Majorianus wrote on 2025-09-03, 06:14:
Wine already has very good support for Win16 applications. WABI with WfW 3.11 installed might have marginally better compatibility, but I doubt you would encounter such apps very often IRL. Besides, WABI is still completely proprietary. Caldera only licensed it from Sun and the latter has never open sourced it. Since development was terminated nearly 30 years ago, Oracle might not even have the sources any more...
+1
Absolutely, your analysis is spot on. 🙂👍
WABI just came to my mind because it did run original Windows 3.1x, along with Program Manager and so on.
WINE or ReactOS are implementations of Windows/Windows API that are much more modern and more capable.
WABI by contrast was from the "old days", just like Merge or once-famous DOSemu.
Way back in the 90s, DOSemu provided DOS compatibility through virtualization of an MS-DOS computer (with Trident VGA card).
It ran a real copy of DOS (FreeDOS etc), but normal Windows 3.x didn't run flawlessly yet.
By using the patched Win-OS/2 from OS/2 it was possible to get Windows going, though.
On Unix workstations, commercial users rather used SoftWindows/SoftWindows 95 maybe. Or WABI, since it was included so often.
Nowadays, DOSBox has replaced DOSemu just like WINE has replaced WABI.
(There's DOSemu2, but I have no experience of it yet.)
What's cool about DOSBox, though, is is ability to boot an actual operating system (like DOSemu formerly).
So it's possible to boot into, say, DOS 2.x or MS-DOS 6.2. Or Windows 9x. 🙂
