Reply 56840 of 57996, by PD2JK
clownwolf wrote on 2025-05-23, 10:11:
Got a Gainbery P120 Upgrade CPU for socket 4. While I am happy to have it, there's not much use-case for retro computing. In my opinion the point of using a Socket 4 is to use the P60 or P66 after all.
The attachment 20250523_025553.jpg is no longer available
It's nevertheless an interesting piece of hardware which I've never heard of. Did they make their own core or is it some Cyrix/AMD/you-name-it deriative?
And is it about twice as fast compared to the first gen Pentium?
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 56841 of 57996, by fosterwj03
I received the Gigabyte Z370 HD3P I bought as a potential vanilla Windows 2000 retro rocket (and to multi-boot XP, Vista, and 7). I only had time to set up the board on a test bench for a quick test with an i5-8400 and 8GB of DDR4. For those interested in using newer Gigabyte boards with Windows 2000, I can confirm that this board has a MPS implementation compatible with Windows 2000.
Unfortunately, Windows 2000 didn't detect any of the PCI or PCIE devices in the expansion slots on the first boot (with the exception of the video card) , just like my experience with an Asus H310-Plus board. I kind of expected this since I haven't tweaked the UEFI settings yet. I also need to try adding a NVMe drive which allowed Windows 2000 to detect peripherals on my H310 board.
I also messed up the device detection on my Windows 2000 install and didn't set up AHCI controller support correctly. Now the drive won't boot. I'll need to re-image the drive and prep it for MPS and generic AHCI before doing more testing.
Reply 56842 of 57996, by gerry
you said that like you didnt want to give "your existing pentium 60/66 mhz system advanced power and performance" 😀
Still, it is interesting and i guess i couldn't resist comparing speeds with various benchmarks just to see
It's from an interesting time, when getting some small increase in cpu speed could yield a big proportional difference in experience while avoiding buying a new pc
Reply 56843 of 57996, by PC Hoarder Patrol
gerry wrote on 2025-05-23, 14:21:
you said that like you didnt want to give "your existing pentium 60/66 mhz system advanced power and performance" :) […]
They did have a benchmark page... https://web.archive.org/web/19961105030738/ht … om/686bench.htm
Reply 56844 of 57996, by devius
AGP4LIfe? wrote on 2025-05-22, 21:46:
Hmmm I'm confused becuase unless im reading the data sheet wrong these are 4MB chips x 8 on the card for a total of 32MB's of ram.
Whoops! Not sure why I thought it was a 64MB card... 🤦 Sorry for the incorrect information.
Reply 56845 of 57996, by Major Jackyl
Bought a box of junk at a garage sale. This was in the box:
The attachment 20250521_211118.jpg is no longer available
The attachment 20250521_211128.jpg is no longer available
I also grabbed this guy:
The attachment 20250523_204035.jpg is no longer available
It had all the parts, so I figured it would be fun. It takes full-size VHS, so I can actually play with this one if it works.
Main Loadout (daily drivers):
Intel TE430VX, Pentium Sy022 (133), Cirrus Logic 5440, SB16 CT1740
ECS K7S5A, A-XP1600+, MSI R9550
ASUS M2N-E, A64X2-4600+, PNY GTX670, SB X-Fi Elite Pro
MSI Z690, Intel 12900K, MSI RTX3090, SB AE-7
Reply 56846 of 57996, by clownwolf
PD2JK wrote on 2025-05-23, 11:14:
I'll test the P60, P66 and P120 upgrade now and post the results on a new thread.
Actually I didnt need to test the P60 or P66, System Information already has P66 as a reference score. Also, this looks to be an actual P120 CPU they used. But cant be too sure unless I take the heatsink off, which is secured firmly.
Results show the Gainbery P120 upgrade as 80% faster than the P66 as per SysInfo 8.0, and a 25 FPS average on Doom Max Details Quake.
EDIT: I tried running tests again, buy SysInfo 8.0 no longer works. I am getting divide overflow error. I added a new screenshot for Speedsys 4.78 instead.
SysInfo 8.0
The attachment 20250523_205300.jpg is no longer available
SysInfo 8.0
The attachment 20250523_205217.jpg is no longer available
The attachment 20250523_204754.jpg is no longer available
Batman's Revenge Socket 4 Motherboard
The attachment 20250523_205116.jpg is no longer available
Speedsys 4.78
The attachment 20250524_004456.jpg is no longer available
Reply 56847 of 57996, by nhattu1986
My purchased arrived this week after a very long searching and fighting.
It this guy:
The attachment 25-05-22 20-37-30 2101.jpg is no longer available
It work fine for both midi and pcm audio, i'm playing around with its mixer.
Reply 56848 of 57996, by devius
Probably the sound card with the biggest chips ever.
Reply 56849 of 57996, by TheMLGladiator
PcBytes wrote on 2025-05-22, 16:35:
Good thing: I got a P2B-DS
Bad thing: It keeps resetting if I have two CPUs installed. It'll get as far as doing the usual beep then it automatically restarts. BIOS doesn't look retail (VMP in the Sign-On string instead of "ASUS P2B-DS ACPI BIOS Revision nnnn").
Other than that... couldn't get the P3B-F working. Bits und Bolts' videos didn't help either.
I'm pretty sure that the P2B-DS only supports the Pentium 2 and Pentium 3 Katmai CPUs. It does not support Coppermine. I believe early versions of the P3B-F are the same way. Either way, I would start with testing them with the previously mentioned CPUs. If that works and the board seems to be stable, then upgrade the bios to the latest version before installing the Coppermine.
Here is more information on these boards and their CPU compatibility:
https://web.archive.org/web/20180205052849/ht … pgrade_faq.html
Reply 56850 of 57996, by Trashbytes
TheMLGladiator wrote on 2025-05-24, 19:57:
I'm pretty sure that the P2B-DS only supports the Pentium 2 and Pentium 3 Katmai CPUs. It does not support Coppermine. I believe […]
v1.06 does support Copper mine and Tualatin with an adapter prior to v1.06 it depends on if your board can supply the correct voltage, some v1.04 boards can others can be modded to do so with caveats.
I have a P2B-DS 1.06 that has a pair of 1Ghz Copper mines running in it via slotket adapter cards, but I also have a pair of 933Mhz slot 1 copper mine cpus that also work in it just fine.
The P3B-F is much the same later revisions will run Cu and Tualatin with adapters while earlier ones lack the ability to provide correct voltages but can be modded to do so.
https://theretroweb.com/motherboard/manual/th … 4f905496897.pdf
here is a rather comprehensive guide from the Retro Web about it.
Both the P2b-F/DS and P3B-F are highly moddable depending on the version you own, tons of info about them and likely a ton of modded BIOSes out the for them.
Reply 56851 of 57996, by PcBytes
P2B-DS is Rev 1.05, PCBA D04, and uses HIP6004BCB so Coppermine support is existent. Same for P3B-F. P2B-DS will POST stable in single CPU configuration using 650MHz SL3XK. Dual CPU configuration is unstable with 2x SL3XK, same CPU set works fine and stable on Gigabyte GA-6BXDU.
P3B-F has been tested with various CPUs and all with same result - C0 and two dashes no matter the CPU used.
- Celeron 300A SL2WM
- Celeron 366 SL36B
- Katmai 500 SL37D
- Coppermine 650 SL3XK
- Coppermine 866 SL4CB
- Coppermine 1GHz SL52R
- Coppermine 1GHz SL4C8
I have since gave up on the P3B-F in favor of a BX2000+ that I suspect of having a completely corrupt BIOS IC. I only get two dashes on the POST card but the LEDs do have a specific cycle I have discovered to be specific to BX2000 (both standard and plus). That, and it seems to be fairly common to corrupt - both the standard BX2000 seem to trigger a "WIDE RANGE PROTECTION ERROR" message.
Reply 56852 of 57996, by dominusprog
Bought this Chikony keyboard. It's came in a very good condition for the most part. I opened it up and give it a good wash and retrobright the cable using a pot and stove (thanks David 🙂). Also replaced two electrolytic caps and the green LEDs with matte red ones 😁.
The attachment 20250525_153631.jpg is no longer available
The attachment 20250524_015407.jpg is no longer available
Reply 56853 of 57996, by AGP4LIfe?
devius wrote on 2025-05-23, 18:24:
Haha no worries, just trying to get my info straight! I'm assuming Trashbytes made the same mistake, Unless his Ram looks Different.
Who decides what truth is, and what is their objective? Today’s falseness can reappear as tomorrow’s truth.
Reply 56854 of 57996, by dionb
Major Jackyl wrote on 2025-05-24, 01:51:
LCS? That's Longshine. And it's ST-506, but RLL, not MFM: https://stason.org/TULARC/pc/hard-disk-floppy … -RLL-drive.html
Reply 56855 of 57996, by Trashbytes
AGP4LIfe? wrote on 2025-05-25, 20:35:
My 256 ?
Its a 64Mb DDR, the SGram version doesn't look much different from the DDR model which is understandable since they use the same PCB. The pic I posted wasnt mine but just a refference photo from Techpowerup so if the photo is wring .. its on them 🤣.
Reply 56856 of 57996, by vstrakh
Bought this Tekram DC-600CF HDD cache and RAID-0 controller, plus floppy controller. The state is unknown/untested.
It's not that I'd use it now with CF cards, but I couldn't pass by this artifact. Harris 286 CPU onboard 😀
The attachment DC-600CF.jpg is no longer available
Reply 56857 of 57996, by PD2JK
vstrakh wrote on 2025-05-28, 11:02:
Interesting! They used a CISC processor for offloading I/O and the card seems low profile. Maybe for 1U/2U rackmount server use?
Reply 56858 of 57996, by Kahenraz
I think that this would have been more relevant for disks that were contemporary for the time. A single CompactFlash card (non-RAID) already can ceasily max out these older disk controllers. The ISA bus that this is on is also going to be a limiting factor.
Reply 56859 of 57996, by Mandrew
Bought a pack of lightscribe DVDs before they disappear like lightscribe CDs did.
