Reply 20 of 42, by RetroPCCupboard
Decivox wrote on 2025-07-28, 15:06:Ive been a long time lurker and gained a lot of knowledge in the process, so wanted to introduce myself and my build that I comp […]
Ive been a long time lurker and gained a lot of knowledge in the process, so wanted to introduce myself and my build that I completed thanks to what I've learned here, elsewhere, and through some trial and error.
Intro:
Originally I wanted to get a 98 era pre-build from a manufacturer as I like the aesthetic and the period stickers they would throw on them (I love those e-Machines "NEVER OBSOLETE" stickers for example). After finally finding something locally in good shape, a Sony PCV-RX450, I ran in to two issues I hadn't thought about much - heat and noise. Without adding a GPU to it, it was already hot. Airflow is basically non-existent with a limited number of tiny fans, and the fans/PSU fan were loud, which brought me in to another issue, replacement parts. I managed to source a new PSU, but the airflow/heat/noise issues caused me to abandon the plan.I ended up deciding I would do a build with (mostly) new parts for ease of purchase, efficiency, and thermals.
The Build:
I ended up finding a non-functioning computer in a beige case in great shape, with a decent amount of fan mounting areas, 2 IDE CD drives and a floppy drive. I gutted it, and then after researching, I ordered the parts for my build:Motherboard - Onda A97S (New)
This was probably the longest part of the search. Finding a new motherboard with IDE, good expand ability, two PS/2 ports, and Windows 98 proved to be quite a challenge. After a lot of time watching marketplace, scouring eBay, and getting to page 150 of AliExpress I found the Onda A97S. It has everything except for a floppy port - I couldn't believe I would be able to use a brand new motherboard!P.S - For anyone using this board, the Windows 98 chipset drivers are contained within VGA_XP32_070824.zip in the SBDrv folder. I know the archive says XP, but when you run the installer, it says "Windows 98 Driver" right on the splash screen. You can also add it with the .inf file through device manager.
CPU - AMD Athlon II 170u (Used)
I ended up going with the single-core AMD Athlon II 170u as it just sips power at a TDP of 20 watts. Apparently its just a Sempron with a core disabled and you can re-enable it somehow, but seeing as Windows 98 cant make use of it, I never tried.GPU - Nvidia Quadro FX 1300 (Used)
I was originally looking for an ATI PCI-E card as I heard better things about the drivers, but for some reason they seem to command some decent money. On the other hand, it seems these Quadros were at least somewhat plentiful in workstation pre-builds and are often available at good prices as they are pulled from scrap machines to be resold. The first one I ordered didnt work, but the seller sent me another which did work. I ordered a replacement fan for it as the original was LOUD. They are quite plentiful on Aliexpress and eBay for under $10 under various renditions of "VGA PC Computer Video Card Cooler Cooling Fan Heatsinks For NVIDIA ATI Geforce". After pulling the stock fan off, it was apparent it was overdue for some fresh thermal grease anyways.Soundcard - Audigy 2 ZS (Used)
This one took a little time to source as well, as a lot of the ones you see locally or online were the OEM versions which are cut down in one way or another, or cheap out (ie no gold) on the ports. I also seen reports of driver issues with the OEM ones so I wanted to stay away. Downloading the step by step driver install PhilsComputerLab made installation a breeze.RAM - 2x 1GB DDR3 RAM (Used)
With one stick in, I can run the Windows 98 installer, run PATCHMEM, and then install the other stick later. Obviously this much RAM isnt required, but I couldnt find any 512 MB sticks of DDR3, 1 GB per stick was the smallest I could find.NIC - Linksys LNE100TX (New)
Yes, thats right, I found this new, sealed in box. New old stock for sure. I havent set it up yet, but Id like to create a proxy locally that will let you browse webpages via the wayback machine, so I can check msn.com as I did back in 1999.HDD - Patriot P210 128 GB (New)
New, cheap, and under the size limit for Windows 98 so I can avoid another patch.The other remaining parts are a MSI MAG A550BN PSU, and an ARCTIC Freezer 7 X CO cooler as it fit in my case.
Interesting build. I have tried to use Quadro FX 1300 in a build before (on a Pentium D platform). I found that it worked in the popular benchmarks and games. But I think I had compatability issues with others.
What games are you playing on it?
