First post, by Gopher666
I using this OS in Vmware
(edit by Dominus: link and mention of it removed)
I putting together a minipc dedicated to run just WFW, I was shocked that FreeDOS does not support WFW, after some research I found a thread that compiled with some custom option it might works... well I wont bother but wonder if anybody got it working with FreeDOS 1.3
In case of a physical machine with PCI ports only, what sound card would you recommend? I assume most which has a DOS driver will work in WFW as well
Was there RDP/VNC or any other remote desktop solution for this Windows?
Is this thing supports Extended partitions? It should, when I partition a 4GB CF card with 2GB and 1.7GB FAT16s and the second is Extended logical it does not see it, if both is primary FAT16 all good 😒
Reply 1 of 10, by wierd_w
Please avoid putting non-free OS disk-images up here on VOGONS, there are pretty stringent rules.
Discussion of the OS, pictures of the OS, and the like are all highly encouraged, but distribution of non-free software is a no no.
That said-- The recently released/FOSS'd DR-DOS can run WFW, with some prodding.
Reply 2 of 10, by Jo22
The problem is support for Windows Enhanced-Mode.
Normal Windows 3.1x and WfW 3.10 could be run in Windows Standard-Mode, still.
There used to be a special, experimental build of FreeDOS kernal that supports 386 Enhanced-Mode.
Since 2021 a patch seems to be included but works for normal Windows only (non-WfW 3.11)?
Also, the FreeDOS memory managers don't seem to support GEMMIS so far, the Windows Global EMM Import Specification.
So the himem.sys/emm386.exe supplied with WfW are a better choice.
Btw, there's a setting that might be needed for some versions of FreeDOS.
InDOSPollingMode=True (in system.ini)
More information can be found here:
https://danielectra.github.io/blog/windows-31-on-freedos
https://en.wikipedia.org/wiki/EMM386#Overview
Reply 3 of 10, by VintagePC'sWizard
I used Rufus to install FreeDos then put a USB mouse driver into there (Not CuteMouse *i can't figure out why it does not work* but i used a wired mouse.com thingy but i can't seem to find anywhere after i downloaded it, and i have no idea how to upload it without spending money. If anyone can help with that please tell me) ran setup.exe, Then went though the setup process and It worked! I mean, if you ask me, That's a bit to easy.
Reply 4 of 10, by Gopher666
Please stay on topic, this is strictly Windows for Workgroups discussion. 😁
For those who don't know how many version of this crap was out there: https://casadevall.pro/articles/2020/05/explo … 90s-networking/
  • Windows 3.1
    Windows for Workgroups 3.1
    Windows 3.11
    Windows for Workgroups 3.11
The others keep it to yourself, imo this was the best from the 3.x series due to the stability patches built in networking and if you read the article he will say that this thing is closer to Win95 in codebase than other 3.x es.
Freedos still DON'T support WFW 🙁
For now, FreeDOS 1.4 can't run Windows for Workgroups in enhanced mode, but can run Windows 3.1 in standard mode.
https://www.freedos.org/download/announce.html
Anyway MSDOS 6.22 ain't that bad. Next thing I need is to find a nice PCI card for this.
Reply 5 of 10, by wierd_w
Yes. Freedos does not.
Again, DrDOS was recently open sourced (as SvarDos http://svardos.org/), *AND DOES*.
Reply 6 of 10, by chinny22
Gopher666 wrote on 2025-05-18, 21:25:
Your assumption is pretty much correct. If it supports dos good chance it supports Win3x as well but worth double checking you can find drivers first. Yamaha is probably the default option.
I'm assuming you want to access the Win3x box remotely. Back in the day this was done with paid software like PC Anyware, There is a VNC for dos but remote access seems more trouble then its worth.
http://arcady.chem.anrb.ru/vncdos
Pre WinXP RDP was known as Terminal Server Client, which did have a version for Win3x which can be found on the Win2k Server CD which will allow you to remote ONTO a remote computer but I think doesn't work on anything newer then Vista/2008
Windows relies on dos for HDD layout. can dos see the extended partition? That said I've only used MS Dos and that combinations definitely supports an extended partition with multiple logical drives set up.
Reply 7 of 10, by Jo22
On plain Windows 3.1x, running share.exe is being recommend if multiple files are being opened/closed simultanously.
Windows for Workgroups 3.1x has vshare.386, I think.
Reply 8 of 10, by VintagePC'sWizard
Gopher666 wrote on 2025-05-19, 20:39:
Are you talking about me? If i did, i'm so sorry!
Reply 9 of 10, by Gopher666
wierd_w wrote on 2025-05-19, 21:09:
This new DOS variant is definitely something worth exploring!
Here are my experiences: yes it does run, but only with it's own HIMEM.SYS coming with WFW311 not with the SVARDOS one.
If you use the original one on some machines you run into this issue: https://freedos-user.narkive.com/T0OG1zj9/imp … in-enhaced-mode
Your system.ini file should get a line (below the [386Enh] heading) like:
PageOverCommit=1
For me it says reduce the number under 4 ... tried 1/2/3/4 none works. With it's original himem it works.
The other question was about the sound card: I want to make this box a midi playing station with AudioRack and other goodies, which PCI card had the best Win 3.x support (both driver and provided software wise)?
Reply 10 of 10, by Jo22
Technically speaking, it's also possible to have Windows 3.1x (incl. WfW 3.11) running on Unix/Linux.
Here, the 386 Enhanced-Mode kernal -and only it- runs on the OS kernal, via WABI. No need for DOS, at all.
That way, Program Manager, File Manager and many Windows 3.x applications can be run.
https://en.wikipedia.org/wiki/Wabi_(software)
http://vscojot.free.fr/linux_desktops.html
https://www.youtube.com/watch?v=lnHVYx6Nq6k
https://www.youtube.com/@dreambyte7926/search?query=wabi
