Reply 55920 of 57994, by Kahenraz
PcBytes wrote on 2025-01-31, 18:25:
myne wrote on 2025-01-31, 16:36:
According to the datasheet it seems to do 133. How well that would run, idk.
Are these overclocks troublesome for the AGP, PCI, or ISA bus? What is the stability problem?
Reply 55921 of 57994, by Big Pink
justin1985 wrote on 2025-01-30, 23:06:
I bought this plain looking PC on eBay for what seemed to be a very unusual case - it's MiniITX but with both full sized 5.25" and 3.5" drive bays ...
I see those SFF cases on eBay all the time with a starting price of £0.99. I had the same thoughts as you but I absolutely hate those low profile expansion slots. Hard to find small cases with a full size riser slot. I have my reasons!
I thought IBM was born with the world
Reply 55922 of 57994, by PcBytes
Kahenraz wrote on 2025-01-31, 21:31:
Are these overclocks troublesome for the AGP, PCI, or ISA bus? What if the stability problem?
I'll test it out later. I have an A7N266-VM under stability testing, from the same package the P2B came from, right now.
Reply 55923 of 57994, by zwrr
For $15 I got an Aztech Waverider Pro 32-3D (138-MMSN852) , which sounded brighter and clearer with FM music than the CT2770 and ES1868.
The attachment mini-1.jpg is no longer available
The attachment mini-2.jpg is no longer available
The attachment mini-3.jpg is no longer available
The attachment mini-4.jpg is no longer available
Pentium MMX233, Zida TX98-3D, 64MB, Riva 128, Aztech Waverider Pro 32-3D, HardMPU-wt
K6-III+550, FIC VA-503+, 256MB, Voodoo3 2000, Creative AWE32, HardMPU-wt
Tualatin-1.4G, QDI A10BM, 512MB, G400, Voodoo2 SLI, Creative AWE64
Reply 55924 of 57994, by PcBytes
PcBytes wrote on 2025-01-31, 21:50:
And... it won't let a 1GHz CPU go higher than 833MHz.
Used the multiplier selection from P2B rev 1.10 to set jumpers to 7.5x multi for 7.5x133= ~1GHz, yet nada.
Also locks up before showing the Windows desktop, although idk if it was because I was booting off a 9GB IBM SCSI HDD.
Reply 55925 of 57994, by RoundTheTwist
zwrr wrote on 2025-02-01, 08:25:
For $15 I got an Aztech Waverider Pro 32-3D (138-MMSN852) , which sounded brighter and clearer with FM music than the CT2770 and […]
I love the these Aztech cards I'm 99% sure the MMSN852 was my first sound card back in the day and came in a 'multimedia' bundle with an 8x CD drive. I bought a MMSN852 for five times as much last year as am on a mission to rebuild my old system, nostalgia is crazy.
Reply 55926 of 57994, by PARKE
PcBytes wrote on 2025-02-01, 11:03:
And... it won't let a 1GHz CPU go higher than 833MHz. Used the multiplier selection from P2B rev 1.10 to set jumpers to 7.5x mu […]
It's the chip that is buggy. This piece of conversation below comes from the Motherboard forum but is no longer available on the web, Author is 'P2B' aka Simon Edwards and Keith Hui who are behind the Tipperlin quide for ASUS mobo's:
ooooooooooooooooooooooooooo
Need P2B-S mod help
www.motherboardpoint.com
Feb 22, 2006
Yeah, upgrading older P2B-series boards would be a lot simpler if the 9150-08 133Mhz setting actually worked, instead of producing an ugly signal the BX interprets as 109Mhz. Maybe next time you are beating on them about the cost of deficient designs, you could suggest they atone for past sins by making 9250-08 samples available to those of us who still care...
P2B
Vogons member Laflash managed to upgrade the 9150-08 on a P2B-D board. You can read more about it here:
Upgraded Asus P2B-D with 133MHz FSB
Reply 55927 of 57994, by myne
It's multiplier locked. You can set them to anything you like and the only thing that might change is the bios display.
You were actually setting it to 1333mhz.
I built:
Reply 55928 of 57994, by PcBytes
myne wrote on 2025-02-01, 12:54:
Um... the chip I use has the default multiplier 7.5 - SL4MF.
Reply 55929 of 57994, by PARKE
PcBytes wrote on 2025-02-01, 13:58:
Vogons member limsolo ran into the same problem here:
Re: Asus P2B-D CPU heatsink clearance for Slotkets
I have the old 9150 clock gen chip which I confirmed with SoftFSB wont produce a proper signal at 133Mhz it downclocks the CPU's (I forgot exactly what but it was lower than 112Mhz FSB).
Reply 55930 of 57994, by myne
Oh, well, look into finding a 9250.
iirc they're pin compatible
I built:
Reply 55931 of 57994, by tunertom
Managed to snag an ASUS P5PE-VM for a price I think was reasonable
It was £40 (GBP) - I think I was able to snap it up because it was listed incorrectly as a different motherboard
Every time I've had chance to see one listed it's been for 3-4x the price I paid
Excited to get it into a little case for some Win98 tom-foolery
The attachment Screenshot_20250201-184532.png is no longer available
Reply 55932 of 57994, by dionb
Ah, 3rd gen Aztech card. Yes, nice real OPL3 with better filters than most SB16. Shame about the Samsung 1MB wavetable - but they can't all be MMSN826 (with ICS wavetable and 2MB ROM)
Nice price too, even formerly unloved and ubiquitous Aztech cards are starting to get thin on the ground.
Reply 55933 of 57994, by Major Jackyl
Got some good stuff today.
The attachment 20250201_131745.jpg is no longer available
The attachment 20250201_131734.jpg is no longer available
The attachment 20250201_125934.jpg is no longer available
The attachment Screenshot 2025-02-01 134141.png is no longer available
The attachment Screenshot 2025-02-01 134153.png is no longer available
Main Loadout (daily drivers):
Intel TE430VX, Pentium Sy022 (133), Cirrus Logic 5440, SB16 CT1740
ECS K7S5A, A-XP1600+, MSI R9550
ASUS M2N-E, A64X2-4600+, PNY GTX670, SB X-Fi Elite Pro
MSI Z690, Intel 12900K, MSI RTX3090, SB AE-7
Reply 55934 of 57994, by dominusprog
Major Jackyl wrote on 2025-02-01, 19:49:
Got some good stuff today. […]
I also own a same exact Panasonic floppy drive. The fact that you can't rotate the lever without any floppy inserted is very cool.
Reply 55935 of 57994, by H3nrik V!
myne wrote on 2025-02-01, 16:39:
Found some on alien aliexpress not long ago, for very manageable money. Bought some, still
1. Waiting for time to transplant it to my P2B-DS
2. Considering if the lower clocks of the 9150 would actually be more usable to keep
Reply 55936 of 57994, by zwrr
RoundTheTwist wrote on 2025-02-01, 12:47:
Yes, you can imagine how joyful and unforgettable it was to get such a sound card with hard wavetable synthesis in childhood.
Reply 55937 of 57994, by Living
zwrr wrote on 2025-02-02, 01:42:
any card for that matter, i will never forget when i bought a cheapo Genius ISA card with Crystal chip and i heard the Lotus 3 opening theme after playing many times with the speaker
https://www.youtube.com/watch?v=-zqMEPCYmn4
every update in the 90's was a milestone
Reply 55938 of 57994, by Thermalwrong
That's quite a haul - I mean literally, that Lian-Li case has wheels right? I used to have that in silver and it was huuuuge. I sold it a while back and had to ship it in a cardboard box, the shop I dropped it off at said no more packages that size 😒
Whereabouts do you find 5.25" drives, a Radeon 9700, a Creative Labs Goldfinch card and a wavetable card all in the same place?
Reply 55939 of 57994, by Ozzuneoj
dominusprog wrote on 2025-02-01, 21:32:
Just be very careful with it and make sure that anyone that may interact with the machine knows that it does NOT lock unless a disk is inserted.
I had a similar drive and the plastic sleeve+bump that acts as the locking mechanism is just press-fitted onto a steel shaft with a notch cut in it. So, the twisting force applied to the lever on the outside translates to a twisting force (with leverage) of 30+ year old plastic on a steel rod. The white plastic may be different, but on the black ones this causes the plastic to crack in multiple places, which prevents the lever from working at all. 🙁
The way I fixed it was actually to wrap the cracked plastic sleeve several times in wire-wrapping wire (with the shielding stripped off), and then using a soldering iron to melt the wire into the plastic to give it some strength. Last I knew it was still operating... but this was not a fun process!
