Reply 57360 of 58018, by twiz11
zwrr wrote on 2025-08-22, 00:29:Use 386: Remove the 486 CPU, set the CPU type jumper, set the FSB jumper to 66. Use 486: Install 486CPU, set CPU type jumper, se […]
mtest001 wrote on 2025-08-21, 12:48:zwrr wrote on 2025-08-21, 02:15:2. FOREX chipset 386 & 486 hybrid motherboard
It is a Global Computer Networks FOREX 386/486 with mediocre performance, no more performance tuning options in the BIOS, and a memory read and write speed of only 12MB/s.Interesting, how do you switch between the 486 and the 386? Do you have to enable one or the other in the BIOS?
Use 486: Install 486CPU, set CPU type jumper, set FSB jumper to 33.No BIOS setup is required
ah the good old days of physical jumpers, viruses couldn't infect your bios if the jumper was physically in the wrong spot.
