Reply 960 of 985, by vsharun
RayeR wrote on 2025-08-26, 16:01:
I wouldn't mix SMM/ME to this (but yes, in some case it is possible IO port trapping in SMM to emulate some legacy stuff like port 64h of keyboard via USB HID).
For simplicity, there are various bridges on the path from CPU to ISA device (on modern system multiple ones), e.g. CPU2PCIE -> PCIE2PCI -> PCI2LPC/ISA. Every bridge can be configured to positive decode some IO windows (IO addres ranges) that are passed through to other side or not or can have subtractive decode that pass all IO address that are not claimed by some other devices on the bus. Problem is that generally bridges has limited number of configurable IO windows with some additional conditions like address alignment/granularity/minimum range... and there can be only one bridge with subtractive decode in the system (multiple ones would cause conflict as it couldn't be decided to which one pass the IO transaction). So this bridges routing capabilities may not be flexible enough for our purpose. As some legacy devices (timer, interrupt ctl, KBD...) are still in PCH and it's needed to pass IO transaction to them while we have our ISA bridge that needs to pass some other IO ranges (like for DMA controller, SB ports, PnP ports) so sometimes it may be impossible to split this 2 paths for onboard legacy devices and our ISA device. In a case where PCH wouldn't contain ANY legacy device it could then simple use one subtractive decode for all legacy ports to our device which would handle/emulate all that legacy devices (like times, interrupt ctl, etc...).
I would. SMM can easily trap port for no obvious reason.
BTW I heard that CHIPSEC has functionality of SMM traps dump via BIOS dump, or may check which ports within given range are trapped using performance counters: trapped port will generate SMI which a) leaves traces in SMI counter and b) has different (significantly higher) execution time.
Reply 961 of 985, by RayeR
Ok, yes, do we have some evidence that SMI handler traps some IOs that are required for ISA functionality? Even if yes it would be hard to do something with it coz SMI handler is usually protected against modding after boot. Yo'd have to patch bios image offline and flash it...
Reply 962 of 985, by dartfrog
I just finished the outlines for a ite8888 config tool for NT/2k/XP and 95/98/ME. It has 2 compatibility layers and checks what version of Windows. The NT/2k/XP layer uses WinIO, where the 95/98/ME layer uses direct hardware access. It uses dynamic WinIo function process to avoid compiling/linking with WinIo as that can be problematic sometimes. I have only tested it on XP compiled with VisualStudio2010 as of the moment, I just bought some more 256 GB SSDs to install other OSes on so I can just swap the HD to test it on various OS.
  • The configuration tool correctly detects OS and finds the ITE8888 bridge.
  • It's able to scan and display the current configuration.
  • It's able to accept a manual configuration via CLI (command line interface).
  • It can set the ITE8888 configuration via preconfigured (hardcoded configurations in source code).
  • It can load configurations from a CFG file and apply it to the bridge.
  • Reset the bridge to it's default state.
  • Created GUS.cfg, SoundBlaster.cfg, FDC.cfg, NE2000.cfg, SCSI.cfg, Serial.cfg
(The picture shows the tool + some example usage, initial load, showing system info, and displaying current configuration.)
I still have yet to detect the new PicoGUS behind the bridge, but atm I'm subtractive decoding, not positively decoding. So that might be one problem.
I also wrote some separate DOS code for the DOS tool, but i need to setup a DOS C compiler/editor and that's a whole can of worms in itself. I might be able to compile the DOS tool on XP with OpenWatcom so I don't need to mess with DOS compilation as I'd rather not relearn it haha, my brain has largely forgot everything needed in DOS for C compiling 🤣. In any case I'm trucking along at a steady pace!
Anyways, hope you're all doing well.
Potential PCIe-to-PCI-to-ISA pathway repository: https://github.com/DartFrogTek/PCIe-PCI-ISA
Reply 963 of 985, by vsharun
dartfrog wrote on 2025-08-29, 09:42:
Under Windows 11 WSL2/Ubuntu is the perfect tool to install and compile DOS apps with both OW and DJGPP.
Reply 964 of 985, by RayeR
I usually compile my DOS tools with DJGPP running under WinXP (NTVDM DOS window) or under plain DOS if necessary.
There are also DJGPP crosscompilers for various host OSes: https://github.com/andrewwutw/build-djgpp/releases
Reply 965 of 985, by dartfrog
Thanks both of you. I went with OpenWatcom on XP for DOS compiling (as I'm already compiling here so why not) and im more familiar with it than DJGPP. But i will have to checkout DJGPP sometime, it looks interesting, and thanks I didn't know of this! I did manage to get the DOS version compiled. I'm just waiting for the new SSDs to arrive today so I can do some dedicated testing on the various apps.
Over the night, I wrote a ISA card detection utility for 95/98/ME/NT/2K/XP, so you can verify your non-PnP ISA card exists behind the bridge. It does require you to configure the bridge chip with positive decode/io forwarding before detecting. I need to add positive decode / io forwarding to the configs as it's all setup for subtractive decoding atm. (was simpler to just leave positive / io forwarding out for the time being till I got the config tool mostly working. now I can go back and add them in). I did detect the flaky FDC card though, so that's interesting!
Interestingly, the detection tool is causing the PicoGUS to turn off when detected and it's causing the PicoGUS to not be found. Sometimes the PicoGUS will reboot itself, other times it will just stay off. If it stays off, you have to do a hard reboot before the card turns back on. I did figure out it's not the bridge getting messed up causing the PicoGUS to turn off, it's the PicoGUS itself. I'll have to go read the PicoGUS code to checkout how they are detecting/configuring the card.
FWIW, I would have assumed XP could detect ISA GUS/PicoGUS automatically as I could have sworn I remember back in the day that happening, but maybe I'm misremembering and it was an ISA SoundBlaster getting detected automatically on XP not a GUS. (My brother had a GUS and I had a SB). Anyways I'll get it sorted soon.
Reply 966 of 985, by Duffman
@dartfrog
There are definitely XP drivers for Soundblaster 16/AWE32 but I don't think there ever were XP drivers for GUS as Gravis were gone by the time XP was released.
MB: ASRock B550 Steel Legend
CPU: Ryzen 9 5950X
RAM: Corsair 64GB Kit (4x16GB) DDR4 Veng LPX C18 4000MHz
SSDs: 2x Crucial MX500 1TB SATA + 1x Samsung 980 (non-pro) 1TB NVMe SSD
OSs: Win 11 Pro (NVMe) + WinXP Pro SP3 (SATA)
GPU: RTX2070 (11) GT730 (XP)
Reply 967 of 985, by vsharun
dartfrog wrote on 2025-08-30, 10:03:
If you have DOS configuration utility for the bridge(s) then you'll free to go with the DOS's debug.
With non PnP cards like the ess688/1688 or PicoGUS in SB mode there's simple commands to check I/O pass-through like reset SB's DSP and check the result via simple OUT/IN two step only sequence.
Reply 968 of 985, by myne
Can't the picogus emulate sb16 and other devices?
I built:
Reply 969 of 985, by Grzyb
myne wrote on 2025-08-31, 01:59:
SB16 not, only SB 2.0.
Nie rzucim ziemi, skąd nasz root!
Reply 970 of 985, by myne
Ok. Well it should be testable with that config.
Potentially all the other pi options too - like lan which presumably uses dma.
I built:
Reply 971 of 985, by dartfrog
I've been working non-stop on the ITE8888 bridge, using two of my motherboards and couldn't get anything to work. I basically exhausted every approach I could.
Then I realized something, both of my test machines have a pci bridge in front of the ITE8888. While you can see and configure the ITE8888 behind the PCI-PCI bridge, I think you need to configure the PCI-PCI bridge as well. Something kind of obvious in retrospect and I think some of you even mentioned this. So I'm working on another configuration tool to configure various IO Controllers / PCI-PCI bridges.
Right now I'm only targeting these southbridges, but we can add more chips over time if it works. (like the PCIe bridge for example)
ICH2 (82801BA), ICH2 Mobile (82801BAM), ICH3 (82801CA/CAM), ICH4 (82801DB/DBM), ICH5 (82801EB/ER), ICH6 (82801FB/FR/FW/FRW), ICH7 (82801GB/GR/GDH/GBM/GHM)
I'll report back when I get a chance, just figured I'd update the thread on my progress.
Reply 972 of 985, by hard1k
Oh wow, that could solve our problems with the Fortex project! We are using Intel 21152 there, so if you implement its support in your utility, it will be awesome.
Fortex, the A3D & XG/OPL3 accelerator (Vortex 2 + YMF744 combo sound card)
AWE64 Legacy
Reply 973 of 985, by dartfrog
I completed the southbridge configuration tool and found i'm still having similar results as before, the ite8888 configuration and 82801 configuration are allowing ISA card reads/writes fine but OS / Drivers / Software are still not able to detect it at all outside of debug.exe probing.
One interesting thing here is an ISA Post Card, well it works flawlessly in my PCI-ISA bridge card. You get logical post card functionality with proper codes for things like missing RAM and other peripherals... In fact, using a ISA post card for IO R/W is perfect for testing basic I/O forwarding as we can see that the configuration tool is actually working and allowing the chips to pass various ports through. So at least we know the card/bridge + configuration tools are working enough to allow some data flow.
It's so frustrating... it's so close to working, but it's just being a right pita 🤣. Maybe this Nixsys motherboard isn't a good candidate for this testing, I will have to see about getting another motherboard. Anyone have any suggestions (cheap as possible, and uses some ICHx but that might not actually matter)
I was reading some code on ISA SoundBlaster identification and it seems like it involves DSP reset timing, and perhaps I have some hardware bug. I might have to get the logic analyzer back out and finish the ISA code for my ISA test probe card...
The weird thing is, if i use debug.exe to validate DSP timing, I receive a valid AA back from:
-o 226 1 ; Hold reset high # Waited some time between commands -o 226 0 ; Release reset -i 22a ; Check for 0xAA […]
-i 22a ; Check for 0xAA response
As far as I know the AA response is the proper Sound Blaster DSP ready signal, and I think I'm testing properly... So it's seemingly ready but drivers don't see the card. Arg! You can see how frustrating this might be. AH we are like 99% there.
FWIW to anyone reading, I've also contributed a dedicated tool to hard1k's Fortex project. Neither of us can test it out yet, but their signature thread link has some info if you're inclined.
Reply 974 of 985, by Duffman
@dartfrog
Was this in windows or pure DOS? might have better luck in pure DOS?
CPU: Ryzen 9 5950X
Reply 975 of 985, by dartfrog
Duffman wrote on 2025-09-16, 04:23:
@dartfrog
Windows, specifically XP. I was hoping by doing most everything here in XP, it would essentially mean I could get all previous OSes working, since each older OS has less and less restrictive environments for talking with hardware. Basically tackle the hardest one first and work backward. But this is turning out to be more difficult than I thought and I probably should move back to an easier OS like DOS.
I've just been dreading testing much in DOS with my current development setup as I compile DOS code in XP, change HD to DOS, Test in DOS, change HD back to XP for changes in code/compilation. But maybe I just need to suck it up and work with the dreadfully slow iteration time or suck it up doubly and use DOS to compile DOS code branch. I can setup dual boot configuration to forgo HD changes, but the last time I set it up I had issues getting back to XP, for some reason it would love to just boot so fast into DOS I couldn't get a chance to open the boot menu. I did buy a Dell OptiPlex 780 Intel Core 2 Duo E8400 3.00GHz 4GB Ram (I think ICH10D?) to use for compilation (also testing) but still waiting for it to arrive. So the problem will be gone in hopefully a few days.
Reply 976 of 985, by rasteri
dartfrog wrote on 2025-09-16, 06:20:
You could set up DOS networking and compile on another PC. Even a modern one.
Reply 977 of 985, by RayeR
dartfrog wrote on 2025-09-16, 03:20:
So you are saying that you tested all involved SB port IO addresses via POST card (with configurable address decoder) and it passed data do display but SB detection tools fails? I think for basic detection IRQ/DMA is not needed, just an IO transactions, strange... are you testing still with PicoGUS or with some real old soundcard? Maybe some old nonPNP SB16 or so would be the best...
Also I would recommend to do tests under pure DOS to avoid some interference with windows multitasking environment...
As it was told before, you can compile in DOS env. both by DJGPP or Watcom, no need waste time with reboots or even swapping HDDs...
For basic IO programming even some old Borland C compiler with textmode IDE would do the job...
Reply 978 of 985, by myne
Wouldn't it be easier to test in the halfway house that is windows 98?
Full, uncompromised dos, 100% driver support, and presumably a compiler/ide like visual studio 2005 that isn't too far behind feature wise or so unfamiliar that it is a learning curve just to get comfortable.
I built:
Reply 979 of 985, by RayeR
Win9x has still preemptive multitasking that may introduce some timing issues...
