Reply 56080 of 58457, by PcBytes
Trashbytes wrote on 2025-02-12, 15:12:
PcBytes wrote on 2025-02-12, 15:05:
Trashbytes wrote on 2025-02-12, 14:56:
Do you keep all these parts that you repair or do you sell them on to other collectors ?
It seems like you would have quite a few duplicates in your collection by now if you were keeping them all 🤣
No duplicates, they're the same stuff I got from the scrapper earlier in this thread - it just happened to arrive today, and so far the most work that is needed to be done is on the MX300, 5AX (which is far worse than what I had to do to the MX300) and the 5ED which needs some pin re-enforcing. The MSI and DFI appear to be the easiest to fix out of the bunch 🤣
Speaking of which, anyone know or happen to have a MX300 bracket to spare? I've tried the bay but to no avail, it's mostly complete (and pricey) cards. I managed to fix the mangled jacks thanks to a CMI 8738 card, of all things 🤣
If you have to it wouldn't be hard to 3d print a new bracket for that card
That's the thing - I have no other MX300 to use as a reference for printing, nor I could find any STL (or any 3d printing format for that matter) file for it.
Reply 56081 of 58457, by AGP4LIfe?
I picked up this nice scratch free pair of reto Dell speakers from a yard sale for 5$! Love it. 😀 Unfortunately the tower was already missing though 🙁
Who decides what truth is, and what is their objective? Today’s falseness can reappear as tomorrow’s truth.
Reply 56082 of 58457, by Kahenraz
AGP4LIfe? wrote on 2025-02-12, 16:06:
I have an issue with this style of speakers in that they have a tendency to tip over a lot. I'll often bump my speakers or desk and knock them over. I don't know how stable this design is, but wanted to mention it.
Reply 56083 of 58457, by sfryers
A cheap, yellowed early 2000's keyboard:
The attachment IZITK-105M.jpg is no longer available
Wouldn't normally be worth a second glance, except for...
The attachment Buckling Spring keyboard.jpg is no longer available
...the buckling spring mechanism! Hardly an IBM Model-M, but an interesting curiosity nonetheless. Model number is IZITK-105M, apparently manufactured by the Can Technology Co. Ltd., Taiwan.
It has an unusually small spacebar and a Fn key next to the right shift, which can be used to set the repeat rate. Pressing Fn+Print Screen causes it to output the string "eleen enterprise co., ltd. v1.02" to the connected PC.
MT-32 Editor- a timbre editor and patch librarian for Roland MT-32 compatible devices: https://github.com/sfryers/MT32Editor
Reply 56084 of 58457, by dionb
It's Terratec week here 😜
The attachment PXL_20250212_221405476.jpg is no longer available
After my EWS64XXL I spotted this DMX 6Fire being sold cheap as it was missing cables and documentation. Fortunately a regular IDE cable works fine for connecting this card to its breakout box.
Why did I get it? Because it is the one other card that can support the Waldorf microWAVE PC synth. Just one issue: despite being designed specifically for this purpose with two dedicated connectors on the card, Terratec in their great wisdom changed the pinout so you can't just use the cables from the EWS64, you need either a special twisted cable or two adapter connectors supplied with the 6Fire. But missing here...
There are pics of the adapters and even a topic here with some tantalizing hints but no clear pinout/diagram of what needs modding to get it to work. A challenge...
Reply 56085 of 58457, by Thermalwrong
sfryers wrote on 2025-02-12, 21:12:
A cheap, yellowed early 2000's keyboard: […]
What a curious keyboard, normally I'd rate it down because of those power and sleep buttons displacing the keys that regularly go in those spots, but it's buckling spring? With a windows key?
Today I got this little 8" LCD TV from a made-up-brand-from-maplins - I was going to take it apart to get the LCD since it's a 640x480 TFT but it works so well as a mini VGA monitor and composite TV that it's going to get used. It's got a really convenient built-in stand, stereo speakers and it looks nice 😀
Nearly pixel perfect VGA is something I find you generally can't get with analogue VGA screens, like the screen would normally do some awkward scaling, but this one doesn't do too badly at VGA resolution:
The attachment littel 8inch tv (1).JPG is no longer available
It's got some weirdness where getting the vertical position right is though, which is especially bad with 720x400 resolution. It's usable but cuts off quite a lot at the top:
The attachment littel 8inch tv (2).JPG is no longer available
Reply 56086 of 58457, by Trashbytes
Kahenraz wrote on 2025-02-12, 18:25:
Yup, I usually stick them down with some blutack or a little bit of 3M double sided tape with the command strip.
Still hit them hard enough and even this wont stop them falling over.
Reply 56087 of 58457, by Ozzuneoj
Thermalwrong wrote on 2025-02-13, 03:04:
What a curious keyboard, normally I'd rate it down because of those power and sleep buttons displacing the keys that regularly g […]
Oh, that little thing is cool! I can't believe it actually has a VGA input!
Reply 56088 of 58457, by Lennart
dionb wrote on 2025-02-12, 22:25:
It's Terratec week here :P […]
I would love to know the pinout as well, so please let us know whenever you figure it out 😀
Reply 56089 of 58457, by Bondi
Some more PCMCIA goodies.
IBM Smart Capture Card - a video capture card notable for working in DOS.
Quatech Parallel port SPP-100 card - very compatible, has drivers for HP 200LX, DOS, and up to Win XP
TDK DMC9000 - a great sounding MIDI card, finally got a new one to replace my non-working one
The attachment IMG_2614.jpg is no longer available
PCMCIA Sound Cards chart
archive.org: PCMCIA software, manuals, drivers
Reply 56090 of 58457, by PcBytes
-2x GB 5AX, both rev 4.1
- Terratec XLerate AU8820
Both from the same guy that I got the AK70 and Athlon 600 from (along with the dud MX300 and 5AX R5.2), as a way to make up for the defective bits from that previous lot.
Reply 56091 of 58457, by RetroPCCupboard
Core 2 Quad Q9400
4Gb Corsair RAM
ASUS P5N-D motherboard (nForce 750i SLI)
Two Palit 9800 GT 512Mb and SLI bridge
Black LG SATA DVD drive
3.5" Bay flash card reader
Came in PC case with FSP PSU.
Paid £40 delivered for the lot.
Not sure what I will do with it yet.
The attachment 20250214_112154.jpg is no longer available
Reply 56092 of 58457, by dominusprog
RetroPCCupboard wrote on 2025-02-14, 11:40:
Core 2 Quad Q9400 4Gb Corsair RAM ASUS P5N-D motherboard (nForce 750i SLI) Two Palit 9800 GT 512Mb and SLI bridge Black LG SATA […]
Core 2 Quad Q9400
4Gb Corsair RAM
That CPU fan needs some serious cleaning 🧐.
Reply 56093 of 58457, by RetroPCCupboard
dominusprog wrote on 2025-02-14, 12:23:
I am pretty sure that heatsink isn't sufficient for that CPU anyway. 95W TDP. The whole PC smells like an ashtray. Haha. So will need a clean throughout.
Reply 56094 of 58457, by Trashbytes
RetroPCCupboard wrote on 2025-02-14, 12:32:
Ashtray .. yup that's a very hard pass for me, have had to clean a few chain smoker PCs in the past and will never subject my self to that gag fest again.
Chainsmoker + Pet = utter gag fest cleaning fans that have sucked all that in...second only to roach motel PCs. Even offered to replace the fans and cooler but nope they wanted them cleaned to save money ....the new ones would have been cheaper since the cleaning time required for the tainted parts was an extra cost and I had the cooler and fans in the spares bin anyway.
have had to deal with both in the past and refuse to touch such PCs anymore.
Edit - For spelling and clarity
Do smokers know how bad stale nicotine smells to a non smoker ?
Do they know how damn hard it is to clean the matted durrie tar off parts ?
Same for Roach motels ...how do people not notice the roaches crawling out of the PC or the smell ?
Reply 56095 of 58457, by RetroPCCupboard
Trashbytes wrote on 2025-02-14, 12:39:
Possibly wouldn't have bought it if I knew. But seller didn't mention smell. Still, the price is OK I think. Question is, can I be bothered cleaning it. I won't use it as it is now.
Reply 56096 of 58457, by PcBytes
S'more stuff from my contact:
- GA-6BXDS
- OR840
- K6BV3+/66
-MS6156
-GA-6BA
nyehehehe 🤣
Reply 56097 of 58457, by Ozzuneoj
PcBytes wrote on 2025-02-14, 13:54:
S'more stuff from my contact: […]
- GA-6BXDS
- OR840
- K6BV3+/66
-MS6156
-GA-6BA
nyehehehe 🤣
Woa, is this accurate?
https://theretroweb.com/motherboards/s/gigaby … -ga-6bxds#chips
Is says this supports Coppermine-T processors? Maybe I'm having a brain fart but I don't believe that is normal for 440BX boards, let alone ones with dual processor support.
Reply 56098 of 58457, by PcBytes
Doubt it, it's BX after all. Unless they're on an Lin-Lin adapter I guess.
Reply 56099 of 58457, by Trashbytes
Ozzuneoj wrote on 2025-02-14, 13:59:
Woa, is this accurate? https://theretroweb.com/motherboards/s/gigaby … -ga-6bxds#chips […]
- GA-6BXDS
- OR840
- K6BV3+/66
-MS6156
-GA-6BA
nyehehehe 🤣
Its certainly not typical that's for sure but there isn't much difference between CU and CU-T so if it runs one it should run the other, the question is if its official support in the BIOS or not.
My ASUS P2B-DS can run CUmine with slotkets and there are mods to get it to run Tualatin.
