tehsiggi wrote on 2025-06-24, 05:13:
I think it's the other way around. Backside pins are named A, front side are named B (don't get me started 😁).
But yeah, I assume they'll both be ground, so probably not your main issue.
Yup .. fixed that ...
But yes its not the issue ..the card isn't detected on the PCI bus, no tool I have can find it so there is a power issue there as the card isn't powering up, even with a dead BIOS the card should still be detected on the PCi bus.
So my next step will be to poke at the mosfet and regulator, my card is identical to the image below.
The attachment front.jpg is no longer available
The regulator on the heat sink will be the first to get the poke followed by the fet down near the edge connector, IIRC its normally the regulator that dies on these cards. (I think its a fet on the heatsink and the regulator is the one near the edge connector, shrug they both get the poke)
