm getting around 13.1 MB/s. Uploading to the network is faster at around 17.6 MB/s. So I think I've hit the practical limits of what is possible on this system. It also seems consistent with the results from this thread: There is a difference between Intel Pro 1000 NICs
By the way, drivers for the Intel PRO/1000 GT are quite resource heavy on this Celeron 600 rig. And my motherboard always loads the network card's boot rom at startup, only then proceeding to boot from the local hard drive. Because of that, I might go back to the lightweight 3Com card.
