First post, by sirotkaslo
does anyone have the latest bios for the M575 motherboard? Mine is dated 2/12/1998 S.
Also, does DMA work on this motherboard? Everytime i enable it, my win98se won't boot anymore.
Thank you!
Reply 2 of 16, by Chkcpu
Here is the original M575 990402S BIOS.
There is also a patched version of this BIOS with K6-2+/-III+ support on my K6plus page at:
http://www.steunebrink.info/k6plus.htm#patched
Jan
Edit: updated the link to my website
    M575_990402s.zip
    110.63 KiB
    56 downloads
CPU Identification utility
The Unofficial K6-2+ / K6-III+ page
Reply 4 of 16, by sirotkaslo
worked like a charm, but I am going to miss the old interface.
Thank you!
EDIT: dma still not working, found some info that txpro has a chipset bug and it will not work, too bad.
Reply 5 of 16, by Roman555
sirotkaslo wrote on 2021-11-14, 10:05:
Hi, […]
Thank you!
What exactly do you mean about DMA ?
I used this model of motherboard. Back then when I installed the IDE miniport driver I saw dramatically lesser CPU usage in the HDTach test.
I used maybe one of the first UDMA33 model of Seagate - ST31722A. So I think the UDMA 33 works. Although I'm not sure about Multiword DMA Mode.
[ MS6168/PII-350/YMF754/98SE ]
[ 775i65G/E5500/9800Pro/Vortex2/ME ]
Reply 6 of 16, by sirotkaslo
When i enable dma under device manager system refuses to boot. Also under bios i only get pio mode and during post it says udma capable but not enabled.
Using wd400.
Reply 7 of 16, by Roman555
sirotkaslo wrote on 2021-11-14, 13:32:
Using wd400.
Did you install the ALI IDE miniport driver ?
P.S. Some links:
https://www.elhvb.com/webhq/models/pcchips/m575.htm
ftp://ftp.spez.kharkov.ua/pub/driver/mb/pcchip/
ALi M5229 IDE Bus Master Controller driver for Win98
ftp://ftp.spez.com.ua/driver/mb/pcchip/txpide98.zip
Reply 9 of 16, by Roman555
sirotkaslo wrote on 2021-11-14, 16:23:
Tried installing the driver from v2.3 cd but installer said that it is already installed. Is there any other driver out there?
I don't remember exactly the version I used. But (IIRC) there was no any checkbox to activate DMA/UDMA in the device manager. And if the driver installed properly the device manager showed the real model of HDD instead of something like "Disc Drive Type 47"
Reply 12 of 16, by sirotkaslo
Finally found the correct version and windows booted after intalling it under safe mode.
    TXPRO.ZIP
    50.56 KiB
    60 downloads
Reply 13 of 16, by biessea
Hi, I found this nice motherboard and it working perfectly.
I have to update this bios, I have the 1998 one, and I wanted to put the 04-02-1999 bios, the last official bios.
Someone know how I could update it? I know that I need a bootable floppy disk, but please where can I find the flasher? I found out that I will need the Amiflash 6.33 but I really can't find one.
Someone has it and could upload here please?
Thanks a lot, I want to put a great AMD K6-2 500 on this baby and Install Windows 98SE making a great retrogaming pc!
Computer lover since 1992.
Love retro-computing, retro-gaming, high-end systems and all about computer-tech.
Love beer, too.
Reply 14 of 16, by biessea
Ok, I have found that utility, simply searching the string on Google "amifl633.zip" that is the correct name of the file.
Then I found a strange site but it made me possibile to download that program, so for you all I upload it here.
On the afternoon I will make the upgrade of the bios and I will let you know If all is gone ok!
    amifl633.zip
    11.22 KiB
    6 downloads
    Amiflash 6.33 bios utility flasher
Love beer, too.
Reply 15 of 16, by biessea
Hey, someone of you could please help me?
After I updated the last bios,
I installed the AMD K6-2, put two sticks of 128mb of RAM for a total of 256mb, and beginning installation of Windows 98SE.
When I use the floppy to start the machine and FDISK the hard drive all gone right.
Then I start the computer with the cd-rom of Windows 98SE but when it enters on the GUI of installation I immediately have this error. How could I resolve it? Someone of you knows what the problem could be?
    387.72 KiB
    error
Love beer, too.
Reply 16 of 16, by biessea
Update: I put another K6-2 (this one is 500mhz and 2,2v.) and it works now perfect.
Probably a bad CPU then, or overheating problems. I don't think it's a RAM problems cause I made a full round of 45minutes of Memtest86 and no errors.
Love beer, too.
