Reply 1360 of 1395, by MikeSG
I updated the interposer I'm working on to better suit all 486 CPUs, and updated the PGA-168 press-fit holes on the PCB. Currently saving up for another prototype.
Having long-suffering problems with the press-fit socket and the PCB finish. I think I have it worked out though and need at least one more prototype run.
List of changes:
LT1573 voltage regulator & MJD45H11 PNP
Removed NA# jumper and added NA# solder-jumper to reverse side.
Added FLUSH# logic (MEMW AND'd with inverted HLDA) to suit both TI486SXL and 486SX/DX.
Added solder-jumpers for R17 & B13 to GND (for CLKMUL#). 20k pullup to 5v for R17.
Added 20k pullup to 5v for FLT#/UP#/RESERVED# (C11). Specified for intel CPUs.
Added 20k pullup to 5v for DP0-DP3 (N3, F1, H3, A5).
Smoothed CLK/CLK2 lines and reduced travel distance
Reduced PGA-168 holes from 1.15 to 1.0
Cosmetic changes
