Reply 20 of 47, by Joseph_Joestar
shamino wrote on 2025-01-30, 07:00:
On some systems the PCI bus gets saturated. Also, the frontside bus and RAM can get hit 4x: reading a file from disk to RAM, reading that file data back from RAM, converting it to network packets as it's written back to another location in RAM, and then reading those packets back out of RAM to send them out to the network.
I just replaced the 3Com network card in my Celeron 600 rig with an Intel PRO/1000 GT. Using that card, and with "Interrupt Moderation Rate" disabled in the driver, I'm getting the following results from LAN Speed Test under Win2K:
The attachment LAN_Speed_Test_Intel.png is no longer available
However, in real-world scenarios such as copying an ultra compressed 7-Zip archive from the network, I'm getting around 13.1 MB/s. Uploading to the network is faster at around 17.6 MB/s. So I think I've hit the practical limits of what is possible on this system. It also seems consistent with the results from this thread: There is a difference between Intel Pro 1000 NICs
By the way, drivers for the Intel PRO/1000 GT are quite resource heavy on this Celeron 600 rig. And my motherboard always loads the network card's boot rom at startup, only then proceeding to boot from the local hard drive. Because of that, I might go back to the lightweight 3Com card.
My retro builds
Reply 21 of 47, by darry
Here is my experience, which I am quoting from another thread
EDIT: The picture attachments are in the wrong order for some reason. I will fix it ehen I have access to a PC. In the meantime, they are correct in the original thread/post
darry wrote on 2021-01-17, 01:49:
I was feeling bored today, so I dug up my 400MHz Pentium 2 (4x100MHz), installed it in my Asus P3B-F and ran at 266MHz (4x66MHz) […]
I was feeling bored today, so I dug up my 400MHz Pentium 2 (4x100MHz), installed it in my Asus P3B-F and ran at 266MHz (4x66MHz) to get something fairly comparable to your CPU and then ran it with a 1400MHz CPU for a best case scenario .
- The machine was running Windows 98 SE and was summarily TCP optimized using https://www.speedguide.net/files/sguide_tweak_9x.zip (TCP Optimizer set to optimum did not give optimal results) .
- CPU-Z was run after the FTP transfer had completed
First, a disk benchmark with the 266MHz CPU :
The attachment 266mhz_atto.png is no longer available
This is running in DMA mode, obviously, off of a SIL3114 SATA controller
Second, the best performance I could get with a 266MHz CPU through FTP using a 3COM 3C905B (100Mb NIC):
The attachment 266mhz.png is no longer available
Third, the best performance I could get with a 266MHz CPU through FTP using an Intel PRO/1000 GT (Gigabit NIC) :
The attachment 266mhz_gig.png is no longer available
Finally, the best performance I could get with a 1400MHz Tualatin (PowerLeap adapter) CPU through FTP using an Intel PRO/1000 GT (Gigabit NIC) :
The attachment 1400mhz_gig.png is no longer available
It should be obvious that a 266MHz Pentium II CPU is just not fast enough to drive a Gigabit NIC .
Conclusion :
Assuming my results are representative, running a Gigabit NIC rather than a 100Mbps one on a 266MHz Pentium II CPU is practically pointless.
EDIT : corrected a typo and an image
EDIT2 : Added some context
Reply 22 of 47, by Joseph_Joestar
darry wrote on 2025-01-30, 13:57:
Interesting findings.
I think Slot 1 (and Socket 370) systems are probably where one would want fast network transfer speeds the most (even if it's "just" 100Mbps), because they only have USB 1.1 by default. And adding a USB 2.0 card has the potential to slow down the entire system, depending on a number of factors.
My retro builds
Reply 23 of 47, by auron
over 7 mb/s networking using a p2 266 on 9x isn't too bad in my book. that's actually around the sequential speed of some decent IDE drives just a year older than that CPU. for more serious work NT would have been used and would perform better than that. i think an interesting use case for fast networking is to stream a disc image using iSCSI, but this needs win2k anyway.
the pro/1000gt and probably also the 3c905b support checksum offloading, but i forgot if the drivers under 9x expose this. if they don't, this is probably not supported under 9x at all.
Reply 24 of 47, by darry
Joseph_Joestar wrote on 2025-01-30, 14:10:
To be fair, that system does reach something like 400Mbps under Linux AFAICR. I do not see a point to running XP on that slow a system for my use cases.
Other than the challenges with USB 2.0 and system slowdowns on older platforms, I don't like the idea of plugging/unplugging stuff constantly. I'm lazy that way.
Reply 25 of 47, by darry
auron wrote on 2025-01-30, 14:31:
Yeah, back in the day, with slower drives, the bad network performance of Windows 9x was not that noticeable for home users.
Reply 26 of 47, by Joseph_Joestar
I noticed that the Intel PRO/1000 Network Adapter Driver 9.2 WHQL is still hosted here on Softpedia.
That driver version was released in either 2004 or 2005. It certainly feels much lighter on my Celeron 600 under Win2K than the 14.0 drivers that I was using before. The installer is a bit wonky, but it does work if you update the driver manually via Device Manager. Transfer speeds remain mostly the same as before, so it might be a good fit for retro systems with less horsepower like my Celeron rig.
My retro builds
Reply 27 of 47, by Joseph_Joestar
Joseph_Joestar wrote on 2025-01-30, 13:30:
I found a way to disable this. It can be done using Intel's BOOTUTIL.EXE and I specifically needed the DOS version for my retro rig. I got it from a driver CD image containing Intel Network Connections Software Version 16.2, but it can probably be found elsewhere as well. The syntax is as follows:
BOOTUTIL.EXE -FD -ALL
This will disable the boot rom on all Intel network cards in the system. Worked for me, so no more Intel Boot Agent during startup on my Celeron rig.
My retro builds
Reply 28 of 47, by Joseph_Joestar
I did some more network testing today, by adding a 3Com 3C905B-TX network card to my K6-2 (non-plus) 266 build.
Under Windows 95 OSR 2.1 I was getting fluctuating file transfer speeds between 2-4 MB/s. However, under Windows NT 4.0 + SP6 I was getting a steady file transfer speed of 5.5 MB/s. Once again, the NT network stack proves its superiority. Also, both Rx and Tx offloading is available for this card under NT4 when using the latest official drivers.
My retro builds
Reply 29 of 47, by y2k se
I tested with iperf. The client was the Win98 box in my signature, with a 3Com 3C905C-TXM NIC. The server was a Ubuntu 24.04 LTS virtual machine with my NAS as a host. The Win98 box connects via a Unifi Device Bridge to a U6 Mesh AP that is hardwired to the LAN at 1 GBe. The NAS is hardwired via 10 GBe. TCPOptimizer set to Optimal did not change the results.
Tualatin Pentium III-S 1.4, ASUS TUSL2-C, 512MB RAM, GeForce 4 Ti 4200, Voodoo2, SB Live!, 3Com 3C905C, 80GB IDE HDD, Dell 2001FP
P233MMX, Intel LT430TX, 64MB RAM, Sierra Screamin' 3D, Voodoo2, AWE64 Gold, 3Com 3C905B, 40GB IDE HDD, Viewsonic A75f
Reply 30 of 47, by havli
I have many benchmarks of Samba share speed on old CPUs. You can find them here:
ctrl+f: Total Commander 8.51a – Samba network drive
http://hw-museum.cz/article/5/cpu-history-tou … -1995---1999-/9
http://hw-museum.cz/article/6/cpu-history-tou … -1999---2001-/9
http://hw-museum.cz/article/8/cpu-history-tou … -2001---2003-/8
Reply 31 of 47, by Joseph_Joestar
havli wrote on 2025-02-13, 15:08:
Those are some nice results.
From what I understand, the server was Debian Linux. But what about the client OS from which you used Total Commander? Was it Win98SE or something else?
My retro builds
Reply 32 of 47, by havli
It was Windows XP SP3 in all these tests.
And Marvell Yukon 88E8003 PCI GLAN for all platforms.
Reply 33 of 47, by konc
Joseph_Joestar wrote on 2025-01-31, 10:02:
I found a way to disable this. It can be done using Intel's BOOTUTIL.EXE and I specifically needed the DOS version for my retro […]
Thanks for this!
I looked for it recently and just wanted to add that it's still available from Intel's site. The support article How to Turn Off Intel® Boot Agent (IBA) or Prevent It from Running links to download this utility from package Intel® Ethernet Connections Boot Utility, Preboot Images, and EFI Drivers. The latest versions doesn't contain a DOS executable, but switch to an earlier one (for example v25.0) and it does.
Reply 34 of 47, by BaronSFel001
Joseph_Joestar wrote on 2025-01-28, 11:27:
I tried something interesting today: FireWire networking. How? Easy, I have a couple of retro rigs with Audigy cards, which of c […]
I tried something interesting today: FireWire networking. How? Easy, I have a couple of retro rigs with Audigy cards, which of course have a FireWire port on the back. I connected two of them together using a 6-pin FireWire 400 cable and set up their IP addresses manually. It worked fine, and the computers were able to see each other on the network. On my Celeron 600 system, I was getting transfer speeds between 6-12 MB/s under WinME. Meaning, I experienced similar speed fluctuations as with the 3Com card, likely due to the Win9x network stack. Unfortunately, I couldn't test this under Windows 2000, as that OS doesn't appear to support FireWire networking out of the box, at least from what I've seen.
However, I did manage to network my Athlon 64 3400+ rig with my Core 2 Duo E8600 system using FireWire. They also use Audigy cards, but have WinXP as the secondary OS. Under WinXP, FireWire networking worked fine, and gave me a steady transfer speed of 18 MB/s (no fluctuations).
The attachment Lan_Speed_Test_FW.png is no longer available
This was mostly for fun, I just wanted to see how FireWire networking works. I'm guessing faster transfer speeds are off the table because Audigy cards are using the PCI bus, or maybe it's something with my setup. In any case, this is a fun alternative to regular network cards, though not very practical.
Remarkable! Joe, you are becoming my go-to for outside-the-box thinking to inside-the-box problems. My AGP is the Radeon 8500 All-in-Wonder which just so happens to come with a FireWire port that I otherwise have no conceivable use for.
I have booted System 20 up for the first time in a while for a battery of maintenance testing and she's still kicking, but I have the same problem of all my expansion slots being taken up with no room for a network card, thinking I would still have to resort to some conversion to LAN hardware via one of my USB 1.1 ports or try and find some combination network/VGA/audio card that would cover my needs without sacrificing any capability.
System 20: PIII 600, LAPC-I, GUS PnP, S220, Voodoo3, SQ2500, R200, 3.0-Me
System 21: G2030 3.0, X-fi Fatal1ty, GTX 560, XP-Vista
Retro gaming (among other subjects): https://baronsfel001.wixsite.com/my-site
Reply 35 of 47, by Joseph_Joestar
BaronSFel001 wrote on 2026-06-29, 21:41:
Heh, as mentioned before, I mostly did it for fun, but Creative was apparently highlighting this feature when marketing their Audigy cards.
I don't personally know of anyone who used FireWire networking for gaming purposes back in the day, but it does seem to work.
My retro builds
Reply 36 of 47, by NeoG_
Just leaving this here since it seems a good a place as any - If you have an older system that can transfer over LAN at a decent speed (over 10Mbps) but is struggling to get over 200Kbps when downloading from the internet (causing video streaming or radio streaming to buffer for example), TCP Optimizer will probably fix it.
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 37 of 47, by myne
CPU usage?
You have to remember old cpu + modern encryption = absurdly slow.
1) They are slower. <2ghz
2) They don't have 'shortcuts' baked in the silicon.
3) retro implies 32bit, so just getting 1 SHA256 string into the registers is 8 operations before doing any math on it.
I built:
Reply 38 of 47, by NeoG_
myne wrote on 2026-06-30, 05:18:
CPU usage? […]
CPU usage?
It seems to be the default TCP windowing strategy in 9x is optimised for narrowband internet connections (EG <= 56k), the effect happens even with unencrypted data transfers. SMB transfers seem to not be affected by default.
Reply 39 of 47, by myne
Sure, but 10mbit cards existed too and they weren't barely scraping 1.5mbit.
I built:
