PD2JK wrote on 2025-05-23, 11:14:clownwolf wrote on 2025-05-23, 10:11:
Got a Gainbery P120 Upgrade CPU for socket 4. While I am happy to have it, there's not much use-case for retro computing. In my opinion the point of using a Socket 4 is to use the P60 or P66 after all.
The attachment 20250523_025553.jpg is no longer available
It's nevertheless an interesting piece of hardware which I've never heard of. Did they make their own core or is it some Cyrix/AMD/you-name-it deriative?
And is it about twice as fast compared to the first gen Pentium?
gerry wrote on 2025-05-23, 14:21:you said that like you didnt want to give "your existing pentium 60/66 mhz system advanced power and performance" :) […]
you said that like you didnt want to give "your existing pentium 60/66 mhz system advanced power and performance" 😀
Still, it is interesting and i guess i couldn't resist comparing speeds with various benchmarks just to see
It's from an interesting time, when getting some small increase in cpu speed could yield a big proportional difference in experience while avoiding buying a new pc
I'll test the P60, P66 and P120 upgrade now and post the results on a new thread.
Actually I didnt need to test the P60 or P66, System Information already has P66 as a reference score. Also, this looks to be an actual P120 CPU they used. But cant be too sure unless I take the heatsink off, which is secured firmly.
Results show the Gainbery P120 upgrade as 80% faster than the P66 as per SysInfo 8.0, and a 25 FPS average on Doom Max Details Quake.
EDIT: I tried running tests again, buy SysInfo 8.0 no longer works. I am getting divide overflow error. I added a new screenshot for Speedsys 4.78 instead.
SysInfo 8.0
The attachment 20250523_205300.jpg is no longer available
SysInfo 8.0
The attachment 20250523_205217.jpg is no longer available
The attachment 20250523_204754.jpg is no longer available
Batman's Revenge Socket 4 Motherboard
The attachment 20250523_205116.jpg is no longer available
Speedsys 4.78
The attachment 20250524_004456.jpg is no longer available
