Reply 40 of 66, by StriderTR
- Oldbie
momaka wrote on 2025-03-01, 16:48:Yeah, that's a standard and OK cooler for socket 370. But I'm not surprised it's not handling the 2500+, as that's a 60W TDP CPU […]
Yeah, that's a standard and OK cooler for socket 370. But I'm not surprised it's not handling the 2500+, as that's a 60W TDP CPU (54W idle, 68W load) - almost twice as much as any P3.
All in all, socket 462 CPUs are pretty demanding, given their core is rather small considering the TDP.
If you're not afraid of cobbling something together DIY style (like many people did back in the day 😉 ), a thick copper heat spreader + thermal epoxy (to glue the head spreader onto the CPU) + any large Pentium 4 or full-size s775 heatsink will likely handle that CPU nicely. The tricky part is the mounting.
Heh, who would've thunk these would be in demand again and have such good resale value. 😁
Yeah, I just completely overlooked checking to see if I actually had a good cooler on hand. That was my bad. I was hoping this dinky thing could keep it cool enough to get it all setup, but nope.
I'm actually picking up one of these: https://www.cwc-group.com/mf035032.html for $23 shipped. I don't "need" copper, it's just a preference. I've used ones similar to this and they worked well. To think, all the coolers I tossed over the years... haha
I seriously considered seeing if I could adapt something more modern, but, I just don't have time to work out the mounting. Would be cool though. 😀
On a side note, I picked up a Athlon XP 3000+ for $15, shipped! With 30 day money back! Ran across it over on Amazon Marketplace. Most go for $35 or more over on eBay. It's the KV4E 2100MHz version, not the KV4D with the slightly faster 2167 MHz. clock, but for $15 I can't complain. It's better than the Sempron 2500+ I have now, and I get that 512K L2 vs 256K. Thankfully this MB supports 400MHz FSB since that's what the KV4E needs, the KV4D was 67MHz faster but uses a 333MHz FSB.
Either way, it's coming together. Slower than I wanted, but it is what it is.
I think I'm just going to use this case: https://www.amazon.com/dp/B0CHPRKW18?
I already own one, it houses my home "server". Nice cheap case and I can maybe dress it up with some case stickers/badges to show off it's retro contents. 😜
