Reply 29800 of 30561, by tehsiggi
I am not disappointed in the overall result.. Got a cheap proper mobo for my testing.
I ordered the right polyfuse and will put it back in, even though I'll never use the firewire ports anyway.
The PCI slot may stay or be replaced.. I'll just order some for good measure and then see how i feel.
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 29801 of 30561, by Trashbytes
Well I have some news on my dead Voodoo3 PCI card, seems its problem is a burnt out finger on the PCI connector, not 100% sure what this finger is for but I assume its part of the power delivery for the card. The card did get warm when I initially went to test it and its totally undetected by the system.
The attachment Burnt Finger.jpg is no longer available
Doesn't bode well for the card itself and I'm not sure how to repair this kind of damage in a way that's more permanent or what caused the finger to be burnt off. Have done a little scratching and the finger is totally gone, there isnt anything to solder to rebuild a finger.
Reply 29802 of 30561, by PcBytes
If you have a spare finger to stick on there, you can scrape the via leading to it and solder the new finger to that via.
Although you'll have to secure the finger down and that... idk how you'd go around doing it.
Reply 29803 of 30561, by Thermalwrong
Trashbytes wrote on 2025-06-23, 20:38:
I've done a repair of a missing pad before, took a PCI modem and cut off the pci pad with a sharp blade. Then superglued the pad into place and soldered a wire to it: Re: What retro activity did you get up to today?
Thermalwrong wrote on 2023-12-12, 23:45:
I think it's finally time for me to put away the hot air station - I've now broken the Elsa Victory II enough that one of the memory data lines is just broken. I mean I was fixing corrosion but with hindsight I can say that drilling through the PCB to run new traces through was a terrible idea. I didn't notice until after I'd drilled those holes that the PCB is 6-layer and some of the data traces route internally, or they did until I started on it. Maybe I'll fix that in the future but it's going away for a while now - repairing a Banshee card is tricky business since there isn't the plethora of information like there is for the Voodoo 1 and Voodoo 3 cards.
The attachment IMG_2750 (Custom).JPG is no longer available
I got one card to actually post once after reflowing it so thought I'd have a go at reflowing or removing the GPU of this PCI Voodoo Banshee - I had thought its GPU was fried since there were missing pads and traces on the PCI slot which I repaired but it would never run, just gave the no video card detected beeps.
That card actually works now since its main fault was a BGA connection issue.
I wonder why it seems like only 3dfx voodoo PCI cards can have burned out pci pins? I suppose it's a survivorship bias since they're the only broken old PCI cards worth enough to not scrap, but I suspect maybe they got fitted into an incorrect port type at some point for this to happen.
Good news for you though, that is just a ground pin (A18 by my count) and there are lots of those on the PCI connector, all you really need to do is clean up any burnt PCB to ensure it's not conductive to the adjacent pads.
Reply 29804 of 30561, by Trashbytes
Thermalwrong wrote on 2025-06-24, 01:15:
I've done a repair of a missing pad before, took a PCI modem and cut off the pci pad with a sharp blade. Then superglued the pad […]
Yeah I've been pondering a good way to repair the damage that will last, your idea will work ok if I put it in a system and just leave it there. More concerning is what caused the initial damage, that pin doesn't seem to connect to either of the voltage regulators on the card but I might be missing something and it does actually find its way to the regulator. Since I don't have a ton of experience at fixing 3dfx cards this repair will have some ...winging it involved but Ill be checking the mosfets and caps before it gets put back in a board.
Edit - did more investigation and this burnt pin connects to the via above it which connects directly to the third pin on the opposite side of the edge connector via that via...it goes nowhere else, so perhaps these two pins are shorted together on purpose and do nothing.
I need to find out what the fingers do on the PCI slot. (Just checked and both are unused by the PCI bus so that explains why they are shorted together)
Reply 29805 of 30561, by bofh.fromhell
tehsiggi wrote on 2025-06-23, 18:30:
I recently snacked a EPOX 9NDA3+ from ebay. It was listed as broken. […]
I was on the lookout for a good 939 AGP board and nForce3 was really nice to have.
So today I took care of it and got it working. Turns out we have an exploded polyfuse in the Firewire section - that's what I call irony!
I removed the burned part and cleaned everything. The PCI slot will need replacement if it is ought to look like new again at some point. But so far - the board works just fine and will be my primary testing platform from now on.
Here are some pictures of FireWire with burnout!
Those are sweet MB's!
Mine is now rocking an x2 4400+ under a Wraith Prism cooler, keeps it barely over room temp =)
Reply 29806 of 30561, by tehsiggi
Trashbytes wrote on 2025-06-24, 01:40:
I'm wondering. I the orientation is correct, the missing pin is A18 and therefore GND. If it is going to the third pin from the edge on the opposite side of the connector, it would short with the clock signal. Not sure if that's supposed to be that way 😉
bofh.fromhell wrote on 2025-06-24, 03:09:
I moved over my X2 3800 and 2GB RAM onto that board now. Together with a Samsung EVO 840 I'm able to leverage that sweet onboard SATA. My old platform (MS-7075) had a K8T800 with the SATA bug, meaning it only detects SATA I drives and nothing else. This now works so much better now. Back in the day I would have OC'ed the snot out of it with such a nice board. But for today I'll leave it humming at default and be happy with it.
Reply 29807 of 30561, by Trashbytes
tehsiggi wrote on 2025-06-24, 05:02:
I'm wondering. I the orientation is correct, the missing pin is A18 and therefore GND. If it is going to the third pin from the […]
Yes my bad its pin B17 on the front and A18 on the back counting from the face plate, both are listed as Unconnected/ground in the docs I have here.
A18 is the missing one and its connected to B17 via the via.
https://wiki.attie.co.uk/wiki/PCI_pinout
is what I used to determine pin out.
Reply 29808 of 30561, by tehsiggi
I think it's the other way around. Backside pins are named A, front side are named B (don't get me started 😁).
But yeah, I assume they'll both be ground, so probably not your main issue.
Reply 29809 of 30561, by Trashbytes
tehsiggi wrote on 2025-06-24, 05:13:
Yup .. fixed that ...
But yes its not the issue ..the card isn't detected on the PCI bus, no tool I have can find it so there is a power issue there as the card isn't powering up, even with a dead BIOS the card should still be detected on the PCi bus.
So my next step will be to poke at the mosfet and regulator, my card is identical to the image below.
The attachment front.jpg is no longer available
The regulator on the heat sink will be the first to get the poke followed by the fet down near the edge connector, IIRC its normally the regulator that dies on these cards. (I think its a fet on the heatsink and the regulator is the one near the edge connector, shrug they both get the poke)
Reply 29810 of 30561, by ChrisK
Not quite sure atm but I think both are linear regulators. The one with the heatsink should make 3.3V for I/O, memory, etc. and the one near the slot is for V_core of the Voodoo chip, so something around 2.xx volts iirc. Look for datasheets/pinouts of these to better troubleshoot them.
RetroPC: K6-III+/400ATZ @6x83@1.7V / CT-5SIM / 2x 64M SDR / 40G HDD / RIVA TNT / V2 SLI / CT4520
ModernPC: Phenom II 910e @ 3GHz / ALiveDual-eSATA2 / 4x 2GB DDR-II / 512G SSD / 750G HDD / RX470
Reply 29811 of 30561, by Trashbytes
ChrisK wrote on 2025-06-24, 06:37:
Fingers crossed the one near the core has not failed and sent too much voltage to the core, the card did get fairly warm when I was testing it.
Reply 29812 of 30561, by bakemono
Anyone know what the deal is with this laptop ZIF socket 7? I assume there is some way to lock it closed after the CPU goes in, but can't see how.
GBAJAM 2024 submission on itch: https://90soft90.itch.io/wreckage
Reply 29813 of 30561, by ChrisK
Looks like there's something missing.
Something like a top cover plate of the socket.
Was there a CPU installed when you got it?
Reply 29814 of 30561, by BitWrangler
Could be less ZIF, more LIF with those threaded inserts being used to strap the CPU down.
Reply 29815 of 30561, by myne
Yeah. Looks like that's likely. Hold it down with the heat pipe
I built:
Reply 29816 of 30561, by bofh.fromhell
bakemono wrote on 2025-06-26, 12:03:
Tech Tangents "Tiny Pentium" MB has the same socket type:
https://youtu.be/8D0k8zXNv28?t=451
Seems that yours is missing the cover =/
It could possibly work by shoving the CPU to the side then locking it down with a toothpick or something, and holding it in place with the HS =)
Reply 29817 of 30561, by keropi
that socket is complete and nothing missing , this is a low-profile socket and the cooling solution is mounted directly to the socket via the 2 screw terminals that it has
you are supposed to drop the cpu in the socket and you push the whole cpu either up or down to lock/release
the 2 spots I have marked are meant to be used as points where you insert something like a flat head screwdriver and slowly push the cpu , one spot is used to lock the cpu the other to release it - they should have writing on them so you will know which is which
you can see the same socket on the Datavan DTV-07C system: https://theretroweb.com/motherboards/s/datava … nternat-dtv-07c , this is how I found out about this kind of socket, never seen it before
I hope the pics make it clear what you are supposed to do, also added a close-up of the pins inside - this is what made me realize how this socket works 🤣
Reply 29818 of 30561, by kinetix
I managed to get an MSX motherboard working, after restoring several missing components and checking others and replacing the defective ones, the CPU, a RAM chip and a VRAM chip. Before I got a replacement video chip but it had no problems, and in the analysis of the defect I came to think that a PAL that unified the functions of several ICs of the MSX1 standard circuit was defective but luckily it was not like that, I was already planning to make this complete circuit (about 4 ICs) and replace the PAL. Now I must reduce some noise in the video signal, and adapt or make a keyboard
Reply 29819 of 30561, by PcBytes
Rebuilt broken RAM clips on a Soltek SL-75KAV.
