Reply 540 of 568, by gonzo
- Member
GeorgeMan wrote on 2024-11-29, 07:56:Unfortunately, this motherboard is unstable at 83MHz FSB with any RAM and any CPU
Have a look here https://theretroweb.com/chip/documentation/vt … ee821910227.pdf.
The northbridge is able to do 66/75 MHz FSB only (unless you maybe have a newer/better revision of it).
To be sure, you can disable the onboard-cache (L2-cache) in BIOS and test 83 MHZ FSB again - sometimes the cache, or the cache-timings are problematical.
In my eyes, this board is not good for any overclocking attempts, and this VIA-chipset VIA580VPX is not the best choice.
I LOVE CPUs RUNNING IN [GonzoHz]
