First post, by rjhansen
I've submitted a sample and told them it's a false positive. It still gets flagged and quarantined.
2.86.2 is flagged as "Trojan:Win32/VBClone!rfn"
I'm currently using the 2.86.1 control panel as a workaround.
Gotta love it.
Reply 1 of 5, by mitradis
classic. Ignore it. Or just use dgVoodoo.conf for edit settings without CP. One way or another, but the panel does not have all the wrapper settings. Better way use dgVoodoo.conf directly. You can remove from dgVoodoo.conf some blocks. For example i use default my shorted config version:
Details
[General]
; d3d11warp, d3d11_fl10_0, d3d11_fl10_1, d3d11_fl11_0, d3d12_fl11_0, d3d12_fl12_0, bestavailable
OutputAPI = d3d11_fl11_0
; all or ID
Adapters = all
; default or ID
FullScreenOutput = default
FullScreenMode = true
; unspecified, centered, stretched, centered_ar, stretched_ar, stretched_4_3
ScalingMode = unspecified
ProgressiveScanlineOrder = false
; if need select custom refresh rate for custom resolution
EnumerateRefreshRates = true
Brightness = 100
Color = 100
Contrast = 100
; can be disabled only for D3D11
InheritColorProfileInFullScreenMode = true
KeepWindowAspectRatio = true
CaptureMouse = true
CenterAppWindow = false
DisableScreenSaver = false
[GeneralExt]
; 1024x768, 1024x768@60
DesktopResolution =
; 8, 16, 32
DesktopBitDepth =
; when resolution is forced to other than the app default (0-16)
DeframerSize = 1
; int or x:3, y:2
ImageScaleFactor = 1
; 0=automatic, 1=no scale or int
CursorScaleFactor = 0
; display region of interest: 16_9, pos:centered or (1024|768), pos:(10|10)
DisplayROI =
; pointsampled, bilinear, bicubic, lanczos-2, lanczos-3
Resampling = bilinear
; auto, discard, seq, flip_discard, flip_seq
PresentationModel = auto
; appdriven, argb8888_srgb, argb2101010_sdr, argb2101010_sdr_wcg, argb16161616_hdr
ColorSpace = appdriven
FreeMouse = false
; alwaysontop, borderless, fullscreensize
WindowedAttributes =
; fake
FullscreenAttributes =
FPSLimit = 60
; DosBox, QEmu
Environment =
; gdi, cursor
SystemHookFlags =
[DirectX]
DisableAndPassThru = false
; svga (128MB), internal3D (4096MB), geforce_ti_4800 (256MB), ati_radeon_8500 (256MB), matrox_parhelia-512 (256MB), geforce_fx_5700_ultra (256MB), geforce_9800_gt (1024MB)
VideoCard = geforce_9800_gt
VRAM = 512
; appdriven, pointsampled, bilinear, linearmip, trilinear, 1-16=anisotropic
Filtering = 8
…Show last 60 lines
; appdriven, disabled, autogen_point, autogen_bilinear
Mipmapping = appdriven
KeepFilterIfPointSampled = true
; unforced, 1024x768, 1024x768@60 or h:1024, v:768, refrate:59
Resolution = refrate:60
; off, appdriven, 2x, 4x, 8x
Antialiasing = 4x
; false if need windowed mode
AppControlledScreenMode = true
DisableAltEnterToToggleScreenMode = true
Bilinear2DOperations = false
PhongShadingWhenPossible = false
ForceVerticalSync = true
dgVoodooWatermark = false
FastVideoMemoryAccess = false
DisableD3DTnLDevice = false
[DirectXExt]
; nvidia, amd, intel
AdapterIDType = nvidia
VendorID =
DeviceID =
SubsystemID =
RevisionID =
; all, classics, none
DefaultEnumeratedResolutions = all
; max, max@refrate, max_16_9, max_16_9@refrate
ExtraEnumeratedResolutions =
; 8, 16, 32, all
EnumeratedResolutionBitdepths = all
; high_quality, ordered2x2, ordered4x4
DitheringEffect = high_quality
; appdriven, forcealways, forceon16bit, disabled
Dithering = forcealways
; 0=automatic, 1=normal or int
DitherOrderedMatrixSizeScale = 0
; appdriven, forcemin24bit, force32bit
DepthBuffersBitDepth = appdriven
; auto, argb8888, argb2101010, argb16161616
Default3DRenderFormat = auto
; 256, 512, 1024
MaxVSConstRegisters = 256
D3D12BoundsChecking = false
; 0=app driven, 1=disable, 2-8=tesselation level
NPatchTesselationLevel = 0
DisplayOutputEnableMask = 0xffffffff
MSD3DDeviceNames = false
RTTexturesForceScaleAndMSAA = true
SmoothedDepthSampling = true
DeferredScreenModeSwitch = false
PrimarySurfaceBatchedUpdate = false
SuppressAMDBlacklist = false
[Debug]
Info = enable
Warning = enable
Error = enable
MaxTraceLevel = 0
LogToFile = false
for some games need change VideoCard or Antialiasing or Filtering. Or FPSLimit and Resolution if you need more FPS (but most games better work on 60).
Reply 2 of 5, by sndwv
Have the same issue from Win10 since weeks. Submitted it as false positive from 2 different PC's / accounts, but still setting off alarms...
This has happened before of course, but usually that resolved in a couple of days?
Reply 3 of 5, by TheDeeGee
mitradis wrote on 2025-07-24, 14:08:
Details
[General]
; all or ID
Adapters = all
; default or ID
Brightness = 100
Color = 100
Contrast = 100
CaptureMouse = true
[GeneralExt]
DesktopResolution =
; 8, 16, 32
DesktopBitDepth =
DeframerSize = 1
; int or x:3, y:2
DisplayROI =
FreeMouse = false
; fake
FPSLimit = 60
; DosBox, QEmu
Environment =
; gdi, cursor
SystemHookFlags =
[DirectX]
VRAM = 512
Filtering = 8
…Show last 60 lines
Antialiasing = 4x
[DirectXExt]
VendorID =
DeviceID =
SubsystemID =
RevisionID =
; 8, 16, 32, all
; 256, 512, 1024
[Debug]
Info = enable
Warning = enable
Error = enable
MaxTraceLevel = 0
LogToFile = false
You can right click in dgVoodoo to open up the hidden options, such at the FPS Limiter.
Reply 4 of 5, by mitradis
It's a matter of taste. I prefer to see all the values ​​in the config file directly. I don't think wrappers need any applications to manage them.
Reply 5 of 5, by Kenshiro3
Details
[General]
; all or ID
Adapters = all
; default or ID
Brightness = 100
Color = 100
Contrast = 100
CaptureMouse = true
[GeneralExt]
DesktopResolution =
; 8, 16, 32
DesktopBitDepth =
DeframerSize = 1
; int or x:3, y:2
DisplayROI =
FreeMouse = false
; fake
FPSLimit = 60
; DosBox, QEmu
Environment =
; gdi, cursor
SystemHookFlags =
[DirectX]
VRAM = 512
Filtering = 8
…Show last 60 lines
Antialiasing = 4x
[DirectXExt]
VendorID =
DeviceID =
SubsystemID =
RevisionID =
; 8, 16, 32, all
; 256, 512, 1024
[Debug]
Info = enable
Warning = enable
Error = enable
MaxTraceLevel = 0
LogToFile = false
I tried. Windows defender overruled me and removed it anyway… even after whitelisting and allowing it.
