First post, by Gopher666
I using this OS in Vmware
(edit by Dominus: link and mention of it removed)
I putting together a minipc dedicated to run just WFW, I was shocked that FreeDOS does not support WFW, after some research I found a thread that compiled with some custom option it might works... well I wont bother but wonder if anybody got it working with FreeDOS 1.3
In case of a physical machine with PCI ports only, what sound card would you recommend? I assume most which has a DOS driver will work in WFW as well
Was there RDP/VNC or any other remote desktop solution for this Windows?
Is this thing supports Extended partitions? It should, when I partition a 4GB CF card with 2GB and 1.7GB FAT16s and the second is Extended logical it does not see it, if both is primary FAT16 all good 😒
Reply 1 of 19, by wierd_w
Please avoid putting non-free OS disk-images up here on VOGONS, there are pretty stringent rules.
Discussion of the OS, pictures of the OS, and the like are all highly encouraged, but distribution of non-free software is a no no.
That said-- The recently released/FOSS'd DR-DOS can run WFW, with some prodding.
Reply 2 of 19, by Jo22
The problem is support for Windows Enhanced-Mode.
Normal Windows 3.1x and WfW 3.10 could be run in Windows Standard-Mode, still.
There used to be a special, experimental build of FreeDOS kernal that supports 386 Enhanced-Mode.
Since 2021 a patch seems to be included but works for normal Windows only (non-WfW 3.11)?
Also, the FreeDOS memory managers don't seem to support GEMMIS so far, the Windows Global EMM Import Specification.
So the himem.sys/emm386.exe supplied with WfW are a better choice.
Btw, there's a setting that might be needed for some versions of FreeDOS.
InDOSPollingMode=True (in system.ini)
More information can be found here:
https://danielectra.github.io/blog/windows-31-on-freedos
https://en.wikipedia.org/wiki/EMM386#Overview
Reply 3 of 19, by VintagePC'sWizard
I used Rufus to install FreeDos then put a USB mouse driver into there (Not CuteMouse *i can't figure out why it does not work* but i used a wired mouse.com thingy but i can't seem to find anywhere after i downloaded it, and i have no idea how to upload it without spending money. If anyone can help with that please tell me) ran setup.exe, Then went though the setup process and It worked! I mean, if you ask me, That's a bit to easy.
Reply 4 of 19, by Gopher666
Please stay on topic, this is strictly Windows for Workgroups discussion. 😁
For those who don't know how many version of this crap was out there: https://casadevall.pro/articles/2020/05/explo … 90s-networking/
  • Windows 3.1
    Windows for Workgroups 3.1
    Windows 3.11
    Windows for Workgroups 3.11
The others keep it to yourself, imo this was the best from the 3.x series due to the stability patches built in networking and if you read the article he will say that this thing is closer to Win95 in codebase than other 3.x es.
Freedos still DON'T support WFW 🙁
For now, FreeDOS 1.4 can't run Windows for Workgroups in enhanced mode, but can run Windows 3.1 in standard mode.
https://www.freedos.org/download/announce.html
Anyway MSDOS 6.22 ain't that bad. Next thing I need is to find a nice PCI card for this.
Reply 5 of 19, by wierd_w
Yes. Freedos does not.
Again, DrDOS was recently open sourced (as SvarDos http://svardos.org/), *AND DOES*.
Reply 6 of 19, by chinny22
Gopher666 wrote on 2025-05-18, 21:25:
Your assumption is pretty much correct. If it supports dos good chance it supports Win3x as well but worth double checking you can find drivers first. Yamaha is probably the default option.
I'm assuming you want to access the Win3x box remotely. Back in the day this was done with paid software like PC Anyware, There is a VNC for dos but remote access seems more trouble then its worth.
http://arcady.chem.anrb.ru/vncdos
Pre WinXP RDP was known as Terminal Server Client, which did have a version for Win3x which can be found on the Win2k Server CD which will allow you to remote ONTO a remote computer but I think doesn't work on anything newer then Vista/2008
Windows relies on dos for HDD layout. can dos see the extended partition? That said I've only used MS Dos and that combinations definitely supports an extended partition with multiple logical drives set up.
Reply 7 of 19, by Jo22
On plain Windows 3.1x, running share.exe is being recommend if multiple files are being opened/closed simultanously.
Windows for Workgroups 3.1x has vshare.386, I think.
Reply 8 of 19, by VintagePC'sWizard
Gopher666 wrote on 2025-05-19, 20:39:
Are you talking about me? If i did, i'm so sorry!
Reply 9 of 19, by Gopher666
wierd_w wrote on 2025-05-19, 21:09:
This new DOS variant is definitely something worth exploring!
Here are my experiences: yes it does run, but only with it's own HIMEM.SYS coming with WFW311 not with the SVARDOS one.
If you use the original one on some machines you run into this issue: https://freedos-user.narkive.com/T0OG1zj9/imp … in-enhaced-mode
Your system.ini file should get a line (below the [386Enh] heading) like:
PageOverCommit=1
For me it says reduce the number under 4 ... tried 1/2/3/4 none works. With it's original himem it works.
The other question was about the sound card: I want to make this box a midi playing station with AudioRack and other goodies, which PCI card had the best Win 3.x support (both driver and provided software wise)?
Reply 10 of 19, by Jo22
Technically speaking, it's also possible to have Windows 3.1x (incl. WfW 3.11) running on Unix/Linux.
Here, the 386 Enhanced-Mode kernal -and only it- runs on the OS kernal, via WABI. No need for DOS, at all.
That way, Program Manager, File Manager and many Windows 3.x applications can be run.
https://en.wikipedia.org/wiki/Wabi_(software)
http://vscojot.free.fr/linux_desktops.html
https://www.youtube.com/watch?v=lnHVYx6Nq6k
https://www.youtube.com/@dreambyte7926/search?query=wabi
Reply 11 of 19, by Majorianus
Wine already has very good support for Win16 applications. WABI with WfW 3.11 installed might have marginally better compatibility, but I doubt you would encounter such apps very often IRL. Besides, WABI is still completely proprietary. Caldera only licensed it from Sun and the latter has never open sourced it. Since development was terminated nearly 30 years ago, Oracle might not even have the sources any more...
Reply 12 of 19, by Jo22
Majorianus wrote on 2025-09-03, 06:14:
+1
Absolutely, your analysis is spot on. 🙂👍
WABI just came to my mind because it did run original Windows 3.1x, along with Program Manager and so on.
WINE or ReactOS are implementations of Windows/Windows API that are much more modern and more capable.
WABI by contrast was from the "old days", just like Merge or once-famous DOSemu.
Way back in the 90s, DOSemu provided DOS compatibility through virtualization of an MS-DOS computer (with Trident VGA card).
It ran a real copy of DOS (FreeDOS etc), but normal Windows 3.x didn't run flawlessly yet.
By using the patched Win-OS/2 from OS/2 it was possible to get Windows going, though.
On Unix workstations, commercial users rather used SoftWindows/SoftWindows 95 maybe. Or WABI, since it was included so often.
Nowadays, DOSBox has replaced DOSemu just like WINE has replaced WABI.
(There's DOSemu2, but I have no experience of it yet.)
What's cool about DOSBox, though, is is ability to boot an actual operating system (like DOSemu formerly).
So it's possible to boot into, say, DOS 2.x or MS-DOS 6.2. Or Windows 9x. 🙂
Reply 13 of 19, by Majorianus
One unusual, interesting and perhaps even marginally useful way to run some Win16 or Win32 apps in actual MS-DOS or compatible DOS running on plain metal is the HX DOS extender. It has an extension that emulates the most important Windows libraries and APIs (GDI & DirectDraw) so that it can run single window Windows apps. They have to be just single window though, since it doesn't emulate window management in any way. It was written by Japheth of the Jemm etc. enhanced DOS memory manager fame.
I actually haven't tried it yet and I don't have a "real" use case, but interesting it is that someone has managed to code something like that. It is still maintained, although I don't think new features are coming any time soon. Extending it to full Windows emulation would be too much work and not really useful, since like you wrote, ReactOS or Linux + WINE already provide that pretty well for "old" Windows versions. Besides, you can't run DOS on plain metal on the latest systems anyway, because many of them no longer have CSM. As far as I know there is no way to boot DOS without legacy BIOS.
Reply 14 of 19, by Jo22
^Hi, yes, a few applications do run on HX: Re: DirectDraw or DirectX porting to Windows 3.1+Win32s possible ?
Reply 15 of 19, by eliot_new
I have a question from a pure gamer's perspective:
Does WfW 3.11 have any relevance for any games or is it sufficent to have a DOS/Win9x dual boot system?
I m asking this, because I m curious to discover how it is to have a dual boot system and want to decide whether to choose MSDOS 6.22 or FreeDOS 1.4?
DOS:K6-3/400,192MB,P5A,Rendition v2200 AGP,Trio64 PCI,3dfx V1,AWE64,ESS1938,PicoGUS,32GB
w98SE:P3/450,768MB,QDI440BX,V3AGP,AWE64,PicoGUS,80GB
wXP:P3/1G,512MB,CUSL2-C,MSIFX5600,Audigy1,80GB
Reply 16 of 19, by keenmaster486
There are certain games that run in Win31, but nothing graphically intensive and afaik next to nothing that won’t run in Win9x. There are other threads about Win31 games though. It’s kind of a niche topic, almost a novelty.
World's foremost 486 enjoyer.
Reply 17 of 19, by maxtherabbit
My favourite "wingame" mahjong (MJWIN.EXE) only has functional beep speaker sound in windows 3.x. The game plays fine in 9x (and even modern windows) but without the sound
Reply 18 of 19, by Jo22
Some of my favorite childhood games with speaker sound were Jiji and WinTrek.
If I remember correctly, some of the i/o drivers for Windows NT helped to get back pc speaker sound in Windows on Windows. PortTalk or GiveIO (?), I think.
Then there's VDMSound, of course, which was made to fix NTVDM (WoW runs on top of it). Not sure if it enhances pc speaker support, though.
Edit:
It depends.. Windows 3.1x games relying on Video for Windows, 16-Bit QuickTime or WinG might run better on Windows 3.1x (esp. 16-Bit QuickTime was unstable on Win 95).
Early Win32 games made with Win32s extension in mind might have less issues on Windows 3.1x.
Some Win31/Win32s games using a lot of GDI resources might run out of heap memory on Windows 95.
Windows 3.1x+Win32s being a hybrid systen had allowed mixing 16-Bit und 32-Bit DLLs, Windows 9x/NT didn't allow this special case.
Not sure if important, though.
Games using 256c and palettes might run better on Windows 3.1x, with a 256c driver.
Some games which go "full-screen" (pseudo full-screen on 3.x) might be interferred with by the then-new Windows 95 taskbar.
DCI requires Windows 3.1x or Windows 3.1x drivers (on Windows 95). A DCI32 was planned but never finished.
Edit: That being said, most games should run "okay" on Windows 95 or 98.
Merely the truely old Windows 1.x and 2.x games that would show a compatibility warning on Windows 3.x won't run on Windows 95+ anymore.
They have to be patched before Windows 9x can run them.
Reply 19 of 19, by wbahnassi
For PCI sound cards and Win3.11, my experience is that DOS drivers aren't enough to make the card work under Windows. You will need dedicated drivers for the card for Win3.11. I'd advise finding out which PCI sound cards had Win3.11 drivers, then go from there. My YMF-744 has good DOS drivers but only Win9x drivers, no Win3.11. I believe you'll need to look for older PCI sound cards to have a chance.
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
