Reply 60 of 62, by luckybob
- l33t++
Jackhead wrote on Yesterday, 10:08:I found another SL49P that would match my first CPU. Will get it in the next days. Till than i tested that dummy cpu that comes […]
I found another SL49P that would match my first CPU. Will get it in the next days. Till than i tested that dummy cpu that comes with my board.
Installed win2k on a SSD over a flashed SIL3114 sata controller. System runs really fast with single core alone.
Not sure its because the 2GB RAM or the 1MB L2, but definitely faster as a Slot1 P3 with W2k.
Here a picture of HWinfo on the mashine. Still not installed the voodoo. I want first the CPU setup finished.
Maybe i found some day a SL4XY pair..
Honestly W2k is an under-rated operating system. its like a lean version of XP.
But the best thing for speed is the sata ssd. The ram also helps, but 2k will fly on anything with >256mb of ram. Even using pentium pro chips, the system feels good with 2K. provided you have the ram. ^.^
I would not worry about TRIM for the SSD - unless you are planning on using this machine every day, its not an issue. You can just keep a backup image of the drive if the worst happens, but honestly its a 1 in a million chance if you are using a quality name brand SSD.
